Question about Cell Phones
Can call out but cannot receive calls - Cell Phones
How can I fix mu i phone 4s? just had it updated and now it will not receive or make calls.
If you can't make or receive calls on your iPhone - Apple ...
https://support.apple.com/en-us/HT204027
AppleJun 2, 2015 - You might not be able to make or receive calls on your iPhone if you have ... Cellular and turn off Enable LTE, 4G, or 3G (this option will depend ...
Troubleshooting FAQs ' Verizon Wireless
www.verizonwireless.com/support/troubleshooting-faqs/
Verizon WirelessI'm hearing a fast busy signal when I make a call. What's ... Why is my roaming indicator on when I'm not roaming? ... Why can I make calls but not receive calls?
My phone won't let me make or receive calls. ' T-Mobile Support
https://support.t-mobile.com/thread/93640?start=0...
T?Mobile US, Inc.Jun 19, 2015 - My phone won't let me make or receive calls. mlr0025 Jun ... I cansend and get texts from people, and I can sometimes make calls on Wifi, though I can'treceive them. ... I'm not roaming, I have 4G, and now I'm getting annoyed with it. ...Have you tried leaving the area and connecting to a different cell site? Full bars but cannot make or receive calls
Jun 10, 2014
Can't call or receive calls
Apr 23, 2014
calls not ringing/ going to voicemail
Feb 12, 2014
Suddenly can't make calls at work
Nov 8, 2013
More results from support.t-mobile.com
Feb 09, 2016 | Cell Phones
Paul_fall528
first you say you can make and receive calls, the you say you have no control . , perhaps if there is someone close to you they can show you what it does properly .
Dec 19, 2015 | Symbol Cell Phones
I can make calls but why can"t i receive calls on my vtech cs6649-2 phone?
Check out your manual for troubleshooting. Google the phone and model # with your question. I have a guess the ringer is turned OFF or wiring is not correct. Good luck.
Jan 14, 2018 | Vtech CS6649-2 Silver Cordless Phone DECT...
My LG Optimus will not receive incoming calls. Whenever someone tries to call my phone it goes directly to voice mail. I can still receive all other alerts such as sms, mms, and e mail but my voice calls...
My LG Optimus will not receive incoming calls. Whenever someone tries to call my phone it is showing missed call onlyl. I can still receive all other alerts such as sms, mms, and e mail but my voice calls are not coming through. What to do
Dec 17, 2010 | Computers & Internet
I can call out on my phone but incoming calls are not getting through.
When calls come through , receive and reject signs come up , press green to receive then nothing???
Sep 16, 2009 | Motorola Mobility RAZR V3
Machine tries to fax while on phone
Hi ...
There are situations when fax interrupts the telephone conversation. The possible cause of this issue is Remote RX feature on MP 780. There are 3 possible solutions to these problems which are listed below:
I) Change Remote RX ID on MP780
  1. Confirm the <Fax> button light is lit. If the light is not lit, press the <Fax> button.
  2. Press <Menu> button. [RECEIVE MODE] will appear on the display.
  3. Press < (left arrow) or > (right arrow) to select [RX SETTINGS].
  4. Press <OK>. [ECM RX] will appear.
  5. Press the < (left arrow) or > (right arrow) to select [REMOTE RX].
  6. Press <OK> twice. The current Remote RX ID number will appear.
  7. Press < or > to select the desired Remote RX ID number. The options are from 00 to 99.
  8. Alternatively, you can press the numeric keypad to select the number.
  9. For example, to select [38], press <3> and then press <8>.
  10. Press <OK>.
  11. Press <Stop/Reset> to return to standby mode (date and receive mode will appear).
II) Turn off Remote RX on MP780
  6. Press <OK>. The current Remote RX option [ON] will appear.
  7. Press < or > to select [OFF].
  8. Press <OK>.
  9. Press <Stop/Reset> to return to standby mode (date and receive mode will appear).
III) Choosing a receive mode MP780
If you want to receive only faxes automatically with your machine, or you have a dedicated telephone line for fax use only:
  • Select [FAX ONLY MODE].
    When you receive a fax call: The machine will receive the fax automatically.
    When you receive a voice call: You will not be able to answer the call.
If you receive mainly voice calls and sometimes faxes, or you want to receive faxes manually:
  • Select [MANUAL MODE].
    When you receive a fax call: The telephone will ring. Pick up the handset and if you hear a beep, press <Black> or <Color> on the machine to receive the fax.
    When you receive a voice call: The telephone will ring. Pick up the handset to answer the call.
    For remote receiving: If you are far from your machine, dial 25 (the remote receiving ID) on your telephone to receive faxes. (Telephone being used, such as a base station for a cordless phone, must be connected through the MP780 for the remote receiving function to work.)
If you want to receive voice messages on your answering machine and receive faxes automatically:
  • Select [ANS.MACHINE MODE].
    When you receive a fax call: First the answering machine connected to your MP780 will respond to an incoming call, and then the MP780 will receive faxes automatically.
    When you receive a voice call: The answering machine connected to your MP780 will respond to an incoming call.
If you want to receive faxes automatically as well as voice calls:
  • Select [FAX/TEL AUTO SW].
    When you receive a voice call: The machine will ring. Pick up the handset to answer the call.
If you have subscribed to a Distinctive Ring Pattern Detection (DRPD) Service with your telephone company (US only):
  • Select [DRPD].
    When you receive a fax call: The machine will ring according to the ring pattern you have chosen and receive the fax automatically.
    When you receive a voice call: The machine will ring according to the ring pattern you have chosen. Pick up the handset to answer the call.
Dont' forget to vote if this helps .... Cheers :)
Jul 17, 2009 | Canon PIXMA MP780 All-In-One InkJet...
How do i check received calls?
Press the send button. Sent, missed, and received calls show up. Received calls will appear in green.
Dec 29, 2008 | AT&T Blackberry Curve 8300 Smartphone
Canon MP530 receive fax issues
Receive Mode Settings Select from the following receive mode options to suit your needs. Once you've decided on which receive mode to use, follow the below instructions to set the receive mode using the operation panel. Receive Mode Setting
  1. Press the <FAX> button to enter Fax mode.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode settings], then press the <OK> button.
  4. Press the up or down arrow to select the receive mode that best suits your needs, then press <OK>.
Types of receive mode
Select the receive mode according to your needs.
Receive mode
Purpose
FAX/TEL AUTO SW When you want to receive faxes automatically as well as voice calls. FAX ONLY MODE When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only. DRPD When you have subscribed to a DRPD service with your telephone company. MANUAL MODE When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually. ANS.MACHINE MODE When you want to receive voice messages on your answering machine and receive faxes automatically. FAX/TEL auto switch
FAX :
The machine does not ring but will receive the fax automatically. Voice call :
The phone attached to the machine will ring. Pick up the handset to answer the call. Note:
  • Ring start timing and Telephone ring length can be specified in FAX/TEL auto switch in the Receive mode settings.
  • If you want the telephone to ring when it receives a fax, connect a telephone to your machine and enable the Incoming ring settings in RX settings.
  • The phone attached to the machine may not ring depending on the telephone type you are using.
FAX only
FAX * :
The telephone does not ring. The machine will receive the fax automatically. Voice call :
You will not be able to answer the call. * If you want the telephone to ring, connect the telephone to your machine and enable the Incoming ring settings in RX settings menu.
DRPD
FAX :
Your telephone line will ring according to the ring pattern you have chosen and receive the fax automatically. Voice call :
Your telephone line will ring according to the ring pattern you have chosen. Pick up the handset to answer the call. Note: Specify the FAX pattern in the DRPD: Set FAX ring pat. in RX settings menu.
Manual RX
FAX :
The telephone attached to the machine will ring. Pick up the handset and if you hear a beep tone, press the <Color> or <Black> button on the machine to receive the fax. Voice call :
The telephone attached to the machine will ring. Pick up the handset to answer the call. Note: If you are far from your machine, you can use the remote receiving function to receive faxes. Pick up the handset of the telephone connected to the machine and press 25 (the remote receiving ID).
Ans. machine connect
FAX :
First the answering machine connected to your machine will respond to an incoming call, and then the machine will receive faxes automatically. Voice call :
The answering machine connected to your machine will respond to an incoming call. Note:
  • Set the answering machine to answer on the first or second ring.
  • The entire message should be no longer than 15
Nov 24, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Missed calls
How do I view the numbers of calls made or received? space.gif space.gif answer.gif You can view the last ten calls that have been placed and the last ten calls which have been received in the Recent Calls option menu.
  • Press the Menu, Recent Calls and press the right soft key to select.
  • To view the calls you have received scroll to Received Calls and press the right soft key to select.
  • To view the calls which have been placed, scroll to Dialed Calls and press the right soft key to select.
  • Once in the Received or Dialed calls you can get more information such as the time the phone call was received/dialed by highlighting the call you want to view, and press the right soft key to view.
  • Scroll down to view all the available information.
In order to delete a received, or dialed call simply highlight the call you want to delete, press Menu and then select Delete. You can delete all the calls in the chosen section by selecting Delete All instead of just delete.
Mar 13, 2008 | Motorola Mobility RAZR V3
Lg ax355 cell phone not receiving incoming calls
Have you tried rebooting the phone as I experienced a similar issue
Oct 20, 2007 | Nokia 1100
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
