Question about Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub Washer
How do I get to the belt of my amana series designer washer
I need to replace the belt on my washer I have the front off my not the back how do i get to it
  • 460 Answers
.this movie will teach you how to remove and to put it back,
http://www.youtube.com/watch?v=6XIsK3W_Qcg
this web page will walk you thru how to replace the belt
http://appliancejunk.com/forums/index.php?topic=97.msg1599#msg1599
I hope this information was helpful?
I like to tank you for the oportunity you give me to serve you please if you have any question or concer please e-mail me, I will be more then happy to assist you.
Sincerely
vickygomar
Posted on Jul 25, 2009
The washer (#WBSR3140GWW) does not spin on the spin cycle and the clothes come out very wet. What could be wrong??
The most probable trouble is the belt is streched and needs replacing. To replace belt remove front panel by placing a putty knife about two inches inward from the ends of front panel push the putty knife in and release clips for front panel.remove panel and belt will on bottom under the motor. On a lot of GE washers the oil in transmission leaks and soaks belt in oil so soon new belt will be oil soaked and needing replacment again if ya see a lot of oil in base belt will fix temporarly till its oil soaked,the fix then is to replace washer since trans. replacement is more than new washer
Gene
Aug 03, 2011 | General Electric WBSR3140GWW Top Load...
My washer wont spin or agitate and there was a burning smell
Hi
Older top load washers use a belt to drive to transfer the energy from motor to drum. However, if the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning "rubber" smell. The belt is located either from the back access panel or from the underside of the washer. The solution is to replace the belt with a new one. To replace the belt you can open the back lid of the washer
To replace the belt carefully pry up on front washer top to release plastic keeper pins, remove 2 Phillips screws from beneath lower front washer panel, slightly lift upward on panel to release. Now remove old broken belt, push new belt beneath large tub pulley and put belt on small motor pulley. After this push back belt tension /idler arm, start belt on large tub pulley, turn tub pulley by hand to run belt on, release tension on idler arm. Replace front panel and lower top.
Hope this helps... Please post back if you need more information.
Daniel
Jan 30, 2011 | Kenmore 24032\24036 Top Load Washer
My neptune washer smells like rubber burning when i wash clothes
Hi
Older top load washers use a belt to drive to transfer the energy from motor to drum. However, if the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning “rubber” smell. The belt is located either from the back access panel or from the underside of the washer.
The solution is to replace the belt with a new one. To replace the belt you can open the back lid of the washer. Remove the old belt & remove the bolt holding motor. Now remove the motor, remove & replace the 2 plastic isolators with the new ones supplied with the belt on the motor spindles. After re-installing the motor & bolt adjust the new belt.
Please post back for any further assistance.
Daniel
Jul 26, 2010 | Maytag Neptune MAH6500A Front Load Washer
Load was to heavy and I smelt burnt rubber now no spin
Hi
Older top load washers use a belt to drive to transfer the energy from motor to drum. However, if the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning “rubber” smell. The belt is located either from the back access panel or from the underside of the washer. The solution is to replace the belt with a new one. To replace the belt you can open the back lid of the washer
Please check this diagram for the part number F28(drive belt)--
Thanks
Daniel
Jul 24, 2010 | Frigidaire FWS833A Top Load Washer
I think a overloaded the washer and it wouldnt spin.
Frigidaire washer will not take a overloaded tub without causing belt problems.
Unplug the washer.
Remove the 2 screws on the very bottom of the front washer panel.
Slide the front panel down slightly and remove it from the cabinet.
Inspect the belt around the motor pulley and transmission.
If it is worn at all it needs replacing.
You could plug the washer back in and set it to Spin cycle and watch for the motor to turn and the belt slipping to verify a bad belt.
Keep your hands,fingers and tools away from all moving parts.
Jan 24, 2010 | Frigidaire FGX831F Top Load Stacked Washer...
Ge whdvh626 washer fills and drains. drun does not
I took off back plate and noticed belt was off. I also noticed that pulley was very loose. I ordered new pulley and belt and replaced myself. Thanks.
Dec 16, 2009 | GE WSXH208A Front Load Washer
Washer Stopped Spinning
My Frigidaire front loading washer is less than 2 years old and YES there is a belt, I am going to replace my 3rd belt this week.....the wheel on the back of the drum has moved enough, even after numberous times of tightening, that it has worn a HUGE hole in the back of the drum from the belts. I will NEVER buy another product from them again, due to not standing behind their product and sending a repair man to my home to fix it, then telling me that I will have to replace the drum....(ltf2940es0).
signed
DISCUSTED WITH FRIGIDAIRE!!!!
Dec 17, 2007 | Frigidaire GLTF2940ES Front Load Washer
Washer wont drain or spin
As long as the water is draining away okay,then it sounds like new carbon brushes for the motor are needed if belt is ok.Should cost 10 pounds or so for replacement.Turn off power via socket before removing belt and motor.Good luck...
Aug 27, 2007 | Bosch WFMC 3200 Front Load Washer
MAYTAG TOP LOAD WASHER
you don't say which model you have. one version uses two belts accesible by just tipping the machine back. Another version you must remove the front panel, and drop the pump and you'll be able to replace the one belt.
Jul 03, 2007 | Maytag Atlantis MAV7260B Top Load Washer
Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub Washer Logo
302 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
