Question about Pride Health & Beauty
Pride xl victory slipping drive in reverse ok forward graham
  • Pride Master
  • 10,291 Answers
Check the brake assembly to see if it is operating correctly
Posted on Sep 03, 2017
  • 32 Answers
SOURCE: no movement, forward or reverse
sounds like it is in neutral, look for a lever on the bottom, rear of the scooter to pull up
Posted on May 07, 2009
gewiz
  • 1271 Answers
SOURCE: goes in reverse but not forward
hi, that sounds like the scooter
a. the speed pot is faulty (Wig wam) thumb throttle , check just in case there a reverse switch,
b. been taking apart and reassembled incorrectly.
Regards
GeWiz.
Posted on Jul 24, 2009
  • 154 Answers
SOURCE: cub cadet 1863 trans/pump slips and whines in
sounds like the clutch not releasing all the way
Posted on Aug 05, 2009
gewiz
  • 1271 Answers
SOURCE: I have a pride victory scooter and at low speeds
that could be the speed pot , try moving the throttle lever upwards to see whether it stops shuttering, if not check the motor brushes.
Regards
GeWiz.
Posted on Oct 06, 2009
  • 692 Answers
SOURCE: 1997 PRIDE VICTORY GIVEN TO ME, BUT NEEDED FRESH
check the freewheel lever on th rear of the chair near the right rear wheel if you can push the scooter easily then you are in freewheel locate the lever and move it to the drive mode and try to drive the scooter again if it still won't move then you have other problems that can only be checked by a service tech Hope this helps
Posted on Feb 27, 2011
Pride Victory XL-4 Mobility Scooter
You can get then from Prides website
Apr 27, 2017 | Pride Health & Beauty
I have a Victory three electric scooter and it will not go forwards but does go in reverse just fine. Could you tell me what and how to check it to find the problem?
Hi , if the scooter goes into reverse okay , it could a be throttle issue , or the forward logic( mosfet out put ) of the PG Drives controller has failed...
I offer free testing if based you're in the UK...
Regards
www.gewizrepairs.co.uk
Jan 20, 2015 | Pride Mobility Products Pride Victory 10 -...
Pride mobility victory XL front tyre wear
Is your track rod bent or out of alignment? Carefully buy the exact wheels with tyres and a track rod if necessary from dismantled Victory XL scooters (a good wheel with a good tyre about €30 - I've done that for my Pride Celebrity XL8 - it was a great success.
Jun 03, 2014 | Pride New Mobility Victory XL 4 Wheel...
Scooter slow in reverse
The drives on most scooters are programmed to be slow in reverse for safety reasons.
Jan 17, 2012 | Pride New Mobility Victory XL 4 Wheel...
When i go forward or reverse i get a click the scooter does not move
Please check near the rear to ensure the the scooter is in gear. There should be a switch that needs to be moved up/down. Let me know if this is not the issue.
Good Luck!
Apr 14, 2011 | Pride New Mobility Victory XL 4 Wheel...
Could you please tell me where i will get forward& reverse throttle for pride victory
Throttle potentiometers are a frequent part that is replaced on scooters due to wear. This part is available from the manufacturer Pride or from a company called Monsterscooterparts.com.
At the Monsterscooterparts home page click on mobility scooter parts, pride scooters, pride parts click on Pride Victory XL SC270 , select throttle pot assembly. Verify SN and compatibility remarks. They have an 800 phone number for questions and they ship worldwide. The Pride part number is ELEASMB 1511 for Victory XL 4 wheel scooters after the year 2000. Looks like the price is about $80. Labor is about 1/2 hour and can be done by an experienced mechanic or do-it-yourself. The part is available from the manufacturer if you are a dealer or have an account.
First remove the throttle lever by loosening the allen set screws. Separate the front console covers by removing 8 or more screws holding it together. Locate the throttle pot, unplug it and install a new one. Be careful not to over-tighten or strip the screws holding the potentiometer housing tabs to the plastic. Check the alignment visually before reassembling it. Don't pinch any wiring when you put the console back together. When you reinstall the throttle lever make sure it is even left to right and does not bind on the plastic console housing. Tighten the lever set screws firmly but do not strip them, this repair will need to be done again and you want to be able to remove these set screws. Hope this helps.
Nov 07, 2010 | Pride New Mobility Victory XL 4 Wheel...
Scooter will just go in reverse and stay in after
Hello,you need to get someone to refit your forward reverse lever.im disabled myaself.please give me a thumbs rating 1 to 4.i do this as i care not for profit Colin.
Jul 31, 2010 | Pride New Mobility Victory XL 4 Wheel...
My scooter when I press the throttle to go forward it like breaks or stops. I have a Legend XL. It goes OK in reverse but, when you press to go forward it breaks like bad gas.
hi i hsave a pride legend classic mobility scooter it will run ok for a few yards then suddenly stop but if u wait for a bit it will go again whats the problem thanks
Mar 02, 2010 | Pride Legend XL Heavy-Duty 4 Wheel Scooter...
Goes in reverse but not forward
Regards
GeWiz.
Jul 03, 2009 | Pride Mobility Victory 3 Wheel Electric...
Health & Beauty Logo
41 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
