Question about Crafts & Hobbies
What does Pattern 47 , turn, Continue onese 47 sts. for left side of neck
Crochet popcorn neck warmer with buttons need pattern
Search for:
popcorn stitch neck warmer pattern
Dec 24, 2017 | Sewing Machines
I am knitting a Santa 14 inches and the instructions for the neck and head are missing off my copy. I am at the neck shaping and have 32 sts on my needle in red - can you help me please?
Sorry. Unable to help with a pattern we've never even seen. Unless you can find the pattern for sale somewhere, you may be up the creek without a paddle.
Nov 07, 2016 | Sewing Machines
I need help with burda 7187
Usually with a wrap dress, you join front triangular pieces to bodice back at shoulders and side seams (often leaving a slit open in one side seam to pull the tie through). Then stay stitch neck and front edges to prevent stretching. Then neaten neck edges turn and stitch, or attach a facing. Probably if this pattern has a facing then you may need to attach skirt to waist and also attach the tie ends to the front edge before facing is attached. So when you turn facing to inside you will have the tie end in position at the point of the bodice/skirt seam on both sides of the dress.
Feb 28, 2015 | Sewing Machines
Where is the VIN plate on a 2006 Suzuki Hayabusa please?
On a 2006 'Busa, there is no plate. The numbers are stamped into the neck. They are on the right side of the neck (as if you were sitting on the bike). Turn the bars to the left and look on the right side if the neck. You will see them stamped into the metal. Hope this helps Pete.
Nov 19, 2014 | 2006 Suzuki GSX 1300 R Hayabusa
How to increase sts. and keep pattern
could you please translate your abbreviations?
Jan 14, 2013 | Lion Brand Homespun Yarn
Turn signal flasher on a cadillac seville sts 1994
  1. The flasher is hidden under the left (drivers) side of the dash, in the vicinity of the steering column.
Dec 30, 2012 | Cars & Trucks
Left signal lights do not work on 2005 sts
Check for power at the light socket aswell as grounds
Jun 16, 2012 | 2005 Cadillac STS
Where is the driver side blend door actuator on a 98 Seville STS?
I believe that the right side has a blend door actuator, and the left side or driver side just gets air from the regular flow from the programmer and vacuum motors.
Dorman/Blend Door Actuator
Part Number:
btn-view-details.png Price: $139.99
Notes: Dorman-OE SolutionsTemperature door. Right
Oct 29, 2010 | 1998 Cadillac Seville
Furreal pony, Butterscotch, Head floppy/leans left
There is a smaller "u" shaped spring in the middle of the neck mechanism that I found one side was snapped off. Looks normal, but it's broken. I made one out of a coat hanger for temporary purposes and it works like new! I will order one from Hasbro. Hope this helps!
Dec 09, 2008 | Hasbro Fur Real Friends Smores Pony
Crafts & Hobbies Logo
157 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
ray gallant
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
