Question about Water Heaters
Richmond power vent 2 wont relight after a couple days have to cycle power to unit
SOURCE: power vent tankless heater has a down draft
I HAD THE SAME PROBLEM ON 2 OF THESE. I CALLED THE COMPANY AND THEY SENT ME A COMPLETE NEW VENT KIT WITH A DAMPER AT THE OUTSIDE WALL. HAVE HAD NO TROUBLE SINCE INSTALLING
Posted on Jan 25, 2010
SOURCE: Richmond power vent water heater won't stay lit.
I have a 40 gal richmond water heater with power vent and had a similar roblem. I call to talk to a tech and he suggested the vacuum switch. I ordered on line. It was $43 plus shipping and I installed it and it did the job. I happy.
Posted on Nov 05, 2010
SOURCE: I have a richmond power
Fastest way to solve water heater problem is call plumber or service technician.
Open following link for typical error codes for intellivent gas valve found on newer Richmond/Rhemm power-vent gas water heaters:
http://waterheatertimer.org/pdf/Intelli-vent-gas-valve2.pdf
http://waterheatertimer.org/pdf/Intellivent-service-manual.pdf
There is no 100% sure way for novice to repair gas water heater.
This is because electrical parts have to ohm-tested using information from service manual that is typically not sent with new water heater.
Also parts have to be cleaned. The gas pressure checked, air in gas line removed, burner tubes and pilot tube and combustion chamber cleaned, burner parts inspected for problems, air intake cleaned, exhaust vent tested.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Best way for do-it-yourselfer to solve water heater problems is to learn as much as possible about specific model by reading product manual that comes with new heater.
The manual will show error codes.
Then keep up with yearly service recommendations shown in manual.
Posted on Aug 04, 2011
  • 5245 Answers
SOURCE: Have 75 gallon gas water heater. Can I run 90 PVC off top power vent without vertical PVC first? Have Richmond unit.
1) I believe you can immediately elbow the PVC pipe.
There is a limit for how many elbows can be used between blower and termination, and limit is determined by diameter of PVC pipe.
2) Copy following link for venting resources and typical Rheem and Richmond power vent manuals, and diameter-elbow pdf from Bradford White.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#venting
3) Richmond is Rheem. Product manual will show specifications for venting.
Product warranty is voided if installation does not follow specifications shown in manual.
Posted on Feb 20, 2013
  • 11 Answers
SOURCE: richmond power vent 2 flashes code 4-4
Sounds like a pressure switch or simular sensing device that is not proving positive, thus a possible vent blockage or defective sensing device.
Posted on Mar 05, 2013
Richmond 6GR50PVEZ-42P power to Gas valve but does nothing but blinking blue light
Following link has power vent troubleshoot resources, with error codes and manuals:
http://waterheatertimer.org/power-vent-water-heater-troubleshoot.html
Rheem/ Richmond series products do not have service manuals posted online
Nov 06, 2017 | Water Heaters
Feb 20, 2013 | Rheem Richmond 75 Gal Natural Gas 6 Year...
RichmondG40PVpower vent gas water heater
1) Type and brand water heater unknown.
Copy following link for Rheem-Richmond tankless error codes:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
2) Question posted under Richmond tank-type power vent.
Error code 24 appears to be Rheem-Richmond tankless water heater.
3) Add a comment with more information about type, brand, age of water heater including what you have tried so far.
4) Call service technician to catch up on required yearly maintenance.
Dec 28, 2012 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
I have a richmond power vent water heater model number 6G40POW-40F.It will run for 2 min then shut itself off then restart and do the same thing all over.Then 2 lights come on and it wont run. Any help...
Aug 03, 2011 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Richmond power vent water heater won't stay lit. I've reset the unit several times and the unit will run for about 10-15 minuets then shuts down (into lock down). Then I have to shut it off unplug it and...
Mar 29, 2010 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Water Heaters Logo
43 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
