I have a snapper mower 2690249
I bought part # 1725250sm not sure where it connects
3 Suggested Answers
  • 174 Answers
SOURCE: Snapper SR130 riding mower won't start. Have
Is it getting fire to the plug, and is it a good blue flame. is the flame arcing between the electrode only. if not your plug could be fuel fouled. if it is fuel fouled toss it and get a new one. the wood ref key on the fly wheel may be bent . if it is bent it will throw it out of time. hope this helps
Posted on Mar 02, 2010
  • 6468 Answers
SOURCE: how to add oil to snapper lawn mower
if there is no dip stick then look about a inch above the base of the engine for a plastic screw about 1/2'' in dia
Posted on May 29, 2012
Brake system
Michael, Check the attached links, 1st link is snapper where you can get info from support,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Tractor Riding Lawn Mower Products Snapper Mowers Tractors
Snapper Lawn Mower Transmission Brake Clutch Parts
Snapper Brakes
Snapper Lawn Mower Parts Lawnmower Parts Discount Online Parts
Apr 09, 2016 | Snapper Garden
Mower belt diagram
Snapper Mower Manuals with belt info and diagrams can be found at:
Find Your Snapper Manual Parts Lists
http://www.snapper.com/us/en/support/manuals
Aug 12, 2014 | Garden
Engine wont fire....
There should be 1 black wire that grounds the coil(s) for kill. Be sure this black wire is not grounded when switch is in on or start position. It will be connected to the coil(s) at the flywheel.
Feb 10, 2013 | Snapper 21 hp* Briggs & Stratton...
I have a snapper sr928 riding mower it will crank but not start up and the neg battery cable will get hot and smoke
Check battery cable connections to make sure they are all tight. It may be getting hot from trying to start for to long. Also try starting with starting fluid. If it starts with starting fluid you probably need some work done to carburetor.
Mar 15, 2012 | Snapper Garden
What 2-stroke mix for a Snapper mower (Briggs & Stratton 6.5 HP)?
USE A 32:1 MIX. THE MORE THE RATIO OIL TO GAS MIX RATIO THE MORE COOLER AND LONGER LASTING THE ENGINE WILL BE. 40:1 IS FOR FULL OUT TROTTLE CHAIN SAWS ECT.
Mar 13, 2012 | Snapper Garden
Snapper Hi-Vac riding mower that won't start with starter
You may need a 300cca battery, an ignition switch or a solenoid to get things going again. I also would check to make sure the starter gear has not locked in the flywheel teeth; it will burn up the starter. You should be able to go to the snapper website and put your model of mower in and find the parts and diagrams you need.
Good Day.
Oct 26, 2009 | Garden
Snapper mower electric start problem
On most mowers, that red wire will connect to the battery. that could be your problem.
you didn't say if it is a rider or not, or how old it is.
Touch the wire to positive post on the battery, with the key off, remove quickly if it sparks.
if no spark, hold it to the battery while turning the key.
if the engine tries to start, connect it permanently.
Apr 14, 2009 | Garden
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
