Question about HP Boating
Trouble shooting starter not turning over on 35 hp US Marine force outboard
5 Suggested Answers
  • 157 Answers
SOURCE: 1996 force outboard motor
Hello vickurzawski, You have a bad bendix. This is mounted on the starter to engage the starter to the flywheel. Check with a local marine shop or auto parts store for a new or used one. Disconnect the battery, remove the starter from the engine, replace the bendix on the starter. Connect a jumper cable to the starter to test operation before bolting back to engine. Make notes on what wires went where before disconnecting.
Posted on Oct 30, 2008
  • 23 Answers
SOURCE: do you have a wiring diagram for an MP39760 marine
Seloc has the best manual.
Posted on Mar 23, 2010
muffteck
  • 202 Answers
SOURCE: Have a 1980's 35 hp 2 cylinder Johnson Outboard
you will need a manuel . To set the advance you will have to get a old bent prop and cut the blades half off (test prop) back boat in lake on trailer,,,,, Or find a test tank ... Or hang on the back of the boat at wide open with someone driving and you hanging on with a timming light and watching flywheel
Posted on Mar 18, 2011
  • 1564 Answers
SOURCE: looking for instruction manual for K & B 8701 Marine Outboard
Sewing machines have outboard marine motors now? Wow!!
Posted on Sep 05, 2012
Procedure to replace 130hp honda impeller
Go to http://marine.honda.com/support/manuals and search your engine. Also try http://m.marine.honda.com/support/manuals
Aug 08, 2014 | Honda Water Pump Impeller Outboard 35, 40,...
My 86 yamaha outboard will not turn over
Bypass solenoid,put jumper from pos on batt to starter motor,but could be so many things,faulty battery cables,broken wire in loom,worn starter brushes,faulty solenoid ,start in gear switch or ignition switch
Feb 02, 2014 | Clymer Marine Maintenance and Repair...
Have new tohatsu outboard that runs fine but wont rev out over 4500 rpm
I just looked at 7 different sites and they are saying Max RPM is between 4,500 - 5,050... How accurate is your Gauge?
Prop Pitch will greatly effect MAX RPM.
Apr 05, 2013 | Sierra International 18-6431 Marine...
Yamaha 4HP outboard - cannot pull starter cord - jammed.
Engine or gearcase seized...
Remove the recoil starter ( 3 bolts and the startingear link)
If you can turn the flywheel slightly: Gearcase seized
If you can't turn the flywheel at all: Engine seized.
In both cases: If you can't disassemble and have the job done yourself, forget that motor...
Dec 09, 2012 | Clymer Marine Maintenance and Repair...
I have a 1973 Evenrude 50 hp outboard motor, when i turn the key nothing happens
it is either a wire broke or the the starter solionde is broken check with volt meter at starter + and - if it shows up voltage its the brushes in the starter motor
Jul 13, 2011 | Boating
I have a 1977 85 hp johnson outboard it started and idiled for about a minute and now i cant get it to fire at all its got good spark possibly not getting fuel but is there anything else i should check
i have a 1977 85 hp johnson outboard it started and idiled for about a minute and now i cant get it to fire at all its got good spark possibly not getting fuel but is there anything else i should check
May 06, 2010 | Johnson Minn Kota Mk 25 & Mk 35 On Board...
I have a 1990 90 HP mercury outboard. It is rough idling and surg
I have a 90 hp force ob. when i run it with the ears she runs fine lets me bring the throttle all the way up. when i but it in the water thru the wake area i can do 4 mph once i'am out of the wake area and give it the gas she dies, any ideas
Apr 20, 2010 | Raymarine Linear Feedback Unit For...
Aug 29, 2008 | Boating
Boating Logo
Top HP Boating Experts
vince
Are you a HP Boating Expert? Answer questions, earn points and help others
