Question about HP Garden
I have a Yard Machine self propelled walk behind lawn mower. It is electric start but also has the cord to pull start. It has a 6.5 Hp Briggs and Stratton engine. We lost the key. How can i start it.
    Habit-Forming:
  • 143 Answers
Lowe's*,Home Depot*(Tractor Supply,Rural King?)(*Best pricing),Ace /True Value,Walmart hardware,local lawn-mower shop will carry replacement keys,generally....it's usually a generic('Master' (NOT as in 'MASTER locks')key....https://www.google.com/search?client=aff-maxthon-maxthon4&channel=t27&q=Yard%20Machine%20replacement%20key
Posted on May 09, 2017
  • 3600 Answers
SOURCE: Yard Man 21" Mower Pull Cord Won't Retract
You will find the retractable spring is broken you can go to any lawn mower shop and buy a replace me, also Wal mart and others you will have to wind it up till rope is tight then hook to the flywheel where the slot is. cost about $10.00 also lube the center hub bearing with wd 40
Posted on Jul 16, 2009
SOURCE: my craftsman rotory lawn mower 6.5 hp self
You have water in in the carborator, I'll bet. I had this same problem. Here's what I did.
I emptied the gas tank, put in a new spark plug, changed the oil and then unscrewed thd big nut on the bottom of the float container (attached to the carborator near the rubber gas injector button) and emptied and cleand the float container. Then i put it all back together, pulled the cord and the same thing happened, but this time i could keep it going by having my daughter constantly pushing the rubber gas injector button. After it had run for a minute with this constant pushing of the button, all the water was gone from everytwhere and it worked.
Posted on Aug 13, 2009
rwvanlue
  • 486 Answers
SOURCE: Stuck pull cord on Toro 6.5 self-propelled mower
1) Common problem when a mower sits for several weeks at a time between mowing;
check for extra grass debris to be glogged between the blade and the mower shell.
2) If the mower has a 'bail' or 'zone' control handle;
this releases a brake mechanism on the flywheel to allow it to rotate, and after it is running, releasing the lever will 'kill' the engine.
NOTE* when transporting a push mower in the trunk of a car, try to keep the mower as level as possible.
*extra note when mower has been transported in the back of a car;
sometimes the mower is placed in a trunk at such a severe angle that the oil from the crankcase is forced around the rings and sits on top of the piston so that when you try to pull the rope you have a 'hydra' lock. (that is when a liquid is between the piston and the spark plug) You cannot compress a liquid, so the rope appears stuck.
If this happens, remove the spark plug (make sure the loose plug wire is fastened away from any combustable that comes out of the spark plug hole *** AND THERE WILL BE A HUGE STREAM OF OIL AND GASOLINE, SO BE PREPARED TO CLEAN UP A MESS ***
pull as normal until fluid is dispelled from internal engine
clean or replace the spark plug
a few more pulls (no choke required) and you are up and going
Posted on Nov 08, 2009
SOURCE: rally ride on lawn mower not starting. briggs and
i have a rally lawn tractor when i hook up the battery it wants to start key is off only thing i did was change the belt. was working fine before .
Posted on Jul 29, 2010
  • 100 Answers
SOURCE: Mower cord is hard to pull and it makes a crying
starter clutch under recoil is seizing on shaft...need to polish shaft and lubricate....recoil housing will probably be damaged as well
Posted on Aug 14, 2010
How do I change the belt on a Briggs and Stratton Self Propelled 7.25ex lawn mower
unbolt top cover 5/16, unbolt bottom cover 3/8 unbolt blade 9/16 or 5/8 remove old belt, install new one, install covers and blade
Oct 01, 2014 | Briggs & Stratton Garden
What is the sprkplug gap for a 6.5 briggs &statton
Contact MTD if your manual doesn't cover this, or buy a shop manual. Or go to the Briggs & Stratton website.
May 20, 2014 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Have a self-starting, self propelled toro lawn mower about 5 years old, I ran it out of gas by accident & now it won't start
It seems to be an obstruction in your fuel delivery system. Get a can of ether and a spray a short burst of it into the breather area near the carburetor, if the mower starts up and then stalls out, then you may need to get your carburetor serviced.
Dec 18, 2013 | Toro Lawn Boy Self Propelled CARB Walk...
Pull cord on john deere 190cc 6.75 hp
The housing might be riveted to the engine housing and might need to come off together. Hope this helps!
Jun 09, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
Aug 01, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Lawn mover will not start, was flipped over
The clicking noise may be the blade hitting the side of the mower or it was not put on properly. It needs a balance to the aluminum flywheel on top of the engine. The blade adapter and blade provide this balance for the engine to run.
Good Day.
Oct 07, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Jul 16, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Garden Logo
35 people viewed this question
Top HP Garden Experts
Vernon Taylor
michael vanier
Are you a HP Garden Expert? Answer questions, earn points and help others
