Question about Garden
I purchased a used res med s9 vpap s machine and need to reset to my prescription pressures of 12 inhale and 8 exhale. Can I do this myself
2 Suggested Answers
  • 47720 Answers
SOURCE: What couses quantum vvti to misfire and inhale instead of exhaling with exhaust?
timing of course .
Posted on Sep 12, 2017
When wil i get my medication
Your medicine? Was it a prescription that your doctor wrote and you had to physically take it to the pharmacist yourself or did your doctor say the prescription would be faxed or called in? Most doctors are faxing prescription in to whatever pharmacist you told him or her that you use. If that's the case, you need to call your pharmacist and give them your name and sometimes your date of birth, to have them check to see if your prescription has been received and if they have filled it. Some pharmacies actually deliver customers meds to them, not all pharmacies offer this service. I hope this helped.
Mar 23, 2015 | Health & Beauty
THE MED,S TO USE FOR ASHMA AND BAD COUGHING
There are other conditions to be checked out. See a doctor, as these meds nearly always need a prescription to obtain.
Oct 24, 2013 | Computers & Internet
What does the Sobesmoke Electric Cigarette cartridge containing?
The Sobesmoke Electric Cigarette is complete up of which can be sealed unit containing solute nicotine. Every time a inhaler inhale, a small battery power run spray becomes a minute small piece of liquid nicotine straightly into vapor. Inhale and exhale cigarette smoking exhaust provides user any nicotine reach throughout just a few seconds in lieu of units jointly with spots , periodontal. If the person hales, a small heading for light in the idea from the Electric digital smoke glows lemon for you to duplicate an actual e cigarette.
Oct 18, 2012 | Office Equipment & Supplies
Hi there, I just purchased a Jura S9 One Touch. I've used it for a week, maybe making 10 coffees/day. Just yesterday an ERROR 6 message popped up. I don't know what to do, please help?
Hi, Error 6. Haven't come accross that one before. It sounds like brew unit problem.I do know error 7&8 are brew unit problems and 1 to 5 are water flow and heating errors. Try turning off the machine at the main power button and unplug it from the wall for a few minutes. This will reset the machine and right it self. They can do this from time to time. Dazza
Sep 23, 2011 | Jura Capresso Impressa S9 Coffee...
Does not dry cloths. dryer gets hot,top and sides during drying cycle. it takes 2-3hrs to get cloths dry.
most probable cause of heating yet not drying in a crushed or restricted vent (imagine only inhaling while breathing yet not never exhaling)
Jul 22, 2011 | Kenmore Washing Machines
I have a Karcher 3.49M purchased 8/2/09. Using the washer I inadvertently turned on after changing hoses, but forgot to turn water back on; this activation lasted only a couple of minutes before I realized...
Normally when you dry run a machine you damage the pump so it would probably need changing. The motor might be Ok but for you to fix it you will need to take it to a Karcher dealer/service center.
From experiance it sometimes can be more cost efficient to purchase a new Karcher machine and get the 12 month warranty than spending money on an older machine.
Jan 19, 2011 | Karcher PSI Electric Pressure Washer
Bogs down?
Try turning the "H" needle CCW a little. Cleaning the muffler and spark arrestor is a good idea too (if it cannot exhale it cannot inhale).
I do not think you need this but something to save for later.
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
  • CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
  • Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
  • Clean the spark arrestor and muffler; if the saw cannot exhale it cannot inhale.
  • There are 2 wav (sound - idle & full - may not be highlighted) files that I find most helpful, I think you will too.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 08, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
I messed the carb adjustment up need to start over readjust it whats the starting point
I would start with both the "H" and "L" needle valves at 1.0 turns CCW from lightly seated then adjust for performance as follows:
  • Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run. If the saw cannot exhale it cannot inhale.
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification)
15 = week produced – March
00198 = 198th unit Husky produced that week
Lou
Mar 09, 2010 | Husqvarna Forest & Garden No.967012396 345...
Safe second?
"The second stage regulator takes the manageable pressure coming from the 1st stage through the hose and delivers it to your mouthpiece in a way that is comfortable to breathe. Where the 1st stage is only concerned with letting air flow into the hose the 2nd stage has more complex machinery which handles both inhaling and exhaling through the same mouthpiece. Like the first stage the 2nd stage scuba regulator uses a diaphragm or piston to open a valve. Breathing in from the mouthpiece reduces the air pressure inside the chamber, water pressure pushes the diaphragm in, which opens the intake valve. When you stop inhaling the pressure in the chamber balances and the valve closes. The result is an air delivery system which supplies air only when you are inhaling and does not leak air constantly through the mouthpiece. A well balanced and well-maintained scuba regulator does its job so well that breathing feels natural and effortless despite the all mechanics involved. The second stage scuba regulator also has a purge or exhaust valve, which lets your exhaled air out of the chamber, but doesn't let water in. When you exhale into the second stage scuba regulator the pressure inside the chamber becomes greater than the ambient pressure. The exhaust valve is a simple one-way valve which lets this air escape. The second stage scuba regulator also has a purge or exhaust valve, which lets your exhaled air out of the chamber, but doesn't let water in. When you exhale into the second stage scuba regulator the pressure inside the chamber becomes greater than the ambient pressure. The exhaust valve is a simple one-way valve which lets this air escape. A second stage scuba regulator also has an ""emergency"" or ""purge"" button which forces the intake valve to open. When the purge button is pressed air will flow continuously into the chamber and escape either through the mouthpiece or the aforementioned exhaust valve"
Dec 01, 2008 | Aeris A1 Octo
Garden Logo
23 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
