My T15.0 treadmill has a clicking sound. I lift up to see the bottom motor compartment to see a red light. This flashes on/off with the clicking sound.
Red light should be on/off or flickers while the track is running>
SOURCE: Overall Problem - Panasonic RX-ED707 won't work properly at all
only 1 reason for that faults :
there is a flat connects the top panel which has all the controls with the other circutes in the stereo...
so you have to open it and care for the cd unit it damage easily then check the flat for loseness or cuts
it happened to me also and that works perfectly
good luck
Posted on Dec 21, 2007
  • 3197 Answers
SOURCE: Chamberlain Lift Master Pro Formula 1 only makes click sound
Is the door stuck in the open position? If so the trolley is probably jammed against the bolt just in front of the motor unit. Loosen the chain enough to free the trolley and then run the opener until the door is closed. While the door is closed locate the 'up limit' on the side of the motor unit and turn this control 2 complete turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
Posted on Apr 05, 2010
  • 726 Answers
SOURCE: radio will flicker, battery light
sounds like battery is dead or the altinator is not charging at full capacity start the car take the positive lead off if it stalls altinator is gone if it runs its all good if it runs but rough altinator is not putting out enough power
Posted on Jul 28, 2008
websnail
  • 419 Answers
SOURCE: flash feed paper & ink light my epson r1800 printer
Do you mean that the paper light flashes at the same time as the ink light or do they flash alternately (ie: paper on, ink off -> paper off, ink on)?
If so the waste ink pads are full and you need to do the following:
1. Reset the waste ink counter:
Grab the tool linked from the wasteink.co.uk site (see bottom).
2. Redirect your waste ink into an external tank OR replace your waste ink pads.. (external tank is easier).
Instructions for the R1800 are available from this site
If the lights are doing something different, please post again with detailed information about how they flash and I can what else it might mean.
Hope that helps.
Posted on Mar 13, 2009
  • 64 Answers
SOURCE: Nordic Track Treadmill will not run
If console lights up but doesnt respond when buttons are pressed, you more than likely have a console problem. Key pad issue would be my best guess.
Posted on Jun 08, 2009
When I press start the treadmill goes for about 1second and stops. Incline/decline works, no error messages. Red flashing light on the control board after the treadmill motor quits. Stops flashing if I...
Contact the store where you bought it. I'm sure your treadmill is covered by the warranty.
Anyway, the next time buy some high quality treadmill to avoid any hassle. I like the treadmills reviewed here: http://www.your-workout-routine.com/cardio/best-treadmills-2014/
Nov 14, 2014 | Exercise & Fitness
Nordictrack Commercial 1500 treadmill w/working display BUT unresponsive buttons
Sounds like a cable harness is undone. The cable feeding the panel which has the computer inside (the power feed) is connected, but the cable from the panel back to the motorized parts isn't. The breakaway is a separate circuit that cuts all power to everything. These are my assumptions (I'm not a nordic track expert), but it's a pretty safe bet, likely the connector in the bottom section. Okay, I just looked it up, first Google "nordictrack 1500 manual" one of the first links is a PDF, with a complete parts breakdown. Depending on your specific model, it looks like there is a connector under the top panel where it meets the right post (and a couple of screws will let you lift it up to check it). It may be partially unplugged, check that first since it looks pretty easy to check.
But I think it's going to be in the bottom, in the bottom of the treadmill the wiring splits to different sections. The motor/incline controller cable (a separate cable #106 on one model I looked up, something like NTL09707 or similar) is probably the one that is either broken or unplugged. So although the computer (up top) is sending signals, they aren't reaching where they need to. Anyway, get that manual, and someone handy with screwdrivers and technology, and they should have it figured out quickly.
Dec 04, 2013 | Nordic Track NordicTrack Commercial 1500...
How to fix a treadmill
see the video attached. lube the rollers bearing front +back.
However you must test the terminal motor voltage with multimeter, if there ARE THE MOTOR IS faulty. see my personal TIPS.
2) test the measure output voltage from control board for input voltage terminal motor if there ARE NOT, the board is faulty.
God bless you
Oct 19, 2013 | Exercise & Fitness
The treadmill will sometimes start and most times will not, even though there is still power. Then I will be on and the belt will stop turning. I can move the incline level but that is all.
With the motor cover off and the power on, make sure there is a red light/led lit on the controler, if yes then press the start button then press #3 on the speed side. If not lit, you dont have power to the controller. If you had a red light, and pressed the speed button, the light should start flashing just before the walk belt starts to move. If the speed button is pushed and the light on the controller does not flash, you have a problem in the console. This is only fixed by replaceing the controler.
Sorry.
Hope this was at least helpfull, Matt
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Dec 30, 2010 | Reebok Acd1 Treadmill Motor Control Board ...
The running belt motor does not work, everthing else works fine the belt will just not turn- no noise or anything
You need to pull the motor hood off to see if the belt is still on the motor. If it is and the motor is not turning, check the controler ( located on the otherside of treadmill) and you should see a red light on. When you tell the treadill to go.... the red light should start to flash, if it does then you need a new motor. If it just stays lit, you have lost communication from the console ( the upper controls ), and need to find out if something came dissconnected.
Hope this helps
Nov 10, 2010 | Horizon Fitness Horizon T91 Treadmill -...
My Tunturi Treadmill ramp is stuck in the top elevation position and will not run. I get a "Auto Syncing" message, but the machine will not run. Have tried unplugging etc, but it will not exit the mode...
Enter the testing mode after switching the treadmill POWER ON by pushing first ‘SELECT’ and then ‘SPEED DOWN’ and hold buttons pressed simultaneously.
LED scanning mode for verifying display functionality Press ‘ENTER’ to scan DATA LINES to verify display functionality Press ‘ENTER’ to scan SACN LINES to verify display functionality Press ‘ENTER’ to scan LED’s to verify display functionality After pressing ‘ENTER’ the TIME window shows “test” and the keypad functionality can be tested (the value displayed changes when a button is being pressed) Press ‘ENTER’ to enter IO mode (TIME display shows lift motor potentiometer value, SPEED reads speed from speed sensor and DISTANCE shows heart rate pulse) Press ‘START’ to test lower board relay (a “click” sound) and then press ‘ELEVATION UP’ for 2 seconds to increase the elevation to 8%. Press ‘ELEVATION DOWN’ to decrease the elevation to minimum percentage 0% Press ‘SPEED UP’ to increase speed value and ‘SPEED DOWN’ toto decrease speed value. Press ‘ENTER’ to repeat above test or ‘SELECT’ and ‘ SPEED DOWN’ buttons simultaneously to return to the normal mode
The lift motor calibration is done manually by following the following steps: 1. Drive the lift motor to 0% from user interface (inclination display must be 0%) 2. Switch off the treadmill and unplug the power cable 3. Remove motor cover 4. Fold up the running deck 5. Loosen two screws (A) attaching the lift motor nut (B) to the incline frame 6. Adjust the lift motor nut (B) so that there is 9 mm (.358 in ) gap between the upper end of the nut and the lift motor frame Tighten the screws (A) and verify correct elevation by measuring Adjusting lift motor to 0% position 2.76in 12% position 9.646 in measurement taken from floor to bottom of motor compartment frame.
Jun 11, 2010 | Tunturi T30 Programmable Treadmill
T6 t7 error in lift motor
That potentiometer may finally gave up the ghost or the unit may need to re calibrated but first it needs mechanically put back together I would call Accell fitness of North America they are the distributors of Tunturi Treadmills and should have the technical data to help in the process. Their Phone # is 1-888-388-6887 Good Luck
Apr 29, 2010 | Tunturi T20 Folding Programmable Treadmill
Viewpoint 2800 model# NTL14905.0 none of the keys respond. TV goes blank or has just red screen
Remove the cover to the motor compartment. Check the red LED on the LMCB. If it is lit constantly and not flashing in any manner, it is the console that is bad. The console runs $1600.00 which is more than the cost of the treadmill originally. Sounds like you are SOL unless you can find a used console somewhere. Good Luck.
Jan 04, 2010 | Nordic Track NordicTrack Treadmill, A2550
WANT TO REMOVE THE MOTOR FROM SPIRIT TREADMILL TO SEE IF IT CAN BE FIXED. HOW TO ?
Remove cover at front of treadmill,4 pillips screws on each side, 2 screws at front. Lift off plastic cover. Loosen motor belt tightener at top of motor mount ,remove 4 11/16 " nuts holding motor to treadmill base, remove red and black motor wires from control board. Lift motor out.
Aug 04, 2009 | Spirit Exercise & Fitness
Image 10.0 treadmill incline not working
You have a stripped drive gear on the lift motor, order a new incline motor, install it and then calibrate it and you should be fine.
Apr 26, 2009 | Icon Exercise & Fitness
Televison & Video Logo
Top Televison & Video Experts
