Question about The Health & Beauty
I got the massage " General Alarm", I have cleaned the appliance but did not solve problem?
My fridge is about 2yrs old I need to know how to turn of the alarm when the door is open. When I am cleaning it. I cleaned it two days ago and now it is making a terrible noise.
The alarm tells you that something's wrong something's not cooling properly or something's wrong with the defrost system if you left your doors open for quite a while it will create ice around the fan blades and that could be your noise problem. d
Disconnecting the power to your refrigerator opening the doors for about 12 hours and let it manually defrost will usually solve the problem.
Appliance 911 Sea Breeze
Jul 24, 2016 | Fisher and Paykel Refrigerators
Can I use an electric massage chair when I'm pregnant?
It should not be a problem to use an electric massage chair whenyou're pregnant. In fact, it's a greatway to relieve all that stress.
May 29, 2012 | Furniture
I have a Cobra 1500W power inverter. The alarm is going off when the inverter is shut off. I drive a truck and have unplugged all appliances from the inverter and the alarm is still going off. What
I can only give some general thoughts on this, I have patched up a few inverters.
Their core parts rely on a component called capacitors these over time degrade with heat which reduces their manufactured value this will mean they fail to fully do their job. The usual result is not providing a smooth supply rail allowing voltage spikes which trip over and under voltage sensing firing off the alarm, more so when not loaded with appliances as spikes can become large.
Your appliances would be snubbing out these through their loading but this can be trouble because they are absorbing this extra energy which may damage them eventually.
This situation will possibly get worse with the inverter failing, it will need a service engineer to work on it or to purchase a new one if there is no local regional repair place.
Look up faulty capacitors in power supplies on the web for an insight.
Hope this helps........
Oct 23, 2017 | Watts Cobra Cpi1575 1500w 1500 Watt Power...
Screen Alert: General Alarm What does this mean
General alarm means the machine has detected a serious fault. There is a section in the instruction manual that may help. If not, read on.
Persistent "General Alarm"
This means many things. If the transmission is not stuck, check the main boiler has not burnt out (open circuit). This happens when the thermoblock labyrinth runs dry and overheats, a common problem caused by leaks, limescale, milk blockages or water filter contamination. Replacing the boiler is the only fix, a difficult and expensive process, experienced fixers (or nothing to lose) only.
Transmission
If the transmission is getting stuck there may be obstructions, the lead screw may be worn or the limit switches could be faulty. If cleaning and grease on the screw/bearings don't help then replacement is a tricky job only for confident hands. Approach with caution.
Aug 25, 2011 | DeLonghi Magnifica 3300 Espresso Machine
There is a General Alarm alert and after cleaning, the message still stay.
sounds like pcb assy fault... or check u have all parts in correctly ie tray ,bucket ect. bsc appliances 07779933829 postal service too .
Jan 31, 2011 | DeLonghi EAM3400 Espresso Machine
Eam3500 delonghi coffe machine
From page 21 of the owner's manual: Message: general alarm. Meaning: The inside of the appliance is very dirty. What to do: Clean the inside of the appliance thoroughly, as described in section 15. If the message is still displayed after cleaning, contact a service center.
Hope that all your machine needs is a thorough cleaning; it's not that difficult.
May 29, 2010 | DeLonghi EAM3500 Espresso Machine/Coffee...
Processor fan failure massage.
I supose the fan works, you then need to enter bios and disable cpu fan monitoring, if the fan doesnt spin connect it to another fan connector or a plain 4pin molex connector / might require a adapter.
Try to get into bios and disable cpu fan fail alarm, keep the temperature alarm on 80 or 70. so it will yell if it gets too hot.
Apr 17, 2008 | Intel Motherboard
Health & Beauty Logo
Top The Health & Beauty Experts
Donald Pera Deane
Donald Pera Deane
Are you a The Health and Beauty Expert? Answer questions, earn points and help others
