Our picture is dark. How do I correct this.
We had company and they were not using the correct remote.
TV PICTURE IS TOO DARK
use the menu on the remote to ajust the picture depth & brightnes
Jan 14, 2013 | JVC 37" Lcd Tv - Widescreen [lt-37e488]
DARK PICTURE
Just restart the tv and can u tell me company name and model no.........
Aug 03, 2008 | Toshiba 42H83 42" Rear Projection...
Dark picture problem
there are 2 mirrors did you clean both there is one down in front near the light source when front screen removed lean in and look down there is another smaller mirrorclean it
Jan 02, 2009 | Mitsubishi WD-62327 62" Rear Projection...
Very dark picture on TV
Try restoring all factory settings. On your remote, press the reset button twice. If that doesn't correct it, then you'll probably need a repair technician. For more info, consult your owners manual, which is also available at
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=fe26abca0a54ad7cbe4ba91bb243a7c2&q=Sanyo+DS31590
Jul 27, 2008 | Sanyo DS31590 31" TV
Lamp reset
The correct way to reset the lamp timer on that unit is to hold the menu key on the remote and push the enter key on the front of the TV at the same time. Hold them (it's about 9 or 10 seconds) and then a screen comes up asking if you would like to reset the lamp timer. That will reset the time but if your problem is a dark picture that's probably not going to fix that.
Apr 12, 2008 | Zenith E44W46LCD 44" Rear Projection...
CANON Rebel RTI Outdoor pictures are dark
learning to use light metering correctly can have its challenge.
the manual will guide you on how to set up to read light from the subject. spot metering a dark area will cause general overexposure, or a washed out look. spot metering a bright area will cause a dark image. if you are on spot meter and shoot two people standing together against a bright lit background, your meter will see between them if they are centered, and read all that bright background, setting the camera to a less sensitive combination of aperture / shutter speed, resulting in a dark image. use field averaging meter setting and be sure you are metering the subject and not the background. try shooting a wall that is fairly clear of other colors and uniform it light hitting it, you should have a correctly exposed image. since it works in other modes (at least 1, anyway) then it is unlikely you have an exposure compensation issue. that is the only other non defect issue that would cause your problem.
once you confirm that you have these settings correct and still get a dark image, its time to have it serviced.
good luck
mark
Sep 01, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Televison & Video Logo
Top Televison & Video Experts
