Cd player want play model# cd 74
Spins an then stop
The Marv
  • 72 Answers
SOURCE: CD Player Not Working
You could take the unit apart and clean the lens with some rubbing alcohol. Or thy running a lens cleaner through it. But most likely the problem is a bad lens assembly and if this was not an expensive unit it is time to replace. But only disassemble if you know what you are doing.
Posted on Jan 05, 2007
  • 65 Answers
SOURCE: cd player not working
first try play Lens Cleaner CD, if you are lucky ,it's done!!
Posted on Sep 17, 2007
SOURCE: CD player stopped readiing disc.
Same here. The open/close CD door button doesn't work either. Did you ever get this resolved? -pokie
Posted on May 08, 2008
SOURCE: Bose Wave Radio w/single CD player on top
My Bose Wave Radio/CD developed this problem about a year ago. I don't use the CD player much and kept the unit clean. The disc spins but, the system does not read it. Cleaning the lens with cotton did not help.
Read that Bose charges $75 to fix this problem.
Posted on Sep 24, 2008
  • 6 Answers
SOURCE: cd player
It may not be reading right because it might be a re-writeable disc. If this is not the case try returning it do to malfunction and if all else fails my friend try buying a new one. By the way if it has a 1.8mm input you can use an external cd player and use the stereo for the speakers. I hope that helps and if you need anything else answered let me know.
Posted on Jun 22, 2009
Why did CD model-1493 player stopped working;since all other functions work fine?
It spins out of control when it can't read the disc.
Dirty or faulty laser
Sep 15, 2014 | Audio Players & Recorders
Why does my CD player say no disc?
IS IT A RECORED ONE, OR STORE BOUGHT, SOME HOME MADE ONES WILL NOT WORK.
Jul 07, 2014 | Audio Players & Recorders
I have a Sony Psyc CD Walkman D-Ej010 and I will have a cd in there at it will play for a few minutes and then stop and say no-disc. What could be the problem?
There may be a couple of reasons why a NO DISC , DISC ERROR or INSERT DISC error may appear in the display of your CD player. Try doing the following steps to troubleshoot why the error is displayed:
  • For disc players with a HOLD switch, make sure to move the switch to the OFF position.
  • Verify that the disc being used is supported by the CD player. NOTE: CD players do not support VCD or DVD discs. In addition, some CD players do not support CD-R or CD-RW discs that are created by a CD burner. For information regarding disc compatibility with your player, refer to the operating instructions supplied with the product
  • Ensure a disc has been inserted into the player. Make sure that the disc is inserted correctly, with the playback side of the disc facing down on the disc tray.
  • If the disc still does not play, attempt to play a different, commercially-produced disc.
  • NOTE: If more than one of the commercially-produced discs do not play, verify whether the discs are extended-length discs. Some players are not able to play discs where the recording exceeds the standard 74 minutes. If the recording of the disc is longer than 74 minutes, it is possible that some of the specifications of that disc were compromised and therefore, the CD player will not recognize that disc.
  • If the disc is dirty with fingerprints or smudges, or if the disc is scratched or broken, the CD player may not recognize the disc.Clean the disc using a soft, dry cloth.
  • Properly reinsert the disc into the player.
  • Attempt to play the disc again.
  • Only press the PLAY button once. If the PLAY button is pressed more than once, the disc may stop playing.
  • If the disc is still not recognized, remove the disc and leave the CD player powered on for approximately one hour to resolve the possibility of moisture condensation inside the player.
  • Please use a Lens Cleaning disc and check if that helps.
If the issue persists, please click hear to locate the repair facility near your area.
Thanks for understanding. Please let me know if you require any clarifications.
Jan 29, 2010 | Sony Walkman D-EJ010PS Personal CD Player
Cd player doesn't play.
If you are using a pirated cd or self compiled cd, chances they don't play. try the original cds
Jun 26, 2009 | GE 74801 DUAL ALARM CLOCK RADIO .9" LCD
My Sony cd player spins but won't play. Cleaned
Those CD cleaners rarely work. They are nothing but small brushes on a plastic CD. Unless the problem is loose dust, they won't work. Try carefully opening up the unit and cleaning the lens using a cotton swab and alcohol. If that does not resolve the problem, post the model number and I'll provide the replacement optics part number and cost. Some units have replacement optics that cost less than $15. Dan
Jun 15, 2009 | NAD L40 CD Player
CD player does not play discs
Laser has died ,problem with pioneer is laser costs are ridiculous and write the machine off
Jan 01, 2009 | Audio Players & Recorders
TOC READ
I have the same problem... Any solutions?
Sep 21, 2008 | Emerson MS3100 3-Disc CD Changer
Cd player not working
Sep 07, 2007 | Aiwa CSD-ED27 Boombox
Check disc
Change your DVD player
May 23, 2007 | LG DE9523P DVD Player
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
