Question about Sewing Machines
What's wrong with my Nelco 234F sewing machine. When I try to sew, the machine gets jammed and the thread is all tangled around the bobbin.
  • Sewing Machines Master
  • 12,296 Answers
Install a brand new needle.
Remove the top thread. ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
Generally, the top tension should be set at the midway point and then tweaked for your particular machine.
If you continue to have a problem, the machine probably needs service.
Posted on May 09, 2017
High & Low tension adjustment of bobbin on a Nelco 234F.
Not quite understanding your question. The standard top thread tension setting is the midway point between high & low numbers. If the bobbin thread is coming to the top of the fabric, loosen the top tension. If the top thread is showing under the fabric, tighten the top tension so it will pull more bobbin thread up into the fabric.
May 10, 2018 | Sewing Machines
I need help putting the bobbin threader back onto a Nelco JA38 sewing machine and the springs are giving me fits. Any help?
Not sure if you are having problems with the bobbin winder or threading the bobbin. This may help:
Nelco JA 38 Sewing Machine Threading Diagram
To avoid awful thread nests under the fabric, be sure to ALWAYS RAISE the presser foot when threading the top thread.
Interestingly, the bobbin threading instructions (above) show the bobbin loading into the bobbin case so it turns COUNTER-clockwise. This is the opposite of instructions for most machines. You can probably try both, the clockwise or Counter-clockwise,and see if one works better than the other.
Be sure to use fresh, good quality sewing machine oil or Tri-Flow Synthetic Oil on your machine. Open it up, while gently wiggling the handwheel, drop a couple drops of oil every place that metal rubs against metal. Avoid plastic or rubber parts! You may even find little round holes throughout that are oil ports. Be sure to get the area around the needlebar, presser foot lifter, feed dogs, the bobbin area, and all the dial and selector mechanisms.
You can find manuals for your machine online (not free!).
Nelco Sewing Machine Manuals Instruction and Repair Manuals
Aug 07, 2017 | Sewing Machines
Do you have experience with a Nelco Sierra 234F Serger? How is the quality of stitching, how easy is it to use and problem free is this machine? Are you still able to get parts for the machine?
As far as I am aware, Nelco hasn't been made for quite a few years--probably since sometime in the 1970's is my guess. I have an old Nelco sewing machine that is a tank of a machine and sews nearly anything I throw at it. But for finer work, I prefer my Bernina--probably because it has more stitch selections, sews a straighter stitch, and I know it better.
If you aren't able to have the machine demonstrated to you and you can test it to your satisfaction, I'd be reluctant (Actually, that goes for any used machine, not just Nelco!) The following may be helpful:
Thread Anybody heard of Nelco sewing machine Worth fixing up
Jan 25, 2017 | Sewing Machines
It keeps getting tangled up here the bobbin is underneath and keeps getting jammed
try changing the needle--make sure it's the correct one for the fabric
being sewed
rethread the machine ---using every thread guide
try using a different bobbin
try turning the bobbin over the other direction
clean under the needle plate and in the bobbin area for lint
also could be a timing problem and the machine would need to be
checked at a sewing machine repair shop
Apr 12, 2013 | Singer 3116 Simple
Bobbin thread is tangling around bobbin carriage as I sew. So I can only go a few stitches before the machine stops sewing and it's tangled.
Hello
This is Really not that big a problem. Simply pull out the bobbin thread with a long lead, put the assembled bobbin into the sewingmachine and take that long thread and close it between the sliding door and the machine itself to hold it temporarly.
Most sewing machine problems are caused by the usasge of wrong thread type. Make sure you have a thread that is for a sewing machine use, that is, good strong stuff, not hand needle basting thread as that will cause much problems.
Often the bobbin is thought to be the problem, those things are almost never the problem. A source of problems also is the usage of wrong or improperly machined flat on the needle itself. Be sure to buy a quality needle as that flat on there, if machined not deep enough will not allow the bobbin to pick up the thread, wind it around and form the stitch.
Jul 12, 2011 | Singer 4830
The bobbin thread will not pick up. The machine had jammed and I forced the wheel and can't get bobbin thread to pick up. When I thread manually, I only get holes, no stitches. Is it a timing belt?
check your needle to see if it's bent---roll on flat surface to see if it roll correctly
on some sewing machines when the thread comes off the thread take up lever it can cause the machine to jam
also if the bobbin thread becomes tangled it can jam
check the bobbin area for lint or loose threads
try having a top thread tail & bobbin thread tail of 3-4 inches
try holding the top thread tail & turn the handwheel on the right side on the machine manually & put the needle down into the bobbin area & see if the bobbin thread will pick up that way
Sep 24, 2010 | White Sewing 2037 Mechanical Sewing...
My sewing machine keeps getting jammed when sewing. the top stitch keeps getting tangled in with the bobbin thread and jamming up the machine.
Here are a couple of things to try.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin
There could be a nick along the edge of your bobbin spool that’s catching your thread as you
sew.
* When you start to sew a seam, grasp the upper and bobbin thread tails. Hold them back
and out of the way as you sew your first couple of stitches. This will keep them from getting
caught in your machine.
I hope this helps.
Sep 11, 2009 | Singer 5160 Mechanical Sewing Machine
Jammed thread.
To address my needle thread tangling (horribly) in the bobbin compartment, I rethreaded the bobbin. I cleaned the bobbin and the feeder feet, I changed the bobbin and the thread. I changed the tension on the needle thread and the bobbin thread. NO FIX! Then, I changed the needle - the problem was fixed instantly. I sewed awhile and then put the original needle back in. No problem. I think perhaps that the problem is being caused by the needle getting out of alignment somehow during sewing. If you are having the same issue, try it. It can't hurt!
Sep 08, 2008 | Kenmore 15516 Mechanical Sewing Machine
The bobbin string gets tangled in a big mess and jams the machine
adjust the thread tightness. thread tension might be loose enough. be sure also the the bobbin inside the machine is place correctly! reversed placement would result in bigger mess.
Feb 26, 2008 | Brother XR-65t Mechanical Sewing Machine
Sewing Machines Logo
65 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
