Jumper settings for HDD HD642JJ to function as slave
  • 375 Answers
Hi Guenther - check the chat dialogue for the solution to your disk problem
Posted on Jul 25, 2009
Slave setting
Sata doesn't use the jumpers like ide drives make sure the two drives are the same type. both ide or both sata.
Terry
May 28, 2012 | Samsung Hd642jj 640gb Hard Drive Internal...
Trying to make my seagate barracuda 7200.9 slave
1) Open your computer case
2) On the back of the drive where the connectors are, you have jumpers. These small plastic tabs change the function of your hard drive. All hard drives have a special setup procedure. The information about jumper settings is on the top of the hard drive.
3) Remove plastic tabs and put them according to "Slave" instructions.
4) Connect drive to middle connector of the cord.
5) Connect power supply cord.
6) Secure the drive in place and close computer case.
Also make sure that the main drive is not set as slave.
Apr 10, 2011 | Seagate Barracuda 7200.9 80 GB Hard Drive
Slave Harddrive I have an extra harddrive that I wish to install as a slave, unfortunately I cannot at the moment, due to some problems. First, the current harddrive I have is a Maxtor I believe, and it...
Dear soviet guy
these are the jumper settting for both the drives
please check that they are on the right place before if you want to use seagate as a slave try placing the jumpers as mentioned.
Maxtor Jumper Settings
Seagate Jumper Settings
Thanks
GAGAN GUPTA
Mar 17, 2011 | Microsoft Windows XP Professional SP3 Full...
How do i set the jumper when installing diamond max plus 9 80gb as a 2nd disk what does cs enabled mean thank you
CS means Cable Select .Parallel data cable have two conectors.If you set jumper set on CS ,in this way ,example,you have two HDD when you plug parallel data cable in middle connector ,1 Hard drive working like Master ,2 HDD work like slave,if you plug in last connector First HDD working like slave,second HDD Master.
http://www.tacktech.com/display.cfm?ttid=379
Aug 04, 2010 | Maxtor Hard Drive
How to set master, slave settings in sata hdd
In first HDD put the jumper in first vertical pair of pins from power socket side, it will become master and second HDD put jumper in second vertical pair of pins from power socket side it will become slave.
Regards
Ashly
Feb 02, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Jumper settings for a maxtor N256 master with slave
Select the maxtor HDD as master by setting the Jumper to the extreme left of the hdd; i.e. next to the data cable.
Remove all jumpers from the other HDD which you want to put as slave.
Sep 02, 2009 | Maxtor DiamondMax 80 (96147H6) 61.4 GB...
Setint the jamper as a 2nd drive and Do i need to farmat it frist
If I recall right this HDD is a PATA (IDE) type. As for the Jumpers please check the following link. The jumper should be as Slave drive.
http://www.helpwithpcs.com/upgrading/install-hard-drive.htm
May 15, 2009 | Quantum Fireball Lct20 (QML20000LD-A) 20...
Western Digital 80gb HDD Fails when installing OS
Try changing the jumper settings to make it the Master instead of the slave drive
Mar 23, 2009 | E-Machines eMachines Desktop PC
JUMPER SETTING
to make a HDD as slave, put off the jumper out.
for any question ask me.
Thanks for your question.
Aug 31, 2008 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Set ol comp to slave setting
hello
please refer to the jumper setting label at your harddrive. your new HDD am sure that is set to Master.
label in hard drive -
M- master
CS -cable select
S- Slave
select and see the S label position of the jumper.
melnavz
Apr 08, 2008 | Dell Dimension 2400 PC Desktop
683 people viewed this question
k24674
jasbo
jasbo
