Question about Cub Cadet Garden
Replace solenoid on cub cadet 54 in lawn tractor
  • 376 Answers
SOURCE: How do I change the drive belt on a 1500 Series
Go to www.partstree.com click on Cub Cadet, enter the model number that's under the seat and that will give you a diagram.
Posted on Jun 13, 2009
SOURCE: My Cub cadet pto cluch bearing is froze up on my 2518 lawn tracto
A medium length extension (stuck through the grill), a swivel and an impact is all you need to remove the pulley with the frozen bearing. It's just a bolt, a washer, and a lock washer holding it on. You just need to remove the pulley to see if the bearing is stuck. Take the pulley to your local shop that can press bearings and you can be up and running for $20 dollars instead of $300. Here's a diagram I found on partstree:
http://www.partstree.com/parts/?lc=cub_cadet&mn=2518-48+Tractor&dn=0043700012
Posted on Apr 11, 2010
  • 4 Answers
SOURCE: I have a Cub Cadet lawn tractor that just stop
CHECK THE FUSE
Posted on Jul 02, 2010
daneinwv
  • 124 Answers
SOURCE: NEED A WIRING DIAGRAM FOR
My name is Dane and I am going to try to help you solve your problem.
Here's a link to where you can find your 3000 series service manual. You will find the schematics starting in chapter 17. Please find your correct engine configuration to match the correct schematic.
http://www.mymowerparts.com/pdf/Cub_Cadet/Cub_Cadet_Service_and_Repair_Manuals/
I hope I've helped. If you found this information useful, please leave me some THUMBS UP as deserved. Thank you! Dane
Posted on Dec 04, 2010
BAMOUT
  • 2478 Answers
SOURCE: Where can I find a wiring diagram for a cub cadet lawn tractor LTX1040 2010 model?
Posted on Mar 01, 2012
Cub cadet lawn tractor not starting?
There are several safety switches located on the tractor that could be giving you the problem. The starter solenoid may be bad as well.
Jul 10, 2016 | Cub Cadet Garden
Still working on a fix for my cub cadet lawn tractor. Starts and runs for a few seconds then quits. I am wondering if this symtom fits a carbuerator solenoid that isn't working. The solenoid clicks once...
if your talking about the solenoid sticking out the bottom of the fuel bowl that is just the fuel shutoff solenoid. when you turn key on that gets 12v hot all the time your running. when you turn off mower the solenoid extends outward inside the bowl to shutoff fuel going up to the venturi. if you take the bowl off and hold it against metal for ground you can watch the solenoid pull inward when you turn key on and outward when key off.
Aug 02, 2013 | Cub Cadet SLT1054 54 in. 26 HP Kohler...
54" Cub Cadet deck leaves strip of grass since I replaced the spindal
all three blades have to be lined up the same way when you put the belt back on.
Sep 09, 2012 | Cub Cadet Riding Lawn Garden Tractor 25hp...
Cub Cadet LT1050-Replaced the solenoid, had starter checked out-it's good, battery has full charge, but mower won't start. Help!!
You need to check that there is a 12volt supply from the low tention wire at the solinoid when the key is turned, if there is not either the switch is bad, or the wire from the switch is bad, or the fuse has blown.
Mar 04, 2012 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet is not turning over ---has new battery and new fuse
did you try to jump the solenoid? it could possibly be bad(the solenoid). if that is good, then i would check the starter next. i would almost guarentee its the solenoid tho, thats a really common problem. -Brian-
Oct 27, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet 1641 won't start....
sounds like the battery doesn't have enough power to crank the engine
May 12, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
29 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
