Question about The Audio Players & Recorders
Tape will not play when using foot pedal, nor does the unit play when you push "play".Brand new machine.We have checked all leads are plugged in properly.It does automatically rewind. What can we do?
  • The Master
  • 5,487 Answers
Return it to where you bought it and they will either give you your money back or replace it. DO NOT ATTEMPT to repair it yourself has that will break the warranty agreement.
Posted on May 09, 2017
My brand new Singer 7463 will not sew, even though the lights, stitch settings, and everything else are completely fine.
The foot pedal is just a variable resistor to give you speed control of the motor
You say the machine is new so it will still be under warranty
have a service technician check it out
It could be a faulty control pedal or leads or motor
Aug 04, 2015 | Singer Confidence 7463 Computerized Sewing...
When using the foot pedal for forward playback to transcribe, when you lift your foot to stop the tape continues forward for about a second.
It sounds to me that you might have a mechanical problem in the machine. I am not familiar with this machine, but I have worked on lots of tape machines. The belts and rubber pieces can get slick or stretched causing problems.
Oct 24, 2017 | Sony M-2000 Microcassette Transcriber
My daughter's brand new, right out of the box Janome 2212 machine is not working. The foot pedal is not engaging the motor so the needle doesn't move up and down. The wheel is pushed in as it
Sorry, but gotta ask is it plugged in and turned on? Check before you answer. (I ask this because it happened to me, set up, ready to go, and no power. After an hour and the machine was in pieces, My son asked if i plugged it in and I snapped "YES, DUH" not seeing him twirling he plug in his hand...he informed me that you must be 10% smarter than anything you operate or eat....at which point he was happy to inform me, the machine was 11% smarter. If it is plugged in and turned on, is the plug to the foot pedal plugged all the way in? Is the machine on? If you get zero reaction, no movement or sound of any kind, the foot pedal my be faulty, it can happen. Take it back to the dealer and they should replace the entire machine or the foot pedal. Good luck and happy sewing.
Jan 10, 2013 | Janome 2212 Sewing Machine
I have a 720. Sometimes when I press play it will rewind.
Hello I can read your full problem but when it hapen unplug your foot pedal to see if the pedal is causing the problem here is a link for a original foot control replacement http://www.tvps.com/Products/Philips-LFH-0210-Foot-Pedal---New__PH-LFH-0210.aspx or just send your unit for service at Send an email to service@tvps.com or call (800) 644-9525. Please indicate model, serial and detailed description of problem
Jun 15, 2009 | Philips Desktop 720-T Desktop Cassette...
Tape completely rewinds when I let off the foot pedal
Make sure the button for back space is not at max is the second button from the right side if problem don’t get fix unplug the pedal from unit and try to play and stop if unit work Ok the problem is your pedal. Needs to be replaced.
Apr 02, 2009 | Panasonic RR-930 Desktop Cassette...
Foot pedal FF or Rewinds when pressing Play
It's possible that there's a broken wire in the cable that connects the foot control to the machine. This usually happens near the plug that plugs into the machine, or by the end that goes into the foot control.
You can usually duplicate it if you put the auto-backspace up a bit and then hold down the play pedal on the foot control. While holding down the play pedal, try moving the cable near the machine or near the foot control in a circular motion. If the machine stops, rewinds or fast forwards, then odds are that the problem is with the cable.
Mar 13, 2009 | Dictaphone 3750 Desktop Cassette...
Top The Audio Players & Recorders Experts
bihug
bihug
Level 1 Expert
D. E. Hev
AliennoisE
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
