Question about Pavilion Computers & Internet
Pavilion lap top not switched On pressing on/off button led flicker 3time nothing happen ?
shredivya
  • 71 Answers
SOURCE: My acer Notebook Does not switch on
Well you can reseat the RAM and check if that does not fixes the issue, it could be an issue with the system board . You can contact Acer support line, if the unit is under warranty you can have system board replaced.
Posted on Jun 29, 2009
antiochpc
  • 1314 Answers
SOURCE: DC5100 want start up
You need to replace the power supply, a fairly common problem.
Posted on Jul 17, 2009
SOURCE: MY iphone won't shut off
Probably the flex cable that connects the button to the mother board is damaged. This part is cheap and easy to install.
You can find the replacement parts here:
http://www.piezas.biz/epages/wwwpiezasbiz.sf/en_GB/?ObjectPath=/Shops/demo132390/Products/%22Piezas%20Iphone%203G%22
Posted on Aug 19, 2009
donfwhite
  • 122 Answers
SOURCE: how do I use print screen on my Acer Aspire
You need to PASTE the Item in a Program. Open Word and a Blank Doc and the Right Click PASTE.... should be there...:)
Posted on Jan 01, 2010
  • 18 Answers
SOURCE: lost signal on acer aspire 6530
There is a little satellite icon next to the always blue (when turned on) skip to next (song) and stop (square) touch buttons. Put your finger on the satellite icon for a few seconds, then move off, a green message should come up on the bottom of your screen saying "Wireless LAN enabled", if it says "Wireless LAN disabled" then there is another problem with your connection.
When the wireless is enabled check that you're connected to the wireless network. Start > Control Panel > Network and Internet > Network and Sharing Center (in Vista) you should be able to see:
"Access Local and Internet"
If it's not connected to the internet try resetting your wireless router, if that doesn't work, check you have the correct network password. Right click the two little PC screens (icon) in the bottom left, in the new window right-click your network and go to properties. In the new window, "Security" tab check the settings and type in the correct network security key (password) again. Hopefully you will have a record fo the network security key or your problem will have already been fixed before you get to this point. :)
Posted on Mar 06, 2010
Hp pavilion laptop beats saudio not switched on.On pressing on/off switched led flicker 3times nothing happen?Plese advised
no pc stated, it has a model, like DV6-12345
full names only work.
no OS stated, HP has laptops from 1982 to now.
what OS, operating system is this.
XP, Vista, W7 to 10? what?
May 09, 2017 | HP Computers & Internet
New Control Panel instald all it does now is beep open lid stop beeping close lid nothing happens lights stay on help please
It is important to set the size switch setting into the Motor Controller's memory whenever a replacement Motor Controller and or Display Module is fitted
To set the size switch turn the power on at the wall and off at the machine. Press and hold the TEMPERATURE UP button then press the POWER button. SmartDrive will give 4 short beeps and the pattern of LEDs will change.
• Press SPIN SPEED UP button, the SPIN HOLD LED is on for (8.0kg) (650mm wide). • Press POWER to exit this mode.
If this doesn't work let me know
Jul 16, 2015 | Fisher and Paykel GWL11 Top Load Washer
Lap top wireless connection to internet router
you need to turn on the wifi button on router
Feb 16, 2014 | HP Compaq nx6110 PC Laptop
Half of my screen flickers into blank white depending on the position of my screen
http://www.youtube.com/user/LCDPARTS?v=bqzaI7fK-HA
this page has a tester and how to change screens in a lap top..
hopefully its just a bad connection or loose connection.
Mar 17, 2013 | HP Pavilion DV9700Z notebook PC
My "hp pavilion a220n" won't power on. ... I was
Pull the power cord out and press the power button on the PC to drain the power for 10 seconds. Then plug the power cord back in and turn the computer on. If still does not work, then the power supply may be blown out and needs replacement.
Dec 23, 2010 | HP Pavilion a220n (DK218A#ABA) PC Desktop
My HP dv4 1120us laptop will not power on. When I insert the power cord the led for power bolt comes on and when I press the power button the power LED flashes once and then nothing happens. The power bolt...
Sounds light a power switch short, but lets try to take the memory out of the laptop and power on the laptop. Does it boot up? if so lets try 1 memory stick at a time.
Nov 29, 2010 | HP Pavilion dv4-1120us Notebook
Grand-ma knows best
It won't switch on at all, the power light is on at the front and the battery light shows re-charging. But when I press the power button on top nothing happens
Nov 22, 2008 | Toshiba Satellite M35X-S111 Notebook
HP DV 5000
Are you sure you didn't make an error while recovering. The c-a-del doesn't always work with reboot.
Jul 11, 2008 | HP Pavilion dv4000 Notebook
I noy surethis lap top is running the correct bios, and battery gets hot
does this only start to happen after the laptop has ben on for a while.
While more information is need, from initial thoughts the laptop could be overheating.
Jun 20, 2008 | HP Pavilion dv1000 Notebook
Computers & Internet Logo
Top Pavilion Computers & Internet Experts
Donna Sander
Josh Whitehead
Josh Whitehead
Are you a Pavilion Computer and Internet Expert? Answer questions, earn points and help others
