Question about Garden
What would make my New Holland BR7060 keep tying bales and not stop?
5 Suggested Answers
jcglessner61
  • 3 Answers
SOURCE: string tensioner and knotter on new holland baler 319
I would say first check the twine tensioners where the twine comes out of the box it's held in. They are simple spring loaded slip tensioners, make sure both have the same tension. From there check all the twine passages for rust or servos
Posted on Jul 09, 2012
  • 3506 Answers
SOURCE: how do I fix a new holland 575 baler hydrick leak on bale chamber
You will likely have to take it off, take it apart and reseal it and if you cannot do this have someone who can do it rebuild it for you and then you can re-install it,
Posted on Dec 11, 2014
  • 48482 Answers
SOURCE: Bale tying
then you need to work on the knotter mechanism or replace it .
Posted on Oct 16, 2015
  • 48482 Answers
SOURCE: Twine tying problem on john Deere baler loose string toward left side of hay bale leaving a hump about 15-18 wide
then you should have called the dealer when it was still new .
Posted on Dec 12, 2015
Where can I find the serial number on a New Holland 1032 bale wagon
It should be on the engine. or the inside. body frame.
Oct 03, 2017 | Garden
New Holland 72 bale thrower will not increase or decrease speed on belts.
From what I've discovered there's a lot of issues a hand---I found a site that has different issues with model---variety of various items contribute to the same problem----you'll have to find you particular issue--there a list of items that may apply to you situation that you'll have to check out---GL
https://www.google.com/search?q=New+Holland+72+bale+thrower&rlz=1C1NHXL_enUS713US714&oq=New+Holland+72+bale+thrower&aqs=chrome..69i57j0l3.2071j0j9&sourceid=chrome&ie=UTF-8#q=control+speed+of+belt+New+Holland+72+bale+thrower
Jul 05, 2017 | Cars & Trucks
How do I fix a new holland 575 baler hydrick leak on bale chamber
Dec 11, 2014 | Garden
Parts on new holland 7050 New Holland round bale
go on the net to new Holland and see if there is a pdf download of the parts book.
Aug 17, 2014 | Cars & Trucks
New holland tractor problems
Check for badly worn chain allowing the mesh to get out of sync. Check that the chain is correctly adjusted as if it is too tight then variances in cog diameters overloads the chain and it will break. Check for correct cog alignment and check for bearing condition of the roller
Aug 12, 2014 | Cars & Trucks
String tensioner and knotter on new holland baler 319
Jul 09, 2012 | Garden
The shear pins on the rake keep breaking on a 853 NEW HOLLAND ROUND BALER. What is ?
Do you mean the driveline protection shear pin (pickup, roll the bale and wrap it) or the overfill protection shear pin?
For the driveline shear pin, check the type of pickup that you have. Make sure that you have the correct shear pin for the pickup (wide or regular). Also check the year of your baler, there are substitute shear bolts available that do not work on a range of the 853 baler. New Holland has a parts list for the baler on their site. Start at http://partstore.agriculture.newholland.com/us/ and use the Look up parts by equipment on the left of the page or see your manual. Next check the air bag pressure. (Make sure that you are in the operating range with a regular pressure gauge. It's possible for the gauge on the baler to read low.) If the pressure is out of the operating range, the roller bars can hit other parts of the baler and cause the shear pin to break.
If your baler uses net wrap, make sure that the wrap isn't caught in the unit. (If the knife doesn't cut the net wrap, it will get caught in the tailgate and the rest of the baler. If it tears in use, it may wrap around the pickup and cause the shear pin to break.) This may apply to twine as well but I do not have experience with it happening with the twine tied 853 baler.)
For the rest of the checks, you will have to remove any bale that is in the baler. If it is large enough it may roll out even if it isn't wrapped when the tailgate is up (try driving up hill). Otherwise, you need to pull, cut or pry the bale out. Standing on the kicker can help the bale roll out if sufficient weight is added. We've found that a spare bale spear works well. Removing the hay in small sections can also work.
What is the moisture of the bale? If the bale is too wet, it will be too heavy and shear the pin before the bale chamber is full.
Next check all of the roller bars in the unit. If any are bent significantly, that one can hit another part of the baler and break the shear pin. It's possible to straighten some of the bars out depending on the damage. If the bar is S-shaped or severely bent, replace it. (Your New Holland parts store may have someone who will demonstrate the technique for bar straightening. It involves hammering the bar straight when it is securely held in a vise. If you can hold the bar safely, I've also seen a bucket on a front-loader straighten the bars.) If a rock gets past the windrow guard, the bars can get bent.
Check that the chains are centered and that none of the gears are shifted to narrow or wider paths in a spot. (There are bars that can be adjusted between two sets of gears near the top front of the baler. Loosen the four bolts and push the parts closer or pull them farther apart.) Check that none of the bearings for the apron motion are frozen or damaged. Replace or repair anything that is damaged.
Do not make the bales too large or uneven. (If you have a Bale Command unit on the baler, it is easier to control the even formation of the bale.)
For the overfill protection, make sure to reset the unit after replacing the shear pin. It can be tough to pull the trip arm fully back. Make sure that nothing is in the tailgate. If your baler has a kicker, make sure that that the two springs on the sides are undamaged and holding the kicker level.
I hope this helps.
(my 853 baler with the wide pickup uses Driveline shear pin 46520 and Overfill shear pin 46047. I'm not sure of the year of the unit. When we got shear pins with a different number, we broke 3 or 4 in a row before realizing that we'd gotten the wrong ones; they were noticably thinner than the required ones. Roller bars are what I call the bars between the chains and we've replaced/straightened many of them.)
Aug 09, 2011 | Computers & Internet
Garden Logo
43 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
