Question about The Office Equipment & Supplies
My 08. Husqvarna with a Briggs, pours oil from the upper right side when it is hot & level is full. Not too bad when left at 1/2 full
27.0 hp. 2754GLS. Model. 440777 Endurance Series
  • 195 Answers
SOURCE: Have a Briggs & Stratton lawn mower engine, 4.5
Is Blade new or causeing vibration .Chge blade,
Please rate Thank you jj505
Posted on Mar 30, 2009
  • 1902 Answers
SOURCE: 31p777 18.5 hp briggs & stratton valve cover leak
Both can cause problems. It is recommend that you do not go on a grade more the 10% for your safety and the safety for others around. But if the valve cover is leaking this can lead to major problems if not repaired on a timely matter
Posted on Apr 29, 2009
  • 10319 Answers
SOURCE: my 25 hp briggs is smoking and leaking oil. it
if the engine is ran quite a lot evey year the valves muct be adjusted. If not it will cause a head gasket leak which it sounds you have
Posted on Apr 03, 2010
  • 4345 Answers
SOURCE: My 24 hp Briggs v
There is no sealer that will resolve a head gasket issue, if that is what you have going on. and, if the head gasket failed remember it is a victim and not the cause, something else in happening.
I suspect that you have a compression related failure, based on the oil consumption and the smoke is probably blow by. This issue requires surgery to diagnose and fix.
Posted on Oct 11, 2010
  • 528 Answers
SOURCE: I installed a new Price
No and you can thank you government rep next time you see or talk to him for this. The valve is set to give no more than 110 to 115 degree water and cannot be changed. If you want hotter water you will need to install a non-scald faucet. Now if you are not getting to the 110 degree mark then you will need to disassemble the valve body and look for debris in the hot water inlet side.
Now when it is apart turn the water on low and flush the piping out before putting it back together.
Posted on Feb 11, 2011
My husqvarna YTH2448 with BS 24OHV ELS725 started knocking and leaking oil from right side. I guess it threw a rod? I want to get another 24HP motor and replace it. Will any other motor's bolt pat
most all motors will boltt up u need to make sure the crank is the same diameter and length besides even if it didnt bolt right up u can always drill new holes
Jul 07, 2012 | Briggs & Stratton Briggs Stratton Intek V...
How much oil does my 03 fxst hold ?
It holds three quarts of engine oil with a filter change. When you change the oil and filter, pour three quarts in the tank and start the engine up for one minute. With the bike still on the side stand, check the oil. The level should be between the lines. Do not "top it off". As long as the level is between the lines, whether the oil is hot or cold, do not add oil. Only add oil if the level goes below the lower line. The top line is "FULL HOT" and the lower line is "FULL COLD".
Good Luck
Jul 31, 2011 | 2003 Harley Davidson FXST Softail Standard
2006 roadking oil change proceedure
Look underneath the transmission and you'll see two drain plugs. The drain plug for the engine oil is the one closest to the left front corner of the oil pan. Drain the oil with the bike on the side stand. Change the oil filtter. Refill with three quarts of 20W50 oil. Check the oil level with the dipstick while it's on the side stand. There are two marks on the stick. The lower mark is 'FULL COLD" and the upper mark is "FULL HOT". Do not overfill.
Don't forget to change the primary oil and the transmission lube when it comes due.
Good Luck
Feb 23, 2011 | 2006 Harley Davidson FLHR Road king
What is the oil capacity for a 1987 FLHTC Electra Glide Classic
I think it's three quarts but the tank has a dip stick on it. After draining the tank and changing the oil filter, pour three quarts into the tank. The dipstick has two marks on it. Check the level with the bike on the side stand. The upper mark is "FULL HOT" and the lower mark is "FULL COLD". Top the oil level off to the lower mark and recheck once you've ridden the bike.
Goodl Luck
Aug 15, 2010 | Harley Davidson FLHTC Electra Glide...
How to check oil level and add or change oil?
Most of the Dyna series bikes have the oil tank on the bottom of the transmission. On the bottom of the trans, there are two drain plugs. The center drain plug is for the transmission. The drain plug nearest the front left corner of the pan is the oil drain.
To check the oil level. Check the oil with the bike on the side stand. The dipstick has two marks on it. The upper mark is "FULL HOT" the lower mark is "FULL COLD" . Have the oil level somewhere between the two marks.
Good luck
Jun 17, 2010 | 2005 Harley Davidson FXDL - FXDLI Dyna Low...
I have a 18 hp briggs and stratton engine that will not start
A few more things to check.
1. The oil level. If the oil level is low the oil level sensor will ground the ignition.
2. Check the wiring from the seat safety switch to make sure it is connected.
3. Follow the black wires from the ignition control module to make sure none of them are chaffing and do not have a chassis ground.
If you still have problems disconnect ONE lead from the oil level sensor and see if you have spark. Most of the time these oil level sensors are the common failure.
Apr 29, 2010 | Briggs & Stratton Briggs Stratton Intek V...
I see a lot of white smoke out of the outlet, what can be the problem i have a 15.5 hp intek ohv motor
Jul 28, 2009 | Briggs & Stratton Briggs Stratton Intek V...
What kind of oil for a husqvarna riding mower?
Yes SAE 30 is the recommended oil for B & S engines. You can find it on amazon for good price. here: Amazon com oil 30w . Hope this was helpful. cheers
Jun 14, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Where is the oil filter located on the Husqvarna Lawn Tractor, Model YTH2348
if its a 23 hp briggs and stratton it should be on the opposite side from the dipstick where you check the oil down low.
It may be black with a briggs and stratton label or it may be yellow with the same.
Jun 05, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
How do I check fluid level on YTH150 Hydrostatic Transaxle?
My Husqvarna hyrdrostatic transmission is sealed, and yours may very well be also. That means no changing the fluid.
May 13, 2009 | Husqvarna Garden
52 people viewed this question
Top The Office Equipment & Supplies Experts
Ian White
Level 1 Expert
Level 1 Expert
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
