Toshbia laptop setup is starting services
Install windows don't have disc
I don't have the recovery disc for my laptop to install windows,what is the boot sequiense if i boot from the cd writer.can you assist me how to do it,please and thank you.
Have you tried to do a System Recovery from your recovery partition? If you have one? You didn't supply your Laptop make, model or your OS? What does it say on the Label of the disks?
Jan 23, 2013 | Computers & Internet
I upgraded windows from service pak 2 to service pak 3 then my windows encountered a problem what shall i do?
You can remove the service pack by click Start -- > Control Panel -- > Add/remove programs. If not, use the backup disc you created upon installing windows. If you didn't create or don't have one, use the original install disc.
Aug 03, 2011 | Microsoft Windows XP Professional
I want to install microsoft office to my mecer laptop but i don't know how to.
Step 1: Put Disc In
If a pop up automatically comes up, you want to hit install.
If not go to My computer.... and look for disc drive most of the time lettered "D"
Open "D" and go to setup icon
Step 2: Following the setup Instructions
Follow the prompt instructions by hitting next through the installation options. You will also have to put your product key in and accept terms of agreement.
Step 3: The Installation
The installation will run on its own all you need to do is hit finish when it completes.
May 23, 2011 | Microsoft Office Computers & Internet
How to restore hp pavilion dv4000 to factory settings
The way to restore most PCs to factory settings is to reinstall Windows. First, MAKE SURE you have the Windows disc that came with your computer and the drivers/utilities disc that came with it.
To start restoring, put the Windows disc in that came with your computer, and run it. Find the option to install/reinstall Windows, and select it (you may have to boot from the disc, which can be done by changing the boot order in BIOS settings). Follow the instructions Windows Setup gives you.
After you're done with that, don't freak out if the sound, wireless, touchpad, etc. isn't working. Insert the drivers/utilities disc now and install all the drivers that are on it onto your laptop.
You are now done with the restore process!
Apr 15, 2011 | HP Pavilion dv4000 Notebook
How do i open my toshbia in safe mode in order to run a recovery disk will not boot
to get the recovery disk to load start computer watch the bottom of screen it will tell you to press F2 to get into setup, click the boot option tab, highlight cd/dvd drive, then by pressing + or - or F5 or F6 which will move it up to top, then go to tab that says exit and save, select yes. put recovery disc into cd/dvd drive and restart.
Sep 14, 2010 | Toshiba Satellite A100-S8111TD Notebook
Can't install xp on toshbia notebook
get xp cd, boot from cd, format drive,install windows
Oct 20, 2009 | Computers & Internet
Windows xp setup halts
This generally indicates that the disc is corrupt. It can be anything from a scratch, degraded read section on the disc, or a distortion from the disc getting bent or hot (left in direct sunlight). You will most likely have to use a different disc for the install.
Sep 03, 2008 | Toshiba Satellite A65-S126 Notebook
Hp computer
You can repair that by booting your system using the CD ROM and the select to repair windows.
If ever this will not solve then;
You should backup your files and reinstall the windows operating system.
In installing operating system you need the following:
1 windows bootable disc/ Operating System REcovery Disc
2.Cd /DVD rom
Boot your system any of this CD/DVD disc and then follow the on screen instruction.
After installation, don,t forget to install the drivers of your system that was enlosed in your system.
If ever there problem arising this solution please notify me for further support.
Jan 22, 2008 | HP Pavilion Media Center a1330n - AMD...
Computers & Internet Logo
David Payne
David Payne
