Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Ajust valves i also had problem whit lt1000 mower they have a bad problem whit valves needing to be ajusted that will cause a very bad drag in the starter making you think you have bad battery
  • ed in oregon May 11, 2010
    are you asking for help or are you responding to another post?
  • 123 Answers
The valves need to be adjusted every year due to normal ware. I all depends on the motor for adjustment is it a single or twin cylinder engine over head valves or not. Please be more specific.
Posted on Aug 26, 2009
Adjustvalves
i need to know what engine it is and is it an ohv or flat. if you have never done this before you can ruin an engine pretty quick. get all your numbers and go to your local mower repair shop they can tell you how to do it. it is an easy job but if you don't do it right you can cause more problems good luck.
Apr 14, 2016 | Garden
79 chevy 4.1 how the best way to ajust the lifters
WHIT ENGINE RUNUNG AT IDLE AND VALVE COVER REMOVED START TO LOSSE NUT AT ROCET ARM AND WHEN NOISE CHANGE LIKE TIKING START TO ADJUST NUT OTHER WAY WHIT
Oct 05, 2014 | Cars & Trucks
Valves ajustement pour 16.5 hp briggs stratton model 313777 0112e1
Find a small engine shop in ur area they will have what u need, or call Briggs stratton
Jul 10, 2014 | Garden
I need to ajust the deak hight on a craftsman lt1000 riding mower
i think that model has a plastic cover just above the foot rest on each side and the adjustment is behind there
Apr 26, 2012 | Craftsman Garden
Honda deale told me i needed a valve ajustment on my 750 shadow it got about 9000 miles on it i took it in the spark plugs were black it runs good they say one valve may need ajustment some one told me...
Spark plugs are carbon fouled black usually caused by leaking valve seals,bad oil control rings.The fuel flow, the fuel pressure, the fuel itself, the fuel pump, the fuel filter needs to be inspected.Also the oil needs to be checked.--------- If one of the valve is out of adjustment, it needs to be realigned, as it can cause the leak and this may cause spark plug getting black. --------- I agree that at present, motorcycle is running fine, but this spark plug getting foul black, is the indication to checked this above mentioned possibilities.--------- ---------- Get the valves and fuel system inspected by the local dealer or at local garages.They can inspect the valve and fuel system and do required tune up and adjustments.--------- This will help.Thanks.Helpmech.
Sep 04, 2011 | Honda VT 750 C2 Shadow Motorcycles
The left rear brake auto ajustment will not stay set i have replaced the front rotors and pads also a complete rear brake job including new spring kit and shoes and new drums. the left rear is ok for a few...
if the wheel cyclinder is bad it will either bleed off causing the brakes to feel soft or the pins could be stuck causing them to drag. also check that all the springs were replaced in the proper location or it may not be holding the adjuster where it needs to be.
Apr 05, 2011 | Chrysler Cirrus Cars & Trucks
The transmission works good except it won't back up. Is it necessarily a bad transmission
linkage out of ajustment valve body needs cleaning or ajustments bad clutch trans bad
Feb 10, 2011 | 2001 Ford Escape
Craftsman LT1000 mower deck cutting uneven. How
try biger wheels on the low side???? ha ha?
no you hit and bent the bed hight ajusters you may need to take the mower bed off to fix this part,,,,,
look as were the morer hight ajuster is,,, is it in the same place on both sides,,, my gess is its not
the bed has a tilt on it,,,they dont cut down trees very well do they?
Jun 11, 2010 | Garden
Missing or a poping sound when NOT under load
sound like the valve need to be ajusted need more information on it want kind mower is it
Jul 18, 2009 | Garden
How to ajust drive belt on a mtd riding mower
Adjust in gear 7. If you try to adjjust in gear 1 you will get it to tight and it wont work properly
Apr 14, 2009 | Mtd Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
191 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
