Question about Exercise & Fitness
Bought a Commercial 1500 NordickTrack treadmill. Worked when we tested it. After transporting it to our home, everything works except the motor won't kick in, so the belt doesn't move.
A warning states that the incline % needs to be at 0 before you fold the treadmill up or the treadmill could experience damage. I've researched and failed to discover what damage might occur.
  • 103 Answers
SOURCE: Just replaced the motor controller on my treadmill
You have one of three things wrong. Either a bad console, bad motor or a bad wiring harness.
If you have a flashing light on the controller when you attempt to start the machine then you more than likely have a bad motor. (this has a long warranty may be able to get one for free, check the back of your manual)
If there is no flashing light on the console then you will need to check the wire harness. This unit is known for pinching wires at the lower section where the upright connects to the lower frame. To check this you will need to remove the console. Three screws on each side and the wire harness on the right side will need to be unplugged. Then remove the right upright by removing the two bolt located on the bottom of the frame. Then do a visual inspection for pinched wires especially where the upright connects to the lower frame.
If the harness looks ok then you will more than likely have a bad console.
If you need parts you can go to http://www.iconservice.com/CustomerService/parts.do
Good Luck! Tim
Posted on Mar 28, 2010
ercupa190
  • 12223 Answers
SOURCE: Nordictrack COmmercial 1500 console buttons don't work
http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitnes
11_17_2011_8_43_24_pm.gifsincerely. Please keep me in touch.
Posted on Nov 17, 2011
StuartB
  • 807 Answers
SOURCE: my treadmill belt doesn't move at all
Contact the seller for help or send it back if it's only a month old, it must be under warranty.
Posted on Jan 25, 2012
ercupa190
  • 12223 Answers
SOURCE: incline and decline wont move, so the belt wont move either. Have a jazfit treadmill
1)LUBE THE DECK BELT, INMEDIATELY.
2) tES THE MOTOR INPUT VOLTAGE, IF THER ARE THE MOTOR NEED REPAIR.
3) tEST THE OUTPUT VOLTAGE BOARD, FOR INPUT VOLTAGE MOTOR, IF THERE ARE NOT THE BOARD IS FAULTY.
4) tRY TO RUN THE SOFTWARE CALIBRITATION.
SINCERELY.GOD BLESS YOU
Posted on May 08, 2012
ercupa190
  • 12223 Answers
SOURCE: Everything works except the Treadmill motor ? Incline works OK, belt doesn't turn at at all. Model EPIC View 550
1) You have problem with LUBE deck belt, this happen because the lack of maintenance, you must lube EVERY week, use 100% silicone lube. Maybe you have WORN deck belt,
2) LUBE the rollers bearing too, use wd-40
3) Test the drive belt motor, see for break, or worn, and replace or tension by 1/4"
4) Test the input voltage motor, if there are the motor need repair. see my personal TIPS for help and troubleshooting.
5) Test the output voltage board, for input voltage motor, if there are NOT the board controllers is faulty. God bless you. see the block diagram attached.
Posted on Nov 26, 2012
I have a proform crosswalk 400e, and the circuit breaker on the treadmill trips whenever I plug it in
Many motor may have two stages, the first starts it turning and then the second stage takes over to keep it running. The 2nd stage of the motor may be faulty and drawing two much current or leaking current to the earth. Your breaker may not be the correct rating for the machine and needs uprating.
Something could have slipped in or moved around that could be jamming the belt or something else in the machine preventing it from starting up and causing an overload that triggers the breaker.
Feb 15, 2015 | Proform Crosswalk 400e Treadmill Total...
I have a Nordic track commercial1500 and the belt motor will not run. Everything else works fine. The fuse is good on the board.
1) see if the belt is tight or loose, repair or replace the belt
2) test the input voltage motor, if there ARE the motor need repair see my personal TIPS for motor help
3) Test the output voltage board, for input voltage motor, if there are NOT the board is faulyt, replace see the b.diagram attached.
Jan 09, 2013 | Nordic Track NordicTrack Commercial 1500...
My Nordic track 1500 motor will not run, everything else still works????
Step 1:
1) test the input voltage motor,if there are the motor need repair,see the diagram attached, and see my personal TIPS for motor help
Step 2:
tes the output voltage board, for input voltage motor, if there are NOT the board is faulty, replace see the block d.
God bless you
Does a nordic track commercial 1500 have a fuse?
see my personal TIPS specially block diagram, if you will see the fuse for every treadmills.
2) Reset the c.breaker too.
3) Reset the c.breaker from your house outlet wall.
4) Test the power cord for wires, break, loose, or burn and repair.
5) Test the power switch, for open or shor. see the diagram attached.
sincerely. God bless you
May 08, 2012 | Nordic Track NordicTrack Commercial 1500...
How do I disassemble the Nordic Track t5 zi for transporting?
Please read you owner manual.
If you do not have please go to www.nordicktrack. com then customer service and then parts & manual, give you model, etc, and download free and read the section how to fold and viceversa.
sincerely
Dec 09, 2011 | Nordic Track NordicTrack T5 zi Treadmill
Nov 17, 2011 | Nordic Track NordicTrack Commercial 1500...
I have a Nordicktrack A2105. When I turn it on the belt runs real fast like a second then stops everything on the panel is working as if the belt is still working but its not. Can there be something...
there is an optic sensor on the top roller that drives the belt. if it has fell off the computer can not sense the rotation. you may have to remove the cover where the motor and top roller is and inspect that the sensor is in place and no dirt is obstructin the signal. good luck to you.
Feb 07, 2011 | Nordic Track NordicTrack Treadmill, A2550
My Nordictrack commercial 1500 is stuck at 12% incline and won't go nor up or down. How do i fix?
need to flip side and with a wrench 1 / 2 or 9 / 16 loosen the screw of motor base and try to press the down key and if so work you should Lift motor replacement
Sep 12, 2010 | Nordic Track NordicTrack Commercial 1500...
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
