Question about Refrigerators
My NEC FR358 Fridge is keeping cool and the freezer is working great but it squeals periodically What could be causing this and is it repairable? Cheers
SOURCE: Freezer works great, as it should, but fridge is only keeping items room temp. I have the setting at the coldest setting: #7. What is wrong?
Here's what I did, I defrosted! I found out that the fridge temp is monitored and maintained by the freezer. Because we had a power outage one night, my freezer thawed while we all slept and then when power came back on, freezer re-froze but this cause an ice build up on the vent on the back wall of the freezer. Well, ice must have been in one (or more) vents, causing blocked air flow in my top half of the refrigerator. I turned the dial in the freezer to "off" which also shuts down power to the fridge half. I then unplugged the refrigerator, hauled all my food items into coolers, opened the freezer door and refrigerator doors and left them open for a little over six hours. I took advantage of this empty fridge and freezer and wiped everything down. After this time frame passed, I plugged the fridge back in, turned the freezer dial to my preferred freezer temp, and wah-lah! Within two hours I had a cold fridge and solid ice cubes in the freezer. I then put all my food items back into their appropriate compartments, and went to work. Bear in mind, a total 24-hour period is needed for the fridge to re-set itself, but still, after two hours the fridge was noticeably cold. Who knew, besides our parents' generation: DEFROST!
Posted on Sep 11, 2008
  • 2920 Answers
SOURCE: fridge quit cooling after i moved it
did you tilt it when you moved it and then when u got it in place plug it in? if so youve got compressor problems, anytime you tilt a fridge you have to let it set for several hours to allow the oil to get back to the compressor or you ruin the compressor
Posted on Jan 01, 2009
  • 10865 Answers
SOURCE: frige light on not cooling,freezer fan working but not freezing
Hello there. Let me see if I can assist you.
A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Posted on May 27, 2009
  • 212 Answers
SOURCE: Amana energy saver not keeping fridge section cool enough. HELP!
if there is frost build up on rear wall of freezer section the unit is not going through defrost cycle which builds up frost on evaporator and restricts cold air flow to the fresh food section. one of three things are bad. defrost heater, defrost thermostat or defrost timer. if no frost on rear wall you might be low of freon.
Posted on Jun 24, 2009
Sea Breeze
  • 4654 Answers
SOURCE: our freezer keeps freezing up and it causes it to
If you tell me the model number found in locations in photo below I can help you.
Posted on Jul 14, 2009
Hotpoint Future fridge freezer - freezer working well but top of the back of the fridge has a large build up of ice ??? And doesn't appear to be keeping the food cold enough
here are lots of things that can cause cooling problems. One of the most common causes of poor cooling in a frost free refrigerator is a defrost system failure. In such a case one or the other compartment may appear to be keeping proper temperature but that too may change in a short period of time. The fridge compartment's temperature rise is usually (but not always) the first to be noticed. Frost" and "Ice"
There is a difference between "frost" (a white, snow-like substance) and "ice" (usually clear and solid). When referring to what is seen during an inspection, please keep this distinction in mind as the possible causes for each are often very different. The Defrost System
Inspecting the (usually rear) wall of the freezer compartment for a frost build up is necessary. (In the case of many GE top freezer models, check the freezer's bottom panel.) If there is a frost coating on it, it is often a sign of excessive frosting beneath it. Sometimes however the evaporator cover panel will actually need to be removed (see the illustration below) before an excessive frost build will visible.
The refrigeration system's evaporator (cooling) coil is usually in the freezer compartment. This evaporator will periodically frost over and have to be defrosted by means of a heating system. When the defrost heating system fails, the frost can accumulate to such a degree that airflow throughout the appliance is hampered. There may be just enough air circulation to cool the freezer section but that will eventually stop too.
Sep 28, 2016 | Hotpoint Refrigerators
Freezer only gets down to around 18 degrees but fridge is fine. No frost on the freezer evaporator fan is running
Modern consumer refrigerators only have coils in the freezer. In the lower back of the freezer there is a small fan and possible a damper (flap that opens/closes) to push cold air from the freezer to the refrigerator. Given that the freezer is 18 deg, it's probably cold enough to keep the fridge area at typically 34 deg.
So the cooling system (compressor, coils, thermostat) are not working properly to keep the freezer at, typically 0 deg. Possible causes: partial loss of refrigerant gas, icing around evaporator coils (in freezer), compressor failing, dust clogging condenser coils (under fridge), condenser fan clogged or broken (under fridge), thermostat failure.
I'd start with condenser. Remove the slotted trim at the bottom front and look in with a flashlight. Are the coils clean? Pull out the fridge and remove the lower back cover (usually cardboard). You can now see the coils and fan. Clean and blow them out.
If it's icing, it probably means freezer door not closing tight. If auto-defrost not working properly it would probably get worse over the period of a few days so not likely.
Apr 21, 2016 | Frost Refrigerators
Freezer works fine, fridge compartment cools but has stopped cooling as good and has recently stopped cooling. did a manuel defrost on fridge and freezer worked fine afterwards, now doing the same thing...
Oncce the fridge was shut off and left for a while the cooling had come back . If frost is seen it is a good indication as the compressor is working with sufficient gas within.
If after about 6 hours you observe cooling it is possible that the defrost timer is faulty.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
replace the defrost timer, heater or thermostat one you have confirmed to eliminate one by one.
Mar 11, 2011 | Hotpoint  14.9 Cu. Ft. Top-Freezer...
Getting very hot in the middle betweenthe fridge and freezer
The condenser fan located on the bottom near the compressor is not circulating well enough to keep the compressor at a good operating temperature causing the compressor to shut down for longer periods of time until cool enough to run again. Clean the coils good and replace condenser fan and you will be fine. The fan works as a cooler for the compressor. Imagine working in the yard on a hot day wearing a mask over your nose and mouth. Your body shuts down quicker because you have to take more rest due to the restriction of fresh air. Same applies to the compressor. Hope this helps. Rick
Apr 27, 2010 | Samsung RS2630SH Side by Side Refrigerator
Refrigerator not keeping things cool and freezer
this is usually caused by dirt either around the fan if its a built in fridge, or around the cooling fins at the back of the fridge.Make shure you unplug the fridge before investigating what is wrong.
Apr 13, 2010 | Hotpoint HSS25GFP Side by Side...
I cleaned out my fridge completely today. Took all the shelves out, cleaned the interior, all the glass over a three hour period. The freezer is working just fine, the fresh food area is nice and dry but...
Manufacturers suggest that it takes approximately 24 hours for the temperature to stabilize in both your freezer and fresh food compartments after being turned off for an extended period of time. Adjust temperature settings to the "half-way" mark for both freezer and fresh food compartments. Allow a period overnight and recheck the temperatures. Also check the condenser coil (usually located underneath the appliance). If clogged with dirt/lint, it needs to be cleaned (carefully) with a condenser coil brush (can be purchased at Home Depot or Lowe's). Prior to cleaning condenser coil, turn off appliance (there is a condenser fan motor and blade operating while on). Be careful not to damage copper tubing (refrigerant in tubing)!
Feb 16, 2010 | Refrigerators
Not getting any water out of the dispenser, but its making ice
The water dispenser on my GE profile fridge stopped working for a couple days. The refrigerator and freezer temperatures have fluctuated over the past several months causing fridge items to periodically freeze and freezer items to periodically thaw. GE tech came today identified a bad circuit board, which he replaced for a cool $300. Ouch. Fridge is only three years old. Oh yeah, the icemaker also has a broken tab which causes it to jam every couple weeks. We have GE Profile appliances throughout our kitchen and they all work great except for the fridge :-( I hope GE engineers read this post. If so, get to work! LOL
Feb 03, 2010 | GE Profile PSW26P Stainless Steel Side by...
Fridge side not getting cool, freezer works great
is the fan running in the freezer?.
is ther ice build up on the back wall of the freezer?
check fridge control, set midway, same with freezer control
Jul 01, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Jun 24, 2009 | Amana ABB1927DE Bottom Freezer...
Sep 10, 2008 | Maytag MBB1954G Bottom Freezer...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
