I was using 2 burners and the breakers flipped off. When I turned them back on F9 came on and oven and clock don't work now
SOURCE: Stove/oven gets hot then shuts off
Shut the breaker off! These are the exact symptoms that a tenant of ours reported for their range. I went to check the range and found that one of the power wires on the terminal block in the back of the range was burning itself up. It had actually started a small wire fire. You need to pull the range out of it's hole and unplug it. Remove the panel in the back above where the cable goes into the range. Examine the power wires and terminal block carefully, because I bet you'll find one of the wires is burning up and needs to be repaired. Please write back and let know what you find.
SOURCE: oven sparking problem
i think you will find the power cord is burned this happens if it wasnt tightend up properly and gets loose turn the oven breaker off before you pull it out
SOURCE: range control panel
Hello maud2,
Not sure if this will help, but here are the user manuals in pdf format for your cooking range (not sure which version you have):
Classic 110 All Electric Ceramic
Classic 110 Gas
If your clock is totally melted, then as my friends above have suggested, it is best you contact Rangemaster or a competent local serviceman and have them replace the timer panel. This will prove to be in your best interest, after all.
Wishing you all the best and good luck,
IrishDruid
SOURCE: frigidaire electric range oven and top burners wont come on
It sounds like you only have one side of the 220v current coming into the range. I suggest checking the outlet feeding the range for proper power. The problem could actually be in your circuit breaker, only sending power via one of the conductors.
SOURCE: Does GE Spectra JBP68 have a fuse? Only 1/2 of range is working.
Your GE Spectra does NOT have a fuse, but it has a electronic control board, as well as elements. If both your elements heat up at all, then they are good. If you will contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service we can discus the issues with your range and I will attempt to get you back up and running again soon.
You may contact us from 7 AM until 9 PM CST Monday through Saturday for appliance assistance and parts.
We look forward to working with you.
Hello - I understand that the range has no display and experiencing issues with the burners not working. Please try resetting the unit by either unplugging it or flipping the breaker off. Wait approximately ten minutes and turn the unit back on. Try setting the time and if it proves to be ineffective, the unit may possibly have a faulty EOC, defective wiring harness, or damaged cord. I would suggest contacting a professional to move forward accurately.
