Question about Car Audio & Video
2006 Outback Stereo and Climate control stopped working. Battery drained in day and a half.
2006 Outback XT 6-disk changer Stereo and auto climate control stopped working while running CD player. No audio and stereo display completely blank pushing buttons has no effect. Climate control displays "AC" and "AUTO" on screen and doesn't turn off even after key removed. Battery drained in day and a half. Everything else seems to be working. Had seen stereo and climate control cut out briefly when playing CDs but was previously recovered on own. On taking out stereo/climate control found 2 pennies inside that likely kids had put in through cd input. Any hope of repair?
SOURCE: Sporatic problem with Stereo and Stereo Display
I have had this problem intermittently since I purchased the vehicle in 2004... the dealer could not fix but showed me that there is a relay that you can pull and re-install. It's under the hood and must be done with the ignition and lights off. Pull the relay, wait 10 secs and re-install and pblm goes away. If you are standing in front of the vehicle there is a relay box on your right/vehicle left. The relay is located in the lower left-had corner of this box. Not a permanent fix, and in my experience the problem goes away when the vehicle is parked for an hour or so but if you have a long drive and want to use the radio, this 60-second fix is worth knowing...
Posted on Nov 08, 2008
  • 850 Answers
SOURCE: I have a honda accord EX 2006 w/out Nav. I was
circuit board in cd player may be at fault
Posted on Jul 18, 2009
  • 510 Answers
SOURCE: stereo and cd player are seperate units
I take it you have a cd stacker
PRESS AND HOLD eject button,insert credit card under cartridge
Push card firmly in,move left -right,this will locate micro switch.
Cartridge should pop out so you can check discs
Posted on Dec 20, 2009
SOURCE: Hyundai CD player displays ''error'' for all functions
my cd player in my sonata keep eject the cd can anybody help
Posted on Jan 12, 2011
  • 22306 Answers
SOURCE: Reset radio and now cd changer doesn't work or even display when pushing button
try this and thats to remove the cartridge and take all the cds out ,then insert the empty cartridge into the set to see if it removes the last cd that was in the player ,then with one cd in try it again and if that doesnt work then disconnect the battery and try again other than that i have no idea sorry
Posted on Apr 13, 2012
Climate control resets when Camry is started
may be a factory setting do u use all of the controls on the panel for air, etc?
Sep 13, 2015 | 2008 Toyota Camry
Location of fuse to control side mirrors on 2009 97x
Fuse panel in end of fascia
No. Amp. Function
1 15 Steering wheel lock
2 5 Steering column unit; ignition switch
3 10 Hands-free; cabin CD changer; SID
4 10 Main instrument unit; manual climate control;
automatic climate control (ACC)
5 7.5 Control module in front doors; Park Brake Shift Lock
(automatic transmission)
6 7.5 Brake light switch
7 20 Fascia fuse panel; fuel filler door
8 30 Control module in passenger front door
9 10 Fascia fuse panel
10 30 Trailer socket; electrical socket in storage compartment
between seats
11 15 Data link connection (diagnostics)
12 15 Interior lighting incl. glove compartment
13 30 Accessories
14 20 Radio, sound system I; control panel,
Infotainment System
15 30 Control module in driver's door
16 - -
17 - -
18 7.5 Manual climate control; fan
19 - -
20 7.5 Headlight levelling switch
21 7.5 Hands-free; brake light switch; manual climate
control; clutch pedal switch
22 30 Cigarette lighter
23 40 Cabin fan
24 7.5 Airbag control module
25 - -
26 5 Yaw sensor (cars with ESP)
27 - -
Trunk fuse panel, left-hand side
No. Amp. Function
1-5 MAXI -
6 30 Control module in left rear door
7 30 Control module in right rear door
8 20 Trailer
9 - -
10 30 Left-hand brake light; rear right turn signal; right tail
light; right reversing light; high-mounted brake light;
trailer lights
11 - -
12 - -
13 - -
14 - -
15 15 Seat heating, left seat
16 15 Seat heating, right seat
17 7.5 Autodimming rearview mirror; rain sensor; tire
pressure monitoring
18 15 Sunroof
19 7.5 Telematics (OnStar)
20 7.5 DVD player (navigation system)
21 7.5 Saab Parking Assistance (SPA); control module in
rear doors
22 30 Amplifier, sound system III
23 - -
24 10 Movement sensor; CD changer in trunk (accessory)
25 30 Electrically adjustable driver's seat with memory
26 30 Right-hand stop light; rear left turn signal; left tail
light; rear fog light; left reversing light; license plate
lighting; trunk lighting; trailer lights
27 - -
28 - -
29 - -
Fuse panel in front of battery
No. Amp. Function
1 60
Secondary air injection pump (certain models)
2 20 Fuel pump; preheated oxygen sensors (lambda
3 10 A/C compressor
4 30 Main relay
1 Secondary air injection pump
2 A/C-compressor
3 Preheated oxygen sensors (lambda probe)
4 Main relay, engine (ECM/EVAP/injectors)
Sep 13, 2012 | 2006 Saab 9-7X
Lack of power, hesitation, climate control blowing hot air
Always check body grounds. You may have good power to the engine with a good ground still, but your body grounds control power to all else.
May 03, 2017 | 2006 Lincoln Mark LT
I was attempting to install a new stereo in my 2000 taurus. it requires to an adapter to put the new stereo in. i got the new adapter and stereo in *kinda* but decided i didnt really know what i was...
check your fuses first. You may have blown one.
Visual Inspection Chart Mechanical Electrical
  • Integrated control panel (ICP) physically damaged, misaligned, any control(s) inoperative
  • Digital audio compact disc player physically damaged, misaligned, any control(s) inoperative
  • Antenna or antenna cable physically damaged, misaligned connection(s)
  • Radio speakers, mounting/speaker cones physically damaged, misaligned
  • Radio ignition interference capacitors, radio frequency interference suppression bond misaligned (also check for cleanliness and metal-to-metal contact)
  • Battery junction box (BJB) fuses F127 (5A), F117 (20A), F127 (5A).
  • Central junction box (CJB) fuse F227 (10A) F211 (15A), F216 (15A), F226 (10A) (wagon only)
  1. If the fault is not visually evident, proceed to diagnose the integrated control panel (ICP) by entering the ICP Self-Diagnostic Mode.
NOTE: To enter the ICP Self-Diagnostic Mode, the ICP must be ON and in radio tuner mode (AM/FM).
  1. Enter the diagnostic mode by pressing and holding preset buttons 3 and 6 simultaneously. This will suspend all radio functions, and display SP.
  1. Preset Button 1 = Audio internal/external SELF TEST. The display will flash SELF while gathering the diagnostic trouble codes (DTCs), then stop flashing when complete. Press the TUNE UP button to display the DTCs if any exist. Record codes and refer to the following table:
ICP SELF-TEST CODES Code Description 0 No diagnostic trouble codes logged 1 No response from rear chassis unit (RCU) 2 No response from cassette player 3 - 4 No response from compact disc player 5 - 6 - 7 No response from remote climate control 8 - 9 Read Only Memory Verification failed
  1. Preset Button 2 = Displays the feature strap for code identification, refer to the following table.
Code Description 01 Base-Electronic Search Radio (ESR) with Manual Climate Control (MCC) 07 Electronic Search Radio with Cassette (ESC) with MCC 17 ESC with Electronic Automatic Temperature Control (EATC) 97 Not programmed default of ESC with EATC
  1. Preset Button 3 = ICP and RCU identification. This test identifies the software level of the ICP and RCU. The ICP is tested first, followed by the RCU. The display will have two sequences of three codes each. The first sequence is for the ICP, the second sequence is for the RCU. For code identification, refer to the following table:
Item Part Number Description 1 - Product variant code 2 - Tape model 3 - CDR
SOFTWARE IDENTIFICATION CODES Product Type Code Description Product Variant Code Description 21 ICP 07
12 EATC with AM/FM, cassette player and CD changer
EATC with AM/FM and cassette player
Manual A/C with AM/FM and cassette player
EATC with AM/FM cassette player and CD changer 31 RCU 01
03 Analog
Midline 71 Remote climate control 01 LH drive 52 Compact disc/disc jockey 01
04 Sony® 10 disc
Sony® 6 disc
Clarion® 6 disc
FMS 6 disc
Sep 13, 2011 | 2000 Ford Taurus
How i revome the stereo on my chevy malibu 2006
Disconnect the negative battery terminal
to prevent an accidental short
Unclip and remove wood grain/painted
trim pieces from both sides of
steering wheel. (Figure A)
Unclip and remove side panel from
driver’s side of dash with door open
and remove (2) 7 MM screws.
(Figure B)
Remove (2) 7 MM screws from bottom
edge of panel below steering
wheel, unclip panel and let hang. It
is not necessary to completely
remove panel. (Figure C)
grain/painted trim piece from above
glove box.
passenger side of dash with door
open and remove (2) 7 MM screws
from behind panel
of glove box then open box and
squeeze sides together to open further
and remove the remaining (4)
7MM screws. Unclip the black vent
cover under the glove box then unclip
and remove entire glove box assembly.
(Figure F)
Unclip and remove trim panel surrounding
radio and climate controls.
(Figure G)
Remove (4) 7 MM screws securing
the radio and (2) 7 MM screws securing
the climate control. Unplug and
remove the radio. (Figure H
Feb 08, 2010 | Sony Car Audio & Video
2006 Subaru Outback radio & climate control display not working
The faceplate for the radio HVAC is broken. Check your local Subaru dealer for replacement
May 27, 2009 | 2005 Subaru Outback
Blower motor or resistor?
Yes its the blower motor resistor.
More then likley theres some trash or something in it, or possibly the motor itself is on it's way out. There not that bad to pull out of that body car, just pull it out and see what you can see.
The blower motor is under the glove compartment
You can replace the resistor on your own. Please find a detailed diagram which would guide you to do it.
Apr 09, 2009 | 2000 Chevrolet Malibu
MSD2758GEW Climate Zone Drawers
Jan 31, 2009 | Maytag MSD2758GEW
2003 Subaru Outback Aircon and heater control is dead. It will not respond to buttons being depressed. I have checked the fuse box and they seem OK. I've swapped relay around with no luck. Is this a...
Apart from the fuse box in the engine bay there is a fuse repository behind the coin alcove underneath the boot release. Fuse 3 for the lighter (I think) was blown. I replaced it and now the climate control console responds and the display lights up.
Nov 27, 2008 | Subaru Outback Cars & Trucks
Car Audio & Video Logo
41 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
