Question about Toshiba Televison & Video
The Recording option is greyed out on my Toshiba 620. I tried to select reset but it is greyed out in the setup/general menu. Is there a way to reset back to factory setting without using the menu?
Drummernick
  • 440 Answers
SOURCE: antenna setup for digital signals is grey and not available
is scan for chs lit up in options scan 1st ok
Posted on Feb 11, 2008
welcomejee
  • 10594 Answers
SOURCE: reset factory settings of sony cyber shot DCS-S650
Hello rkhanna,
Initialize function reset all data/ settings to factory defaults including date. I think, LCD Back Light of your cyber-shot is not working and its hardware problem. Contact nearest Sony repair shop.
Posted on May 27, 2008
pmf1977
  • 12 Answers
SOURCE: Setup for mass storage on phone wont work
plug in your usb lead
when the phone makes its noise to comfirm lead is plugged in
a usb icon should appear on the top menu bar
hold the bar and drag it down
you should see a notification USB connected
select it
select MOUNT
there ya go you should now be able to see it
Posted on Jan 08, 2009
sijudoniston
  • 134 Answers
SOURCE: IBM ThinkPad R50 restore factory settings
You might have deleted the Hidden partition within the drive .So you will not get the restore factory setting option
Posted on Aug 27, 2009
Professeur_D
  • 42 Answers
SOURCE: Reset Toshiba SD-5000 Dvd player to factory defaults
With most Toshibas, you could un-plug them and leave it for either 10minutes or 30minutes and it would reset. strange, I know. give it a try.
I also found this when working on a similar problem with your player, it may be relevant -you could try pressing the power button and another button..
sorry, I don't have one in front of me to test..
[[power off the player
hit the power button and immediately hold the HDMI select button
the 3 HD indicator lights will cycle and then pushing the HDMI select button will move through the resolutions.]]
Posted on Aug 31, 2009
I have a toshiba 42HL196 tv and i am trying to connect it to an external antenna. I cant find a channel scan option in the setup menu. The menu on my tv is not the same as the toshiba video.
First check the current source. Press the Input button on the TV (second from the left) or on the remote (below 9) until the correct Antenna input (Ant 1) is selected. Make sure that the antenna is connected to Ant 1 (the RF connection closest to the back HDMI ports). You only use Ant 2 if you have a coaxial (RF) cable connection. Then press Menu and then try the Setup menu again. You should be able to access the Installation menu and Terrestrial sub-menu now. Change the Input Configuration for Ant 1 to Antenna before attempting to Program Channels.
If this doesn't work, try resetting the TV to the factory settings. You'll have to access the Menu, go to the Installation sub-menu and then select the System Status and then System Information. Select Factory Defaults and enter the PIN. See the manual for the default PIN if you haven't changed it. Then confirm the reset. The manual is available from the product support page: http://support.toshiba.com/support/modelHome?freeText=2841536 . The direct link to the manual is http://cdgenp01.csd.toshiba.com/content/support/manuals/userguides/su2846615/42hl196_om_e.pdf . See page 29 for the PIN. Then try accessing the Terrestrial menu and scanning for channels.
I hope this helps.
Jan 31, 2017 | Toshiba Televison & Video
My H264 network DVR DH 3004 has reset it self to Chinese, how do I factory reset back to English? Thanks
Set the system parameters such as general setup, code setup, network setup, network service, output
mode, PTZ control, serial port setup and alternate patrol setup.
See the window pop ups. Here you can select the language from the drop down window
[systemtime? Set the system data and time.
? dataformat? Choose the data format:YMD,MDY,DMY.
? listseparator? Choose list separator of the data format.
? timeformat? Choose time format: 24-houror12-hour.
? language? English or Chinese.
? harddiskfull? Choosestop:Stop recording when the hard disk is full.
Choosecover: Coverthe earliest recording files and continue recording when the harddisk is full
[number? Only when the address button in the remote controller and the corresponding DVR number is
matched,the remote operation is valid.
? videoformat? PALorNTSC.
? latencytime? Set the latency time in 0-60.0 means no latency time.
? summertime? Choose the summer time option and pop the dialog box as followed.
For more details, refer its user manual.
https://electronicshelponline.blogspot.com/
Sep 12, 2016 | Home Security
Functions greyed out
Greyed Out Menu Options
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsMar 13, 2013 - Home > Setup & Installation > Greyed Out Menu Options Share on Google+ ... The menu options you have access to on many Samsung TVs ...
Antenna menu is grayed out - Forums - CNET
www.cnet.com > Forums > Samsung
CNETApr 21, 2013 - I have an HD over the air antenna going into my Samsung TV. However, the antenna as well as the Plug in Play menu is grayed out and can't be selected. Any ide... ... I think I might do 1 of the these two options. 1. Buy a new ... Samsung Support for Smart TV is terrible
Jun 11, 2015
TV Picture settings greyed out?
Sep 22, 2013
Samsung Smart TV update problems
Aug 29, 2013
Grayed-out menu settings with LN32A550
May 31, 2009
More results from www.cnet.com
Why is some options in TV menu grayd out? - SamyGO
Dec 25, 2015 | Televison & Video
No option to finalize disc
Either the disc is already finalized or there isn't enough space on the disc for finalization. Check if you have Auto-finalize enabled. Press Setup and go to the line "General Settings" with the up/down arrows. Press Enter. Then select Recording and Enter. Go to the Auto Finalize line and press Enter. Check both Disc Full and End of Timer Rec and see if these are set to On or Off. This option is explained on page 27 of the manual (page 29 of the PDF available from Funai Service http://www.funaiservice.com/manuals/SYLVANIA/ZC320SL8/ZC320SL8.PDF ). Remember that the finalization takes 20-50 MB on the disc.
I hope this helps.
Sep 07, 2014 | Sylvania ZC320SL8
Need manual for toshiba D-vr 610 recorder
For VHS -> DVD dubbing, make sure that you put in a compatible writable DVD with enough space for the video. For dubbing a DVD to VHS, make sure that you have a VHS tape with the erase protection tab on the tape. Insert the blank media in the correct side and the media that you want to record in the other. Press Setup on the remote, then select the General Settings menu. Then select Recording and finally Dubbing. (Use the up/down arrows to navigate the menus and press Enter to select an option.) Select the type of dubbing that you want to do. Press Setup to exit. Then press the DVD or VCR button (with the item to record) and press play and pause when you reach the point that you want to start the recording. Then press the other device button and press the Dubbing button (on the remote or the unit). Press Stop when done recording the selection.
Note: copy-protected videos can't be dubbed.
Crutchfield and Toshiba both have the manual for the DVR-610 . Crutchfield has the manual here: http://a248.e.akamai.net/pix.crutchfield.com/Manuals/052/052DVR610.PDF . See page 49 for a set of screen captures of the steps for duplicating a video.
I hope this helps.
Jan 20, 2012 | Televison & Video
I would like simple steps to transfer VHS to DVD on my Toshiba DVR620KY. I want to copy with the unit alone. Would appreciate your help. Thanks.
Hi ,
Please follow the instructions below to record from VHS to DVD. You may not be able to record from some pre-recorded VHS cassettes due to copyight protection embedded into the recording. You should stick some tape over the copy-protection tab on cassettes prior to recording if the tab has been removed. On some cassettes, there may be a slide switch which needs to be moved to the record/rec position. All pre-recorded cassettes will have the copy-protection tab removed.
1. Switch on the TV and DVD/VCR and select the correct input on the TV for the player.
2. Set the player for the recording direction, i.e. VCR to DVD . . .
- Press the SETUP key on the Toshiba remote to open the on-screen menu
- Use the UP/DOWN arrow keys to highlight GENERAL SETTING then press ENTER
- Use the UP/DOWN arrow keys to highlight RECORDING then press ENTER
- Use the UP/DOWN arrow keys to highlight DUBBING MODE then press ENTER
- Use the UP/DOWN arrow keys to highlight VCR > DVD then press ENTER
- Press the SETUP key again to close the on-screen menu
3. Press VCR to select VCR mode.
4. Insert the cassette you wish to record and fast-forward or rewind it to the position where you want to start recording from. Allow at least 5 seconds extra if not starting the recording from the beginning of a cassette.
5. Press PLAY then press PAUSE immediately.
6. Press DVD to select DVD mode
7. Insert a blank DVD
8. Press the REC MODE button to select the recording mode (XP / SP / LP, etc)
9. Press the DUBBING key to start the recording.
You can watch the VCR while it's recording. When you reach the point where you want the recording to end, press the STOP key. You do not need to repeat step 2 every time you record. The player will stay in VCR > DVD recording mode unless you change it.
Hopefully, you will now be able to record from VCR to DVD. If you need further assistance, please let me know.
Regards,
BElectric
Mar 26, 2011 | Toshiba D-VR4 DVD Recorder/VCR
My bf hit lock dvd and dont have a password. never set up one
As long as no password was actually entered, then access the general set up menu using your remote. There is a Disc Unlock option--choose it. If it does not allow you to access it--it is greyed out, for example, then exit the menu, and try to play a DVD. When it asks you for the password, try 136900. If that universal password is accepted, then again access the general setup menu, and choose the Disc Unlock option.
Hope this helps!!
Jan 06, 2011 | Philips DVP3962 DVD Player
It's stuck on disc lock , by accident and it's askin for a password how can we reset this player
Try using 136900. If this password works for you, then using your remote, access the general setup menu and choose the Disc Unlock option (which if you tried accessing it before, was greyed out.)
Hope this helps!
Oct 14, 2010 | Philips DVP3962 DVD Player
How to switch the tape speed on Go Video dvd/tape.
  1. Press SETUP,
  2. Toggle with the left/right arrow to the RECORDING OPTIONS (icon has a dot and the letters REC below it in the icon menus at the top of the set up screen.)
  3. While RECORDING options is selected, press the DOWN arrow to select VCR RECORD QUALITY.
  4. Press ENTER to go to the submenu.
  5. Use the ARROW UP/DOWN buttons to select the desired quality.
  6. Press ENTER to confirm selection.
  7. Press SETUP to exit the menu.
This is the same procedure for selecting the quality for the DVR recording speeds.
VHS speeds are:
SLP is 3x the recording time of SP.
DVR recording options are:
HQ=1 hour
SP=2 hours
EP=4 hours
SLP=6 hours
per disc.
Mar 18, 2009 | GoVideo VR3845 DVD Recorder/VCR
SYSTEM SETUP OR BOOT MENU FOR TOSHIBA A40
Restart the computer,
Right after the Toshiba logo appears start tapping the F8 key.
You will get an option to start in Safe Mode.
Select this option and let the computer start in Safe Mode.
If given the option you will want to log in as Administrator.
After you are logged in you will want to go to the Control Panel and then click on the Users link.
Select your account and choose to remove the password.
Reboot the computer and you should be able to access your account.
Jan 03, 2008 | Toshiba SATELLITE A10 A15 A20 A25 A35 A40...
Televison & Video Logo
26 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
