Question about Ovens
How much to buy a new oven door for Westinghouse POH967S/1
    Habit-Forming:
  • 143 Answers
This MIGHT be the part.$80.85 +S+H.....https://www.repairclinic.com/PartDetail/Westinghouse-Range-Stove-Oven-Outer-Door-Glass/316406403/1062329?ss=a13b89i530&TLSID=1779&Ref=611198&gclid=Cj0KEQjwrsDIBRDX3JCunOrr_YYBEiQAifH1FmowBLo5d2_ciqlHmfN2bm8mLlnE1Bj9_vmm8W7q-0caAq7l8P8HAQ
Posted on May 09, 2017
I am replacing an oven element for a Westinghouse POH967s/1. The rear element doesn't appear to have screws on the plate that has the elements going into the back of the oven? It had 1 screw on a bracket...
If they are about 1/4" in size and you have a screwdriver that has removable tips, remove the tip and use it as a nut driver to remove the bolts. Otherwise get a nut driver or 6 sided socket the size you need and remove them.
Mar 07, 2015 | Ovens
Trying to find a user manual for Westinghouse oven model POH967s
try retrevo.com bottom of page ,,,and its free good luck
Sep 10, 2011 | Ovens
Hi, We have a Westinghouse electric wall oven with a door which appears to have a broken spring inside. We have previously been able to set it back in gap for hinge but now it has given up holding...
You should be able to buy new springs or the hinge complete from most appliance parts outlets. On some Westinghouse, the door will slide straight off the hinges but on others, you have to strip the door to get at them. Try opening the door and see if the door slides up and away from the oven. If it does, its pretty easy to change the hinge, if not, there will be a little clip on each hinge which locks the arm in place. Slide the clip on both hinges to the front and then you can lift the door up and out of the oven. remove the screws holding the door together and then you will see the 2 screws which hold the hinges in. Order a left (or right) hand side whatever one you need, but I would suggest that they are replaced as a pair, otherwise the door may not close evenly.
Jul 31, 2011 | Ovens
The oven door has disengaged at the hinge I cannot get back into the slot on the stove westinghouse
Hi You cant do this without taking the door off the oven this is a 2 person job when it has disengaged There is a wire clip on the bottom of the K type hinge that hooks on to the top of the hinge if you can get them to hook together you can then remove the door You need to do this to both hinges lay it flat get the 2 hinges hooked together put the door back in the oven and release the hook the hook also looks like a flat u shaped bracket it depends on which westinghouse stove you are talking about as to where it is located mostly it is very close to the oven itself Regards Geoff Stove Recyclers
May 28, 2011 | Ovens
I have a westinghouse fan forced 600 wall oven and I need the serial or model number to get a new door for it, Thanks
There is usually a small sticker on the oven inside the door at the bottom edge of the oven. This usually has the information you require on it. If this is not the case then if you have the handbook for the appliance you can get it from there.
Failing this take a digital photograph of it and this will often be enough for a parts supplier to identify the item.
You don't say how old the oven is but a new door will be quite expensive, check out the cost first relative to .the cost of a replacement oven.
Dec 11, 2010 | Ovens
The hinge on our westinghouse silhouett oven door may be damaged as the door will not give a tight seal can it be repaired or replaced and how, the rest of the oven works like new.
If it is a drop down door, then the hinges are not repairable, the only solution is to replace both door hinges, and not just the broken one.
Hope this helps.
Jan 30, 2010 | Ovens
White-Westinghouse wall oven, no manual
after self cleaning I cannot open the door
Dec 18, 2009 | Ovens
How to clean between doors of a wall oven a
2smart4u did not answer the question - how to clean between the glass on the oven door. I too have streaks inside the glass - looks bad - no way to clean it?
Dec 04, 2009 | Ovens
Westinghouse POC700M Ultimate One wall oven. We are putting a new element in it. How many wires should connect to the element on either side (ie. looking into the oven left and right)?
if you have not removed the old one yet . reinstall the ones onthe right to the right. and the same on the left . there is on most ovens only two . mm
Nov 22, 2009 | Ovens
Westinghouse Wall oven mod.PON 667S
Hi there.
Westinghouse have produced a modification which replaces the left and right door support channels in the front of the oven.
Call Ryan Nielson Spare Manager at Axial Appliance Servicing www.axial.co.nz
in Mt Wellington Auckland, and he can sell you the reinforced parts which cost me $27 for my oven.
I am replacing these channels myself this weekend as warranty no longer applies to our oven, but if yours is still under warranty I'd suggest that Axial will do the whole job.
Dec 16, 2007 | Ovens
Ovens Logo
46 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
