Question about LG Computers & Internet
Lg wm2010c rear shock replacement
How do you get to this part? Not accessible
5 Suggested Answers
  • 29 Answers
SOURCE: replacing rear shocks
rear shocks are under the car, not inside the car.
Posted on Aug 27, 2008
arikrom
  • 528 Answers
SOURCE: my LG model # WM2010C is not draining. i had to
door switch need to be replace or bypass :) dont slam the door next time ... :) but it might be the water pump go bad so if the door switch not helping you will need to open the machine and see is the pump got bad
Posted on Jan 02, 2010
town41200
  • 56 Answers
SOURCE: replacing the rear shocks. How
if i remember right under rub in the floor or hump
Posted on Nov 23, 2010
  • 42 Answers
SOURCE: how to gain access t top of rear shock
access is at the sides behind the rear seat.
Posted on Jul 01, 2014
LG HE Washer model WM2010c, the unit was in spin cycle and bounced accross the room! Now the washer works but the basin is on a slant with the back end lower than the front!
Go to www.repairclinic.com and enter WM2010c. You will be presented with a list of common replacement parts and may be able to view a generic LG video showing disassembly.
Feb 02, 2017 | LG Washing Machines
LG HE Waher model WM2010c, rubber door seal slid and distorted the seal edge, on a spin cycle with a towel in it, how do I fix this?
If seal/boot is not torn, then remove front spring/wire clamp, reposition the seal/boot, reinstall the spring/wire clamp. Check out repair videos at appliancepartspros.com or repairclinic.com.
Feb 01, 2017 | LG Washing Machines
What are the most major issues with lg wm2016cw washers?
all washing machines suffer from same things.overloading throws balance off stuff in pockets finds its way to the pump too much powder is used causing blockages and soft water areas cause elements to fir up with limescale.eventally motor brushes wear.but theyre cheap to replace
Aug 05, 2014 | LG WM2010C Front Load Stacked Washer /...
How replace the rear shocks on mercedes 420 sel
You will need to remove the rear seats to access the hole just above the shock. Remove the bottom seat cushion first, then find the small bolts that hold the upper seat to the frame. Once removed, you will see access to the top of the shocks (might have a plastic covering the hole).
Feb 14, 2010 | 1991 Mercedes-Benz 420
My LG model # WM2010C is not draining. i had to
Jan 02, 2010 | Washing Machines
Do i have to remove the back seat to take rear struts off
Answer
REMOVAL - SHOCK ASSEMBLY
NOTE: Access for the nuts attaching the rear shock assembly upper mount to the vehicle is through the inside of the trunk.
Roll back carpeting on top of the rear shock tower to access shock mounting nuts.
Remove plastic cover from the top of the shock assembly.
Remove 2 nuts attaching the shock assembly upper mount/spring seat to the shock tower.
Raise vehicle on jackstands or centered on a frame contact type hoist. (Refer to LUBRICATION & MAINTENANCE/HOISTING - STANDARD PROCEDURE)
Remove the rear wheel and tire assembly from the vehicle.
Remove two fasteners holding the splash shield to the shock assembly upper mount.
Remove bolt attaching shock absorber to rear knuckle (Shock Absorber Attachment To Knuckle).
Remove the shock absorber from the rear knuckle first when removing the shock absorber from vehicle by pushing down on the rear suspension.
Move shock assembly downward and tilt top of shock outward, then remove shock assembly from vehicle through top of wheel opening
Nov 23, 2009 | 2002 Dodge Stratus
Are their any speical problems or tricks in replacing air adjustable rear schocks on a 2001 buick custom
Removal & Installation
  1. Remove the tire and wheel assembly.
  2. Support the control arm with a jack stand.
    0900c152802427b0.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Use support bracket tool J-23028-01 mounted on a jack to support the rear lower control arm
  3. Remove or disconnect the following:
    Electronic Ride Control (ELC) air tube from the shock Two bolts securing the shock to the control arm Trunk trim to gain access to the shock upper mounting nuts. Cover, the two nuts, and the reinforcement from the top of the shock Shock from the vehicle
    0900c152802427e1.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Remove the cover to gain access to the upper shock absorber mounting components-rear suspension
    0900c152802427e2.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Exploded view of the lower shock absorber mounting to the knuckle assembly-rear suspension
To install:
Install or connect the following:
Shock, reinforcement, and the two nuts. Tighten the mounting nuts to 15 ft. lbs. (20 Nm). Shock cover Trunk trim Shock-to-control arm bolts and tighten the bolts to 18 ft. lbs. (24 Nm) ELC air tube to the shock. Tire and wheel assembly
Apr 09, 2009 | 2001 Buick LeSabre
Replacing rear shocks
Aug 03, 2008 | 1995 Jaguar Vanden Plas
Computers & Internet Logo
56 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
