Question about Garden
I have a Sears Craftman pressure washer model 580.752100 and would like to change the pump oil. How much & what type of oil is required?
Parts list identifies part# 190585GS,which is identified as an OIL BOTTLE. It is further identified as pump oil.
jj505
  • 195 Answers
SOURCE: power washer not starting what type of oil to use dpd3100
10 w 30 for engine
10 w 30 and specify for [PUMP OIL]
ANY AUTO STORE
THANKS AND PLEASE RATE JJ505
Posted on Apr 14, 2009
  • 174 Answers
SOURCE: How much oil in pump...Craftsman 2200 PSI pressure washer
Hello:
Best to use NON DETERGENT 10W30. Be sure you fill the reservoir only 1/3 to less than 1/2 full.
Posted on Aug 26, 2009
  • 583 Answers
SOURCE: Type of oil for pressure washer pump.
any anti foaming oil ,you can use multi grade but it goes milky with minute air bubbles and gives the appearance of getting water in.most manufacturers recommend anti-foaming oil
Posted on Sep 05, 2009
  • 56 Answers
SOURCE: what oil, how much oil, and how change oil on pump of ry80030a
The RY80030 Pressure washer has a Faip pump on it. There is no drain plug and you do not change the oil in it. The pump only holds 4.5 ounces of oil and the pump only has a life expectancy of between 30 and 50 hours. If for some reason The oil gets drained, remove the pump from the motor and set it on a bench standing up on end. Remove the allen bolts holding the water and oil sides of the pump together.Be carful as the piston springs are under load. fill the pump 3/4 of the way full and replace the head. there is a smoke stack on the pump but it is simply a breather not an oil fill.
If this helps please rate this post. Bill the Tech
Posted on Jan 04, 2010
fixitriteman
  • 431 Answers
SOURCE: LOW OIL PRESSURE ON 2007 GMC SIERRA 1500. CHANGED
have it tested using a manual gage if still low then main baring ore most likely bad that would mean a over hall if is really low and bearings bad should be making rattle noise when started up first few seconds
Posted on Mar 11, 2010
Testimonial: "thanks alot.truck is not making a rattling noise.we did check it with a manual gauge.it read about 10 at idol. press. gets better as you incr speed"
What is oil type for my pressure washer pump (K2300G)?
PDF]Service Handbook High-Pressure Washer Pump 3.532-629.0
www.mymowerparts.com/...Pressure-Washer.../Karcher-Pressure-Washer...
Sep 28, 2001 - For Karcher Pressure Washer Parts Call 606-678-9623 or 606-561-4983 .... Oil Bath. The swash plate and pistons are bathed in oil. (oil type ...
Oct 21, 2015 | Garden
What type of oil does the pump use? how much?
8.5 oz. to the red dot on the site glass.
SAE 30 / 30 wt Non Detergent Oil from your local auto parts house.
Oct 02, 2009 | Caterpillar Cat Pump Pressure Washer Pump...
I have a craftman snow thrower, model#536.886122, serial#632722946 and I'm in need of a manuel.
Manuals of Sears products are available through their 'Parts Direct' system and have been resonable in price. The last one for a riding mower cost ~$7.00
Sep 21, 2009 | Tools & Hardware - Others
Does pressure washer pumps need oil or not?
There are certain pressure washer that do require oil. It depends on your make and model of he machine.Usually they require, when it is a gas powered unit and then if its a 2 cycle gas engine they take a gas/oil mix in the tank and do not require oil in a crankcase.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 03, 2009 | Briggs & Stratton Garden
Need owners manual for 2.2cu in sears craftman chainsaw
Download the PDF version from http://www.hammerwall.com/Manuals/Craftsman/Description/358.352161/Craftsman%2016%20Inch%20Bar%20Gas%20Chain%20Saw/L0708268/
Aug 27, 2009 | Garden
Do you have to use oil in the pump and if so type,how often.
water pumps doesn't require oil in the pump; but your engine does require. if the water pump is of "self priming" type, fill the pump casing with water before starting the machine to avoid damage to the water seals.
May 22, 2009 | Campbell Hausfeld PW1750 Electric Pressure...
How to change oil in a pressure washer
From the manual CleanShot 2050 Briggs and Stratton
Change Pump Oil
1. Drain engine oil and fuel from pressure washer
2. Use an 8 mm allen wrench to remove black pump oil cap between high pressure outlet and garden hose inlet.
3. Tiltl pressure washer to drain oil into an approved container until it drips slowly from pump.
4.Tilt pressure washer in opposite direction and empty premeasured pump oil bottle into same opening (a small funnel may be helpful) [THIS IS WHAT THE MANUAL SAYS-NOT CLEARLY WRITTEN IN MY OPINION OR WRITTEN BY SOMEONE FOR WHOM ENGLISH IS A SECOND LANGUAGE]
5. Install black pump oil cap and tighten firmly.
6. Set pressure washer in upright position. Add fuel and engine oil.
From the engine manual use synthetic 5w-30, 10w-30 from -20 degrees F to temperature of 100 degrees F.
Change oil after 5 hours of operation initially. Before tipping to drain oil, remove fuel from fuel tank by running until tank is empty. Remove oil cap and dipstick and tip engine. Keep spark plug side up. Or remove drain plug from the bottom of pressure washer with a ratchet and square extension and drain oil from bottom. (fuel does not have to be removed)
May 21, 2009 | Briggs & Stratton Pressure Washer...
Oil for a troy bilt 2550 psi pressure washer pump
What fluid and how much is required in the Troy-Bilt 2550 power washer pump?
May 17, 2009 | Briggs & Stratton Garden
Craftsman Pressure Washer Model #580762250 Serial # 4033531 Need a manual for this particular machine. When it builds up pressure it cuts off.
I believe sears will give you one free;
http://www.managemyhome.com/mmh/lis_pdf/OWNM/98070390.pdf
you have to download it, but it isn't too much trouble, page 16 lists a whole laundry list of possible problems. Word of advice, change your oil in the pump regularly, if it is burnt appearing you might want to consider replacing rings etc and complete teardown, we didn't and trashed the pump.
Jul 11, 2008 | Electrical Supplies
Garden Logo
59 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
