Question about Sanyo Office Equipment & Supplies
Sanyo plc-ef10na turns of after 3-4 seconds of the warm up. no dust, not the lamp
  • 4 Answers
SOURCE: MULTIMEDIA PROJECTOR
I have a Sanyo XU35. Mine was starting up and showed a picture for about 15 - 30 seconds then shutting down. My lamp warning light was not coming on. When I put it in for repairs it turned out to be the lamp that needed replacing. The technician said it is not uncomman for the lamp to be going and the lamp warning light not to come on. I got my lamp on e-bay from ping_ngo for a great price.
Posted on Oct 02, 2007
SOURCE: sanyo plc se15 no light output
i all,hoping you can help with my problem.Ihave been given a sanyo plc se15 projectoe but with no lamp originally,the "lamp"indicator and "lamp replace indicator"were originally lit but when i have installed a new(23hrs use previously) lamp i have no light output and these 2 indicators are still lit! what voltage should i have on the lamp terminals(i a fully qualified electrician btw) is there some sort of reset procedure as i dont have any instructions etc
thanks in advance for any help
Posted on Mar 22, 2008
  • 3 Answers
SOURCE: Sanyo PLC - Z5 Lamp Replacement Light
Just had the same problem. Based on other suggestions on here I tried resetting the overheat switch, and IT WORKED!
So, you have to pull the 6 screws (one of them is shorter than the rest, remember where it goes) that hold the top on the projector. 3 are on the back, 3 on the bottom - look for the arrows next to the screws.
Put the projector on it's feet, and pull off the top. The button wires will still be connected, so just hold onto the top and find the black circle/shaft above where the lamp is. The shaft has white paint on the top/tip of it. Push it down with a light amount of force. You should hear/feel it click.
Put top back on, put screws in, and you should be good to go.
Don't forget to reset the lamp replacement counter in the menus.
Posted on Aug 01, 2008
nick_helpap
  • 334 Answers
SOURCE: reset lamp counter on Sanyo Projector PLC XU100
in main menu lamp reset in settings
Posted on Oct 07, 2008
SOURCE: sanyo plc-xp46 lcd projector
In the on-screen menu...
Press MENU, go to SETTINGS ICON, Move to Lamp Reset
Also, to see lamp hours used, press and hold the UP ARROW (on the unit, not on the remote) for 30 seconds while projector is on.
Posted on Jun 03, 2009
My Sanyo plc xu70 projector lamp is brand new after replacing it still has the same prolem.when I turn it on the power light gets green for seconds then red blinks then it stops..what do you think the...
1, the lamp is ok
2,the lamp ballast is ok
3,seems that the power supply or mother board is defective
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Jan 17, 2014 | Sanyo Projector Lamp for PLC-XU70
I have an Sanyo PLC-SU07E Multimedia projector. I
1,Turn the projector on,press the Menu botton
2,Press the Left ,Right,Up or Down to find the "lamp usage" and the reset option.
3,select "Lamp replacement counter Reset ?"
4,select "Yes"
Jerry China
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Aug 09, 2013 | Sanyo PLC SW20A Multimedia Projector
Hello.... Sanyo PLC-SU20N projector....shuts down within 3 seconds of turning on.
If the lamp doesn't strik, it will.
Check the ballast unit and lamp age.
Mar 19, 2011 | Sanyo PLC SU20N Multimedia Projector
My Sanyo PLC XE31 wouldn't switch on, bulb replacemetn lamp was lit. Changed bulb and now it switches on, green light shows, fans run, and then after approx 30 seconds the red light flashes and it switches...
1, the lamp is ok
have a nice day!
Jan 24, 2011 | Sanyo FOR PLC-XE31
Sanyo plc-xt10a will not power up. ready light is not on. power to unit is good.
First, check the lamp/lamp door--the door has a safety interlock that prevents power from getting to the projector. Make sure the power *is* getting to the unit by using a known-good power cord. Also, check the 3 air filters. If one or more was clogged with dust, the unit might have had a thermal sensor trip. There is also an internal fuse on the power supply which may have blown.When was the last time the projector worked correctly? Have there ever been any power problems related to that unit before? If the above checks yield no success, the projector will have to be repaired at a service facility. Hope I was of some help---Rick
Sep 09, 2009 | Sanyo (6103055602) Projector Lamp for...
Sanyo PLC-XU33 image displayed for 10 seconds then turns off
Owner decided to upgrade to a newer projector. Lamp was too expensive.
May 07, 2009 | Sanyo PLC XU33 Multimedia Projector
Lamp goes out after 10-15 seconds
Recently had a similar issue.
When I took the lamp out (Let it cool for awhile first), there was dust all over one side preventing air from the fans from cooling the lamp, so it shut itself off after getting too hot.
Apr 27, 2009 | Sanyo PLC XU48 Multimedia Projector
Sanyo plc-xp46 lcd projector
Feb 10, 2009 | Sanyo Projector Lamp for PLC-XU100,...
Sanyo PLC-XF46N projector shuts down before powering up completely
The Fix Ya rep suggested that I try the "Reset" button located next to the Audio out on the side of the projector; this solution proved to be the fix I needed. I was able to get the lamps to warm up and get into the menu to cut back the bulbs/power consumption on start-up, allowing the projector to function for a problem-free 4 hour period Unfortunately, I had the same issue this morning, but the same fix worked again.
Jul 06, 2008 | Sanyo PLC-XF46N LCD Projector
Sanyo plc-xu35
Sounds like a simple problem to fix but don't ask here unless you plan on signing up...take your projector to a "real" professional who'll actually speak to you.
Sep 12, 2007 | Sanyo PLC XU35 Multimedia Projector
57 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
Electro Med Services...
k24674
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
