Question about Craftsman Garden
We have a craftsman lawn mower that has not been used 10 years. It starts for a second when we use starter fluid but dies right away. Any suggestions? It has gas and we put a new air filter on it.
  • Craftsman Master
  • 4,300 Answers
In order to start and run an engine needs compression, timing, the correct quantity of fuel and a good spark. An engine that doesn't start has one or more of those requirements missing.
The fact it runs for a second with the ether spray indicates it has spark, compression and timing, though it must be remembered ether is more volatile than petrol so if the spark or compression is weak, ether might work but petrol might not.
The main indication from your description is fuel is not reaching the combustion chamber or the wrong quantity or perhaps the fuel isn't fresh. Revisit the basic requirements and if nothing is discovered, strip and clean the carb.
Posted on May 09, 2017
Will start but will only stay running if you prim it until its warm then runs fine
Lawn Mower Repair pt.1: starts & dies, Tecumseh/Craftsman ...
? 2:10
Mar 7, 2011 - Uploaded by Alameda Repair Shop
Spray with starting fluid and the engine runs a bit longer but dies.... I especially like how you use the gas can to hold up the mower, Classic :) ... After I started it up, it would only stay running for a few seconds before dying. .... LAWNMOWER REPAIR: briggsand stratton pulsa prime carb overhaul - Duration: ...
How to fix a gas lawnmower that starts then dies - YouTube
? 7:37
May 3, 2011 - Uploaded by SmallEngineRepairGuy
This is a how to video on what to do if your gas mower starts up then dies after a ... I have a different lawnmower and not very mechanical but this got my ... Got the job done and now i can do a thorough cleanout of it when i run it dry of gas. .... How to FixBriggs & Stratton Small Engine that Only Runs Off the ...
Craftsman 5.3hp starts but won't stay running... - DoItYourself ...
Dec 09, 2015 | Briggs & Stratton Briggs Stratton Intek V...
Need suggested fixes
clean your carb out, not getting enough gas I guarantee you didn't run wire thru your jets best thing to do is take the carb to your nearest lawnmower repair shop to have them soak it in cleaning solution for a day or to and have them put a carbkit in it
Jul 30, 2015 | Garden
Craftsman 22" self propelled platinum series lawnmower died while pushing it. wont restart. ????
A good place to start is taking the air filter off. Then try stArtingvit again. Often a dirty air filter will not allow a mower to stay running. If that does not help. Remove the cover under the carburetor looking for dirt in the cover. Also well the cover is off remover the small pin that holds the float in place. Pull the neddle valve out cleaning it and the other parts with a carburetor cleaner then reassemble
Jul 21, 2014 | Briggs & Stratton Garden
Why is my craftsman lawn mower keep shutting down every 5 feet or so. Its about 4 years old. Any suggestions?
Are you sure you have to mix the gas with oil.I don't think Craftsman engines mix the gas. It you have a dipstick that tells me that you put oil to the full mark on the stick. If your carb has a cup on the bottom of the carb take it off and clean it out. Also clean the fine holes out that's in the bolt as they get plugged with dirt.and engine won't run.Usually an air gun will do the trick. When you put it back together make sure the gasket is installed properly. If there is not much oil when you check it you could seize the engine.
Jun 29, 2014 | Craftsman Garden
Riding lawn mower battery won't hold a charge
It is a battary issue, however it sounds like the engine is not charging the battary so it goes flat, or there is a drain on the battary .
Jun 27, 2013 | Craftsman Garden
What would cause mower to die after starting?
your carb. is gunked up. get a can of starter fluid and a helper. have the helper spray some starter fluid into the air intake to keep it running after it starts. Once it runs for a couple of minutes it will be ok. J.
Jun 27, 2010 | Craftsman 675 Torque 190cc 21" Briggs ...
Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Jul 05, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Craftsman mower will not start without starting fluid
Sounds like you have water / debris in your carb fuel bowl. Using spray carb cleaner will only work if you remove the bowl and clean the carb jets. Also, you could have water in the gas tank as well. First, remove your air filter, then remove the 3 screws that attach your filter bracket to your carburator and mower. Take off your fuel line at the carb and drain all your gas into a clear jar. If it looks very yellow, cloudy, or see water in the bottom of the jug, change your gas. Using a half inch socket wrench, after gas line is disconnected, remove the fuel bowl and clean with carb cleaner. Also, examine the bolt you just removed. There are 2 jets in the side and one at the end. Using the carb cleaner, make sure they are clean as well. Use the carb cleaner extension tube to spray up inside the bottom center of the carb, where the bolt threads, to clean that area as well. After all this make sure your float assembly is intact and reassemblt the bowl to the carb and reattach the the fuel line. finish by reattaching the air filter support bracket making sure the gasket between the carb and the bracket isn't damaged. Also, never use last year gas, alway buy freah every year.
Jun 07, 2009 | Craftsman Garden
Got a Craftsman 6.25 HP push mower. Had it for just over 2 years. I pulled it out of the garage to mow the grass the other day, and it would not start. I used some starting fluid and it started right up....
Check the fuel line for cracks or breaks. Check the fuel filter if it has one. And finally, you may need to disassemble the carburetor and spray with carb. cleaner.
Jun 07, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
