Question about Gentron Electrical Supplies
,How do i get a manual for this unit, Gentron pro2 generator welder manual pdf
    Sergeant:
  • 197 Answers
Plug gap for 6000p gen.
Plug gap is not hyper-critical. Too close is usually worse than too wide.
If you set the gap at .035 and the recommended gap is .025, it'll still run. Or set at .035 and recommended is .045.
We're talking about the thickness of 2-3sheets of paper difference.
Jan 13, 2018 | Gentron 6000 Watt Propane Generator with...
https://www.google.com/search?client=aff-maxthon-maxthon4&channel=t27&q=gentron%20pro2%20generator%20welder%20manual
May 09, 2017 | Gentron Electrical Supplies
You must be more specific. Here's a link to a .pdf manual for A Gentron generator; perhaps you may find your generator manual within this thread.
http://www.searspartsdirect.com/partsdirect/user-manuals/GG3500-Gentron-GENERATOR-manual
Mar 06, 2016 | Gentron Electrical Supplies
Where can I get an owners manual ?
PDF]10000W Generator
scene7.samsclub.com/is/content/.../GG10020-Eng%20manual-cpdf
Gentron/UPC will repair or replace, at Gentron/UPC's sole option, products or components ... Expendable parts or accessories supplied with the product which are..... FILLED WITH OIL OF A HIGH QUALITY SAE 10W-30 GRADE ENGINE OIL.
Gentron - 10000 Watt Gas Generator with Electric Start
www.samsclub.com > Sam's Club > Emergency Supplies
Sam's Club
Rating: 4.4 - ‎330 reviews
Gentron 8,000W / 10,000W Portable Gas Powered Generator with Electric Start ...... 1 year parts and labor limited manufacturer's warranty; For issues not ...
Gentron Pro2 10000w Gas Generator (GG10020)
https://generatornow.com/gentron-gg10020-pro2-10000w-gas-powered-...
Gentron GG10020 Pro2 10000w Gas Powered Portable Generator with Electric ... It's a one year/1000 hr parts and labor warranty for our residential customers.
Jan 21, 2016 | Electrical Supplies
How do I wire the on/off switch on a gentron 10,000 generator?
Give us a call when you are with the Generator and we will run through it with you. Call your local office and speak to an engineer: http://www.generatorguru.com/ask-the-guru/
Generator Guru
Sep 24, 2015 | Gentron 10,000W Generator with Electric...
Champion 4500 watt generator. 140 amp ac welder Hobart, What type of oil does this need and how much
This welder generator has a Briggs & Stratton 305cc gasoline engine. The service and maintenance manual is at http://www5.briggsandstratton.com/eu/cz/pdf/owners_manual/100%5CMS3780-GB.pdf
Page two has a chart for the oil by ambient temperature ranges and whether or not you use synthetic oil.
5w30 and 10w30 synthetic are good for all temperatures. That's what I recommend.
Aug 17, 2014 | Welding Tools
Why does my miller bobcat welder generator not stay at an idle when swithed to low idle, insted it goes back and forth to high then to low idle?
The unit may need recalibrating the idle/run setting. Instructions found in manual at 8-6 (subaru engine) and 9-5 (kohler). Idle speed around 2200rpm. Simple screw adjustment. PDF manual here :- http://www.millerwelds.com/om/o4434l_mil.pdf
Aug 02, 2014 | Bobcat Miller 225 Welder Generator 907209...
Outlets providing incorrect voltage
The Wiring for this unit was screwed up in manufacturing. reverse the lines from the 120 side and the 120v end of the 240 pole. that should resolve the issue and you should also find that if you trace the wires back to the source on the dynamo they will now match/Pair up properly. Make sure to mark the wires you are swapping carefully and test under no load before load testing the unit.
Nov 21, 2013 | Gentron 10,000W Generator with Electric...
Gentron pro2 6000p has no spark
With small engines, ignition is magneto. Four things can cause a lack of spark: (1) Faulty plug - try a new plug; (2) Bad, shorting, or disconnected spark plug wire - check for high voltage from ignition coil; (3) Bad ignition coil - check for low voltage at the coil input wires; (4) Magneto failure - the pickup coils next to the flywheel may be shorted, loose, or disconnected, OR the magnets on the flywheel may have lost their field or come out. I would troubleshoot this problem by checking and eliminating each of these possibilities in the above order. If all of the first three check out good; I'd have a mechanic check the magneto because this requires at least partial disassembly of the motor.
Nov 17, 2012 | Gentron 6000 Watt Propane Generator with...
Electrical Supplies Logo
70 people viewed this question
Top Gentron Electrical Supplies Experts
Phil Walker
Phil Walker
 Generator Guru...
Generator Guru...
richie46
Are you a Gentron Electrical Supply Expert? Answer questions, earn points and help others
