Question about Amtrol Water Heaters
Bubbles in hot water then clears
I have an Amtrol WH7L7P tank and water has a lot of air bubbles in line when first started
freetek
  • 5568 Answers
SOURCE: not enough hot water. I have an Amtrol Extrol coil water heater
Since you mentioned 'both temperatures' it seems your unit is like most all of them, a lower and upper coil.
If your hot water supply runs out quickly, this normally means that the lower coil has failed. Since heat rises, the upper coil will never supply a tankful of hot water, just hot to start, and then as the flow continues, it doesn't have time to do more than warm the water flowing into the tank.
Every home should now own a simple digital multimeter; they cost less than $20 US everywhere and one can find them in auto parts stores, electronic supply companies and tool companies.
If you have a Harbor Freight tool store in your area, you can get them for under $10 US any time and sometimes even less:
Digital meter
You need to be absolutely certain that the voltage to the water heater is shut down. Before you measure anything else, set the meter to its highest AC setting and check across the coils and then from either contact to the metal housing. If it is dead everywhere, then set the meter to the lowest Ohms scale (normally 200). The resistance of the coil should be nearly the same reading as when you simply short the meter's probe tips together. If it measures 'OL' then the coil is open and must be replaced.
Posted on Feb 26, 2009
  • 252 Answers
SOURCE: air in hot water lines only after installing
Does you system have an auto air vent - has a cap like tire valve. cap should be left loose.
Posted on Mar 14, 2009
SOURCE: No hot water from the Amtrol Boiler Mate model
The smart control was only reading 140 it never went up or down from that number and now it has an ER3 code seem the circulator just runs and runs
Posted on Feb 14, 2010
SOURCE: amtrol water heater WH-7P gets barely warm water
I had the same problem. I had a steam boiler and the water level in the glass gauge was below the top of the coil of the tank. remember water finds its own level, so it settled at the glass gauge level, therefore air got in coil.
to resolve problem : turned on manual water feed to boiler to raise water level. as water level got higher, let out water in hosecock between boiler and amtrol. amtrol noticed hot water reduction, circulator clicked on, boiler kicked on, turned off hosecock, turned off manual feed. I effectively bleed water out of line by running water out of amtrol as water feed in boiler increased water level above coil.
took a while to figure this out, so if this is the problem, dont feel to bad. keep water level of steam boiler high.
Posted on May 12, 2010
  • 10865 Answers
SOURCE: no hot water have amtrol boilermate
There is a device on the boilermate called an aquastat which controls the flow of hot water into it. Replace that and you should be up and running again. Joe.
Posted on May 23, 2010
Why when I turn the hot taps on I get milky water out of the hot taps and its a new HWS Vulcan 250 lit electric single element only 3 months old
Put that water in a glass and let it sit for a couple of hours. If it clears up, it is air bubbles. The old unit most likely had mineral deposits on the elements and they insulated the water from micro heating that creates the bubble. Since the unit is new, the water is in direct contact with the heating elements and micro bubbles are forming on the elements. When you turn the hot water on, the turbulence washes the bubbles out.
Sep 04, 2016 | Water Water Heaters
Why the hot water temperature couldn't reach the set temperature (130 degree) in Amtrol WHS80Z indirect water heater?
I have a couple of thoughts. You may have air in the boiler water circuit at the loop that feeds the tank. You'll have to find the vent in the loop to get it out. Second, the automatic valve that opens for hot water may not be opening fully. Have you felt both the boiler water lines that go in and out of the tank? If the water going in is hot and the line out is very cold you have very little boiler water going through the loop. Make sure the isolation valves on the loop are open. Is your boiler full of water? If the boiler loop lines are hot going in and coming out, the tank is full of rust or debris and no water can get to the fins on the internal tubing to pick up heat. If that's the case there is no repair and its time to get a new tank. Hope this helps good luck.
Nov 04, 2014 | Amtrol WHS-80Z - WHS-80Z 80Gal Hot Wtr...
Amtrol wh-7p
The tank rusting itself shut is almost an impossibility due to pressure. I would be inclined to believe that the controller is starting to fail and water that was way too hot entered the system and caused and overpressure issue that made the leak, When the pressure and temp dropped, the problem subsided. According to some of the threads that I have found on this, Amtrol is pretty generous about replacing the defective parts even when they dont have to. http://www.doityourself.com/forum/water-heaters/335226-amtrol-boilermate-problem.html
Jan 24, 2014 | Water Heaters
Heater broke, my Amtrol water heater expansion 80 gal tank, takes hot water from the oil fired furnace, and keeps it hot, However, the tank is set at 140 degrees, but the water coming out if the hot wter...
Hiliary
sounds like the primary coil in side is cracked and is mixing hot water.. with the cold water in tank need to check and replace as necessary
Sep 15, 2013 | Amtrol Water Heaters
Black flakes come out when the hot water side of the faucet is used
These black flakes must be in your line or your expansion tank. Remove the filter from your faucet, temporarily, and let just the hot water side run until the water comes out clean. You must flush these black flakes out.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jan 31, 2011 | Amtrol ST-5-C THERM-X-TROL ASME Expansion...
I have a humming and knocking that is happening in my pipes. It seems to be related to my hot water heater. I have unplugged the heater and that helps most of it, but there are still times during the day...
Knocking water pipes are caused by air trapped in the pipe. If the pipe only went uphill and horizontal, the air releases out of the faucet and doesn't cause a problem. But if the pipe takes a turn back down, there is an opportunity for the air to remain trapped. Try this ---. Turn on all of your hot water faucets full blast at the same time. Start with the highest faucet farthest from the hot water tank and work your way back to the one closest to the hot water tank. Count to ten, then close them in reverse order. If that doesn't clear the air, then look for a place where the pipe travels horizontally then back down. If such a place is accessible, and if the pipe is copper, buy a self-piercing tap of the type that are used to supply water to an ice maker. Install it and let some water out and hopefully some air out. If you also attach a section of clear hose you and you open the valve very slowly, you will be able to see the air bubbles in the hose. I use just such a setup on my hot-water heating system and it works like a champ. Good luck!
Nov 26, 2010 | Water Heaters
Amtrol water heater WH-7P gets barely warm water
From what you are saying it sounds like an issue with either a circulator pump or a zone valve. It depends on what type of system you have ... if you have a circulator pump that only runs the Amtrol then that is probably bad. If you have a zone valve system then it is probably the zone valve if you still have heat for the rest of the house. If you have no space heating then it is probably the circulator pump.
Nov 04, 2009 | Water Heaters
I have a amtrol proline pressure tank model ca17255 with air in the water part of the tank. how do you get the air out. thanks
the water heater should have a value on it. connect a hose pipe to it, run hose out door or window, then open value. need to open bathtube faucet.(cold) let it run until air gone, then go around and open all cold and hot faucets one at a time to remove all air in lines.
Aug 20, 2009 | Water Heaters
Air in hot water lines only after installing thermal expansion tank. tank is mounted below water line .
Mar 05, 2009 | Amtrol ST-12-C THERM-X-TROL ASME Expansion...
Water Heaters Logo
42 people viewed this question
Top Amtrol Water Heaters Experts
Paul Carew
rayc588
Level 1 Expert
Are you an Amtrol Water Heater Expert? Answer questions, earn points and help others
