Question about HP Computers & Internet
Hp pavilion laptop beats saudio not switched on.On pressing on/off switched led flicker 3times nothing happen?Plese advised
  • HP Master
  • 2,251 Answers
No pc stated, it has a model, like DV6-12345
full names only work.
no OS stated, HP has laptops from 1982 to now.
what OS, operating system is this.
XP, Vista, W7 to 10? what?
Posted on May 09, 2017
melnavz
  • 1226 Answers
SOURCE: LAPTOP HP PAVILION DV2000 problem
Hello!
That beeps indicated that there is a problem in the video Graphics adapter and in the memory.
try remove and clean the memory and then fix it back, im sure that would resolve your problems. however if this not solve then your should replace the memory.
If affraid to do so, then maybe let the repairman do it for you.
fixya!
best regards, melnavz
Posted on Feb 29, 2008
SOURCE: Fn+F4 on HP laptop does not toggle
s video is output for the tv and its not controlled whith those buttons that you have to configure in the graphics drivers, but usualy the s video on hp and compaq laptops quit working but you have to configure them in the graphics driver
Posted on Jan 02, 2009
CosmaP
  • 409 Answers
SOURCE: HP Pavilion dv7-1240us does not restart
Press and hold the power key. It should shut down (or just pull the power).
Restart the PC and do not press the escape key
Posted on Jul 24, 2009
  • 1584 Answers
SOURCE: HP Compaq nc6220 Laptop is dead. no lights,
Is this the same if the charger is also plugged in??
Remove battery and retry with charger plugged in.
If same battery charger is faulty.
Posted on Dec 22, 2009
budmrtn
  • 11361 Answers
SOURCE: HP Pavilion f1703 Monitor flickers on & off
Clean and resolder all four round inductors, check the caps, replace them if they have bulging tops (even slightly bulg). Check the transistors (c5707) for shorts. See pictures here: http://s807.photobucket.com/albums/yy352/budm/HP%20F1703/
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 25, 2010
HP Pavilion dv6 7040 TX Laptop screen on right hand upper corner turns dim and after some time becomes uniform
Being a led screen maybe one or more of them have gone bad
Or if you are lucky just a faulty lcd ribbon cable
Mar 25, 2014 | Computers & Internet
Hello guys. I need help with my hp dv4 1225dx pavilion. It all started with not powering with battery power. But the battery is in perfect condition. When I plug in the power cord. It comes on and I...
It sounds like a hardware issue, if you're getting the LED's blinking when pressing power, there IS power to your mainboard (which is a good thing). Some manufacturers have placed LED blink codes within the system to let you know what's going on, but I have a feeling it's either A) your battery or B) your hardware, such as a bad RAM stick.
Try removing the battery and with the power plug connected switch the laptop on. If it works, you've got a bad battery.
Try removing a single RAM stick or replacing both.
You could search HP Pavilion LED blink codes to further address the issue.
Jul 18, 2012 | Computers & Internet
My hp pavillion dv6700 will not power up all of the blue lights will flicker as i press the power button for a few seconds then it will power off. ive tried taking the battery out and running it strictly...
Your DC jack may be loose or broken off the system board.
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it's still under warranty, it would be fixed at no charge to you.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Jan 19, 2011 | HP Pavilion dv6000z Notebook
My HP dv4 1120us laptop will not power on. When I insert the power cord the led for power bolt comes on and when I press the power button the power LED flashes once and then nothing happens. The power bolt...
Sounds light a power switch short, but lets try to take the memory out of the laptop and power on the laptop. Does it boot up? if so lets try 1 memory stick at a time.
Nov 29, 2010 | HP Pavilion dv4-1120us Notebook
I have a HP Pavilion dv4-1220us Laptop and the screen flickers at the bottom. A 1/8" white line will appear at the bottom of the screen-this happens after about 1/2 hour of starting it up. Later the...
Usually this means u have a damaged led panel or panel ribbon connector try a new LED screen first try ordering from Amazon get the numbers off the back of the screen
Jan 17, 2018 | HP Pavilion dv4000 Notebook
When I start the laptop or when the screen is
If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN ... Power LED and battery charge LED start flickering when you wiggle the power .... HP Pavilion dv7-4080us 17.3-inch Desktop Replacement Laptop PC ... High-Capacity Battery For Hp Pavilion Zd8000 Series Laptops ...
www.articlesbase.com › ComputersLaptops
Jul 19, 2010 | HP Pavilion zd8000 Notebook
System diagnostics says needs battery calibration
battery calibration is nothing but it the process to discharge the battery fully.
discharge the battery fully till the system gets off automatically, then only recharge the battery for 100%. make this process for 3times continously
Dec 24, 2009 | HP Pavilion dv1000 Notebook
Hallo. The screen of My laptop HP pavilion dv 2000 is
on the boot sector when you switch on youe computer, please press delete or f8 repeatedly. if there is nothing showing on your screen., then you should know that the is a problem with youe laptop scree.
i advise you to go and see a computer sepcialist to check if it is your hardware that has a problem.
thank you,
wonder
Sep 18, 2009 | HP Pavilion dv2000t Notebook
HP dv600 Screen Flickering
Change your screen refresh rate and update the video drivers.
Aug 27, 2009 | HP Pavilion dv6000z Notebook
HP Pavilion zd8000 don't startup
have you even try to remove the battery in your laptop?
if not try to remove it in a miniute then put it back again.
maybe it is in standby mode.
Jan 23, 2009 | HP Pavilion zd8000 Notebook
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
