Turn off click when I type tndt80 - Computers & Internet
Turn off num lock laptop
Hi aidatul, please try these steps
1. Choose Start---Control Panel---Ease of Access---Ease of Access Center.
2.Click the Start On-Screen Keyboard button.
3. Click on the 'num lock' key once to turn it off
Close the keyboard and try to type.
Jun 19, 2013 | MSI Computers & Internet
Turn off filter keys
The Filter Keys feature in Windows enables the system to ignore keystrokes that it determines are unintentional, such as when you press a key quickly or hold it down for too long. This is a particularly convenient feature if you are learning to type or have trouble typing. However, if you turn the feature on by accident, the system may mistake your typing style as mistakes and ignore some keystrokes. Open the Ease of Access Center to access the settings to turn the feature off.
Click "Start," then select "Control Panel." Click "Ease of Access" at the bottom right corner of the window. Click "Change How Your Keyboard Works" under Ease of Access Center. Uncheck the check box next to "Turn on Filter Keys" in the Make it Easier to Type section. Click "Apply," then "OK" to save the settings. Hope this helps.
Jan 21, 2013 | Computers & Internet
There is no services windows installer
Reinstall the Windows Installer
To reinstall the Windows Installer, rename the damaged Windows Installer
files, and then reinstall the Windows Installer. To do this, follow these
steps:1. Click Start, click Run, type cmd in the Open text box, and then
click OK.
2. Type cd %windir%\system32, and then press ENTER.
3. Type attrib -r -s -h dllcache, and then press ENTER.
4. Type ren msi.dll msi.old, and then press ENTER.
5. Type ren msiexec.exe msiexec.old, and then press ENTER.
6. Type ren msihnd.dll msihnd.old, and then press ENTER.
7. Type exit, and then press ENTER.
8. At the command prompt, type exit, and then press ENTER.
9. Click Start, and then click Turn off computer or Shut Down.
10. Select the Restart option, and then click OK, or click Restart.
11. Log on to the computer.
12. Download and install the latest version of the Windows Installer. For
more information about how to obtain the Windows Installer, click the
following article number to view the article in the Microsoft Knowledge Base:
893803 (http://support.microsoft.com/kb/893803/) Windows Installer 3.1 v2
(3.1.4000.2435) is available
13. Click Start, and then click Turn off computer or Shut Down.
14. Select the Restart option, and then click OK, or click Restart.
(Vista uses Ver. 4)
Was this helpful? Then click the "Yes" button below. Voting helps the web
interface. http://www.microsoft.com/wn3/locales....htm#RateAPost
Jul 30, 2012 | Computers & Internet
Turned hibernation on in error .how do i turn it off again
You can turn it off under power management in control pannel. To avoid this issue in the future try this:
To make hibernation unavailable, follow these steps:
  1. Click Start, and then type cmd in the Start Search box.
  2. In the search results list, right-click Command Prompt, and then click Run as Administrator.
  3. When you are prompted by User Account Control, click Continue.
  4. At the command prompt, type powercfg.exe /hibernate off, and then press ENTER.
  5. Type exit and then press ENTER to close the Command Prompt window.
To make hibernation available, follow these steps:
  4. At the command prompt, type powercfg.exe /hibernate on, and then press ENTER.
Jul 21, 2011 | Toshiba Satellite L670DST2N01 Laptop
COMPUTER CRASHED I NEED TO RELOAD CD BUT I DONT HAVE ACCESS CODE
There are now several versions of the basic Futura software and AutoPunch available on the market. The most current is version 1.0.0.2. To determine what version of either software you have, you will find this information around the inside rim of the CD at approximately 4 o'clock. Before loading any of the Options into your computer, check the version and then follow the steps below. The following steps will update your software so that you will now have the latest 1.0.0.2 version of the basic program and all options.
To load base software 1.0.0.0 with AutoPunch 1.0.0.0 or base software 1.0.0.1 with Autopunch 1.0.0.1
  • You must use bobbin part number 085128. This bobbin is specifically designed for the Futura CE-100 and CE-200.
  • Load Base software (have machine set-up for embroidery with USB connected to both machine and computer - machine turned OFF)
  • Turn on Futura machine and double left click on Futura icon to open program
  • Close program and turn off the machine
  • Install Autopunch and leave the CD in the tray
  • Download appropriate update for Windows Version from the Futura-Support.com updates and save to desktop
  • Double left click on the desktop download icon to install update
  • Type in the Access code from Autopunch jewel case and then left click on the check mark to open program
To load base software 1.0.0.0 with AutoPunch 1.0.0.1 or base software 1.0.0.1 with Autopunch 1.0.0.0
To load base software 1.0.0.0 or 1.0.0.1 with Autopunch 1.0.0.2
  • Load Base software (have machine set-up for embroidery with USB connected to both machine and computer- machine turned OFF)
  • Close software and turn off machine
  • Install Autopunch using Installation Wizard - leave CD in tray
  • Turn on Futura machine and double left click to open program
  • Type in Access Code from Autopunch jewel case and then left click on check mark to open program
To load base software 1.0.0.2 with Autopunch 1.0.0.0 or 1.0.0.1
  • Close program and turn off machine
  • Place Autopunch CD in tray but CANCEL Installation Wizard
  • Turn on Futura Machine and double left click to open the program
To load base software 1.0.0.1 with Autopunch 1.0.0.1 with Hyperfont 1.0.0.2 or Photo Stitch 1.0.0.2
  • Load Base software (have the machine set-up for embroidery with USB connected to both machine and computer - machine turned OFF)
  • Close program and then turn off the machine
  • Install the Autopunch program and leave the CD in the tray
  • Type in the Access code from Autopunch jewel case and then left click on the check mark to open program*
  • Download appropriate update for Windows version from the Futura-Support.com updates and save to desktop
  • Double left click on the desktop icon to install update
  • Install HyperFont program - leave CD in tray
  • Type in Access Code from HyperFont jewel case and then left click on check mark to open program*
  • Install PhotoStitch program - leave CD in tray
  • Type in Access Code from PhotoStitch jewel case and then left click on check mark to open program*
* Must open the program after installing each Option with CD in tray and type in Access Code before installing next Option.
To load base software 1.0.0.2 and adding all Options - Hyperfont 1.0.0.2, PhotoStitch 1.0.0.2, Autopunch 1.0.0.2 and Cross Stitch 1.0.0.1
  • Install Base software (have machine set-up for embroidery with USB connected to both the machine and computer- machine turned OFF)
  • Close program and then turn off machine
  • Install Autopunch program and leave the CD in the tray
  • Type in Access Code from AutoPunch jewel case and then left click on check mark*
  • Install Hyperfont program and leave the CD in the tray
  • Type in Access Code from HyperFont jewel case and then click on check mark*
  • Close Program and turn off machine
  • Install Photo Stitch program and leave the CD in the tray
  • Type in Access Code from PhotoStitch jewel case and then left click on check mark*
  • Close program and turn off machine.
  • Install Auto Cross Stitch program and leave CD in tray
  • Download appropriate update for Windows version from the Futura-Support.com updates (Fut_sp2_Options.exe) and save to desktop
  • Type in Access Code from Auto Cross Stitch jewel case and then left click on check mark*
Dec 11, 2010 | Singer CE-200 Quantum Futura Computerized...
I am trying to get my DVD drive to autoplay. When I right click on the drive icon and select autoplay, the type of file and the program to autorun + apply -- the system seems to respond. But when I right...
The AutoPlay feature may not be turned on. To turn on AutoPlay, follow these steps:
  1. Click Start, and then click Run.
  2. Type regedit, and then click OK.
  3. Locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\CDRom
  4. Double-click Autorun and see whether a zero or a one is displayed in the Value data box.
    • If the value for Autorun is 1, go to step 5.
    • If the value for Autorun is 0, right-click Autorun, and then click Modify. In the Value data box, type 1, and then click OK.
  5. Locate and then click the following subkey: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
  6. Double-click NoDriveTypeAutoRun to see its value. If the value is 0xb5, the AutoRun feature for CD-ROMs is turned off. To turn on the AutoRun feature, follow these steps:
    1. Right-click NoDriveTypeAutoRun.
    2. Click Modify.
    3. In the Value data box, type 91.
    4. Select Hexadecimal, and then click OK.
  7. Exit Registry Editor.
Jun 12, 2009 | Computers & Internet
Office 2004 for mac automatically starts each line with a CAPITAL
To turn off automatic spelling corrections and all automatic formatting:
  1. On the 'Tools' menu, click 'AutoCorrect'
  2. Clear the 'Automatically correct spelling and formatting as you type' check box.
Tip: To specify options for checking spelling, on the 'Word' menu, click 'Preferences', and then under 'Authoring and Proofing Tools', click 'Spelling and Grammar'.
To turn off automatic capitalization and text corrections:
  2. Click the 'AutoCorrect' tab, and then clear the check boxes for the options that you want to turn off.
Tip: To turn off automatic spelling corrections as you type, clear the 'Replace text as you type' check box.
Jan 04, 2009 | Microsoft Office 2004 for Mac
Keyboard buttons clicks before typing
Sounds like he may have turned on the "Sticky Keys", to turn this off , tap the shift key 5 times....should take care of it!
Oct 01, 2008 | Dell Dimension 3000 PC Desktop
Blackberry 7100g
About fixed dialing
If you enable fixed dialing number (FDN) mode, your device only makes calls to contacts on your FDN list. Your device can dial emergency numbers in FDN mode, even if the numbers are not in the FDN list. If your service provider plan includes SMS, you can also send SMS messages to contacts on your FDN list
so if you have this enabled chances are you have to turn it off.
this is how you turn it on so you should be able to use it as a guide to turn it off.
Turn on fixed dialing
1. In the phone options, click FDN Phone List.
2. Click the trackwheel.
3. Click Enable FDN mode.
4. Type the PIN2 code provided by your service provider.
5. Click the trackwheel.
or if you wanna keep it on and add friends to the fdn
Add contacts to the FDN list
3. Click New.
6. Type a name and a phone number.
7. Click the trackwheel.
8. Click Save.
and finally some shortcut keys:
To open the phone, press the Send key.
To end a call, press the End key.
To call a selected contact or phone number, press the Send key. To call a speed dial number, hold the assigned key.
To add an extension to a phone number, press the X key. Type the extension number.
To call your voice mail access number, hold 1.
To type a letter in a number field, hold the Alt key.
To type the first letter on a key, press the letter key once.
To type the second letter on a key, press the letter key twice.
To turn on or turn off mute using the Mute button, press the Mute button.
To turn on or turn off mute using the keypad, press the exclamation point (!) key.
To turn speakerphone on and off during a call, press the period (.) key.
To change the volume during a call, roll the trackwheel.
Aug 02, 2008 | RIM BlackBerry 7100G Smartphone
Computers & Internet Logo
David Payne
David Payne
