I get a clear paper jam then press ok but there is no paper jam
SOURCE: "Clear paper jam" error, but there is no jam!
Thanks, tried all the maintenance options including cleaning the rollers. What I have found worked very well was to bin the printer and purchase an HP model!
Posted on Apr 06, 2008
SOURCE: I have a Canon Pixma
It was covered by Staples Extended warrantee and they exchanged it.
Posted on Nov 15, 2008
TIPS72
  • 369 Answers
SOURCE: Canon MP610 - Paper jam error message
PLEASE REMOVE THE POWER CABLE AND REINSERT IT IT SHOUL BE OK AND IF STILL PERSIST JUST RESTART THE PC IF STILL RESIST PLEASE LET SOME TECHNICIAN TO CHECK FOR THE SENSOR FOR THE PAPER JAM ...
GOOD LUCK
Posted on Jan 04, 2009
davedstone
  • 11 Answers
SOURCE: Paper Jam MX860
Double check as sometimes a small amount of paper will give this error message. If you are sure no paper is in the path/feeder, then unplug your printer from the ac supply for about 10mins (Logic reset) then plug back in and this should have this working again.
Posted on Sep 12, 2009
  • 289 Answers
SOURCE: error paper output slot. the paper is jammed clear
Try this...With te printer off line, press the paper feed button making sure thre is paper in both feed trays. Once it print, a blank page go in and change back t your desired papper source. Hope that helps, please let me know.
Ash
Posted on Jan 27, 2010
Cannot clear paper jam
Paper Jams in the Automatic Document Feeder
If you're loading legal-size paper, insert only 10 sheets at a time to prevent paper feeding problems.
If paper jams inside the ADF, clear the jam and reload the paper as follows:
1.
Open the ADF cover and remove any jammed paper.
Caution:
Do not try to remove the paper without opening the ADF cover first, or you could damage the mechanism.
2.
Press OK, then select Yes and press OK to clear any messages on the display screen.
3.
Reload the paper. Make sure the corners of the paper are not bent, folded, or curled up.
Jan 11, 2011 | Epson WorkForce 600 All-In-One InkJet...
Paper jam.clear jam paper and then press ok.
clear any jammed paper then push ok if you cannot find any jammed paper then pull the plug wait 10 seconds and plug it back in
Dec 02, 2009 | HP PSC 1610 All-In-One InkJet Printer
Paper cartrige cradle is stuck.
print cartrige cradle is stuck clear jam then press ok in hpphotosmart 7550
Sep 08, 2009 | HP Photosmart 8150 InkJet Printer
Canon MX860 Rear Paper Jam
I have a small piece of paper jammed in my Canon MX-860 that Cannot be seen from anywhere. Can you help me find so I can clear it
Jun 27, 2009 | Canon Office Equipment & Supplies
Jamming problem
try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Mar 06, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Please clear paper jam and press ok
hi i josh in cebu phils. may i help you? friend the paper jam means there is something blocked your paper feeder try to clean or check if there is something in there may be a paper pencil clifs etc. try to clean and restart the printer.good luck
Feb 19, 2009 | Office Equipment & Supplies
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prirweto-i-23
Sep 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
jasbo
jasbo
