Question about Exercise & Fitness
I am getting E 1 error message on my jazfit top49 trademill
Jazfit 5002 won't turn on???
If you wish to get some details; check the site http://electro-medical.blogspot.com/. Pull up older posts. Surf the site with patience. check for treadmill articles..
Mar 14, 2016 | Exercise & Fitness
Jazfit 4400 error 7
Sounds like it is time to replace the entire lift mechanism. Usually something like that would have a kit available for such repairs., I'm sure that'a not the first one to go bad. Call our local dealer and find out what the procedure for repairing the lift screw. You can probably pick up n after market replacement at a local parts house a lot cheaper than from a dealer. Good Luck.
Col. Dana Gillespie
Jul 05, 2014 | Office Equipment & Supplies
How do I get my I run reebok trademill to move
If you push start and the belt does not move then it seems like the is a problem. This problem may be the LCB.
Nov 24, 2013 | Reebok Vista Treadmill - RBTL13305
Fix error 2 treadmill
this is a probably a faulty sensor speed see the diagram attached. However depend of your mark , model, can be e1 ,tight the connector very well, and clean it. Test the s.speed for open or faulty.
Oct 19, 2013 | Exercise & Fitness
Incline and decline wont move, so the belt wont move either. Have a jazfit treadmill
1)LUBE THE DECK BELT, INMEDIATELY.
2) tES THE MOTOR INPUT VOLTAGE, IF THER ARE THE MOTOR NEED REPAIR.
3) tEST THE OUTPUT VOLTAGE BOARD, FOR INPUT VOLTAGE MOTOR, IF THERE ARE NOT THE BOARD IS FAULTY.
4) tRY TO RUN THE SOFTWARE CALIBRITATION.
SINCERELY.GOD BLESS YOU
May 08, 2012 | Exercise & Fitness
Jazfit treadmill wont work
hai, please check control board transformer output
Jul 03, 2009 | Spirit Esprit ET4 Treadmill
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
