Question about Garden
Not sure why this is intermittent loss of charge no blade engagement
Blades not egaging.
Check your ground wire. Follow the wire from your engage switch and or button. The ground wire may need tightened. I had a john deere and this problem was intermittent then if finally didn't work at all. I called the dealer and he walked me through the problem. sure enough the ground connection was not only loose but needed cleaning and tightening. Never had the problem again. hope this helps solve your problem.
May 05, 2016 | Garden
Won't power up when clutch is engaged for mower deck
Something is binding in the mower deck area, perhaps and stuck bearing, bearing needs greased, stick or stone or big clod of grass caught between blade and deck or belt and pulley..
Disconnect to spark plug, and use a stick or something to spin blades manually. MAKE SURE spark plug is disconnected before EVER messing with blades. Motor could spin one time around accidentally and cut off your fingers. Disconnect plug wire and or remove plug to be absolutely sure before messing with blades. I'll say it again REMOVE plug wire from plug before inspecting blade area.
Apr 03, 2016 | Ferris IS2500 52"" Zero Turn Lawn Mower...
Why does my rover rancher stall when i go to engage the cutting deck
1>the pressure switch under the seat may be malfunctioning? (it will cause the engine to die immediately when trying to engage the cutting blades because it thinks your not sitting in the seat.
2>dirty or clogged air cleaner element will cause engine to die when engaging cutting blades. This can be tested very easily by removing the air cleaner element and then trying to engage the blades again. If this works then replace air cleaner element immediately before running the engine anymore.
I have personally experienced both of these problems myself more that once.
Feb 17, 2015 | Garden
Why does my new 3.5CH heli only spin on the ground & lower blades aren't operating. Won't fly. What gives?
Make sure that you charge the batteries overnight. Low battery power will cause loss of power and loss of lift.
Nov 08, 2014 | HobbyTron Phantom 3.5CH RC Helicopter...
Intermittent power steering loss, and engine power loss
Check battery connections and charging system.
Jan 31, 2014 | Cars & Trucks
Loss of power when blades engaded.
Remove deck belt from blade pulleys and Tri to spin blades by hand. If they don't spin freely, you probably need new spindle bearings but if you do need a new spindle I would replace the whole spindle housing... Just make sure the one (s) you buy has housing, spindle, bearings, nut and washer.
Jul 04, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Husqvarna riding mower smokes when cranked and dies when engaging blades
If it dies when engaging the blades it's not getting enough juice to do so. Test the battery and make sure you are getting at least 12 volts. If not, charge it. If so, the solonid is going bad.
Apr 13, 2017 | Husqvarna Garden
Blades fail to engage (using pto) after tractor has been running for awhile.
bad wiring to the charging system or the alternator is bad
May 03, 2012 | Garden
Turn key doent start
Do you here a clunk when you turn the key to start? If so that is the starting coil pulling in, if not the starting coil may be bad or battery drained or safety switches in wrong position, but check battery voltage and connections. I had a friend recently leave the lights on and drained the battery. If battery drained charge it or jump start your mower and mow for a while to charge. Also check to make sure your safety switches are in the right place. I had another friend that had a kid playing in her garage and he had engaged her blades and the safety prevents starting the mower with blades engaged. Also if you have an electrical engaging of blades versus a manual if the blades were left engaged while sitting it will drain the battery also.
Jul 07, 2011 | Garden
Mower blades willnot engage
make sure the battery is fully charged, check all electrical connections and clean them with vinegar and rinse well with demineralized water afterward.
May 26, 2010 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
