The cylinder is tilted inside.it happened while it was working.though machine is working its not proper
My Frigidaire Window Ac Unit is Collecting Water on the Styrofoam Thats Facing Inside The Home By The Vents,Why Is this Happening?
tilt your ac down on the outside,so it will drain properly,if that doesnt help,pour some bleach in the water inside to get rid of mold that clogs the drain
Apr 18, 2017 | Heating & Cooling
I have a 1996 GMC Safari van 4whl drive 6clyder everything works with car off but when i put the key in the ignition it wont turn what does that mean and how do i fix it with out taking it in the shop?
IGNITION SWITCH AND LOCK CYLINDER BROKEN. YOU NEED TO TURN OFF RADIO THEN DISCONNECT NEGATIVE BATTERY CABLE WAIT 20 MINUTES UNTIL AIRBAGS DISCHARGE THEN LOWER STEERING COLUMN DONT LET COLUMN ROTATE DAMAGE SIR COIL.YOU NEED TO REMOVE 2 TORX SCREWS FROM UPPER SHROUD.LIFT UPPER SHROUD FOR ACCESS TO THE LOCK CYLINDER.HOLD KEY IN THE START POSITION AND USE A 1/16 INCH ALLEN WRENCH TO PUSH ON THE LOCK CYLINDER RETAINING PIN.RELEASE THE KEY TO THE RUN POSITION AND PULL THE STEERING COLUMN LOCK CYLINDER SET FROM THE MODULE ASSEMBLY.REMOVE THE UPPER SHROUD. THEN INSTALL THE UPPER SHROUD AND NEW LOCKCYLINDER WITH THE KEY INSTALLED TO THE LOCK CYLINDER AND TURN TO THE RUN POSITION MAKE SURE SECTOR IN THE LOCK MODULE IS ALSO IN THIS POSITION. INSTALL THE LOCK CYLINDER TO THE UPPER SHROUD THEN ALIGN THE LOCKING TAB AND POSITIONING TAB WUTH THE SLOTS IN THE LOCK MODULE ASSEMBLY WITH THE TABS ALIGNED CAREFULLY PUSH THE CYLINDER INTO POSITION. INSTALL THE UPPER SHROUD TORX HEAD RETAINING SCREWS AND TORQUE TO 12 INCH POUNDS. INSTALL THE LOWER SHROUD MAKING SURE THE SLOTS ON THE SHROUD ENGAGE WITH THE UPPER SHROUD TABS TILT THE LOWER SHROUD UPWARD AND SNAP THE SHROUDS TOGETHER. INSTALL 2 LOWER SHROUD PAN HEAD RETAINING SCREWS AND TORQUE TO 53 INCH LBS. MOVE THE SHIFT AND MULTIFUNCTION LEVER SEALS INTO POSITION THEN IF REMOVED INSTALL THE TILT LEVER BY ALIGNING AND PUSHING INWARD.POSITION THE SECURE THE STEERING COLUMN. PROPERLY ENABLE THE AIRBAGS SYSTEM BY RECONNECTING NEGATIVE BATTERY WAIT 5 MINUTES BEFORE STARTING VECHICLE AIRBAGS LIGHT WILL TURN OFF AFTER FEW SECONDS WHILE ENGINE RUNNING WHEN YOU FIRST START ENGINE.
Sep 15, 2011 | 1996 GMC Safari
Hammer not moving back
Do you mean with a load on it. or without? In other words, while the air hammer is pointed downward, if you put (example, the chisel tip) against a surface to be cut/hammered/etc., it doesn't work? Because, under normal circumstances, it won't work while pointed downward unless the chisel tip is actually against something. If it's doing that under load, though, have you checked the chisel you're using? If the shaft of the chisel is broken or marred, it may not be smoothly traveling the way it should. If it's okay, you likely have a broken piston inside.
Jun 05, 2010 | Chicago Pneumatic Chicagopneumatic Air...
Washer does not spin even though water fill and drain properly. Water level presure swith working properly. How do you cehck the capacitor and the motor to make there is power get to each part. Washer is a...
OK,
This could be something not related to the electronics. The motor has a coupling that connects the output shaft to the transmission. If you can, check below the washing machine using a flashlight. If there is black rubber dust below the machine, that bushing needs to be replaced. It is worn out...The part is about $20 to $25 depending on where you purchase it.
To replace the coupling, drain the washer, then unplug the power. Tilt it back, then remove the motor to inspect the coupling. You can easily replace the coupling by removing the motor. There are two metal retainers that can easily be snapped loose using a large screwdriver. Pull the motor away from the transmission housing, then remove the existing coupling and install the new coupling.
Once it is in place, clip the motor back in place, tilt the washing machine back down, plug it back in, and VOILA! You are in business!
Jul 27, 2009 | GE Washing Machines
96 chevy monte carlo 3.1 wont start
check to see if the wire is broken for the passlock/passkey system in the ignition lock cylinder, its common for the copper wire to seperate inside the insulation, when you tilt the column it could have been pushing the wires together enough to touch inside the insulation
Jun 18, 2009 | 1999 Chevrolet Monte Carlo
Agitator isnt working properly
Hi, You will need to replace the agitator dog kit inside the agitator.
Remove the cap of the agitator and then remove the inside cap. You will need a 7/16" socket with a long extension to reach the bolt that holds the agitator in place.
Pull the agitator out and seperate the top half from the bottom half. The dog kit # is 285770.
I hope this helps you. If I can assist you further, please let me know.
Vic
May 29, 2009 | Washing Machines
Thread bunching on model singer 2157C
According to everything I've researched, when this happens it's because there is no tension. Check & make sure it's threaded properly. If it's still bunching underneath, then there may be something wrong inside the machine - even though you adjust the tension, it may not really be happening inside. You'll have to take it apart or service it.
Aug 29, 2008 | Singer 2517 Mechanical Sewing Machine
Toyota Problem
You will need to replace the ignition lock cylinder, one of the pins that code the lock is stuck or broken. Have the new cylinder keyed to fit your original keys, the dealer or a local lock smith can do this for you.
Aug 25, 2008 | 1997 Toyota Camry
Braun kf 580 coffee maker
If the hot plate is tilted then it should be able to be pushed back down until it is completely level. If not then it is damaged. Check to see that it is screwed in properly underneath.
Apr 15, 2008 | Coffee Makers & Espresso Machines
Ripped door seal
It's usually not a good idea to wash single items in a front loader. This is because it can't properly balance the load. Either the item won't come out dry enough or if it does manage to spin the machine will shake violently until one of the shocks comes loose. When that happens the tub tilts down and to one side twisting the boot.
Jan 04, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
