Question about Yahoo Computers & Internet
On yahoo newsroom I cannot advance to next' for more information
Manual
This is not camera lenses it is interior / exterior banner printer paper.
See the factsheets for the product at:
http://www.hp.com/hpinfo/newsroom/press_kits/2009/aiim2009/Factsheet-HPDurableBannerwithDuPontTyvek.pdf
http://www.hp.com/hpinfo/newsroom/press_kits/2009/GSBatPrint09/HP_Durable_Banner_with_DuPont_Tyvek_FS.pdf
Oct 11, 2014 | HP Cg821a Durable Banner With Dupont Tyvek...
How to change settings in Outlook to delete message from server after downloading
Hi, follow the steps below. Don't change any of your settings since they already work, but when you get to step 7 this is where you check whether or not you want to remove the emails from the sever.
Open Outlook 2003 then:
  1. Click Tools ' E-mail Accounts.
  2. Select Add a new e-mail account and click Next.
  3. Select POP3, then click Next.
  4. Enter the following information:
    • User Information
      • Your Name: Type your name as you'd like it to appear when you send an email message.
      • E-mail Address: Type your Yahoo! Mail Plus email address (for example, jo.bloggs@yahoo.com).
    • Server Information
      • Incoming mail server (POP3): Type pop.mail.yahoo.com
      • Outgoing mail server (SMTP): Type smtp.mail.yahoo.com
    • Login Information
      • User Name: Type your Yahoo! ID (your email address without the "@yahoo.com").
      • Password: Type your Yahoo! password.
    • Check the Remember password checkbox if you don't want Outlook to prompt you for your password each time you check your mail.
    • Do notcheck the Log on using Secure Password Authentication (SPA) checkbox.
  5. Click the More Settings button. The Internet E-mail Settings dialog box appears.
  6. Select the Outgoing Server tab:
    • Check the My outgoing server (SMTP) requires authentication checkbox.
    • Make sure that Use same settings as my incoming mail server is selected.
  7. Select the Advanced tab:
    • Under "Incoming server (POP3)," check the This server requires an encrypted connection (SSL) checkbox. The number in the "Incoming server (POP3)" field usually changes automatically from 110 to 995. If it doesn't, type 995.
    • In the Outgoing server (SMTP) field, type 465. Under it, check the This server requires an encrypted connection (SSL) checkbox.
    • If you want to save your Yahoo! Mail messages on both the Yahoo! Mail server and on your computer, check the Leave a copy of messages on the server checkbox. If you want your messages to be deleted from the Yahoo! server once Outlook has downloaded them onto your computer, leave the box unchecked.
    Note: After your messages are deleted from the server, we cannot retrieve them.
  8. Click OK to close the Internet E-mail Settings dialog box.
  9. Click Next and then Finish.
  10. Close and restart your Microsoft Outlook.
Jun 05, 2012 | Microsoft Office Outlook 2003 for PC
Can I configure microsoft outlook 2007 to work with my yahoo e-mail if i'm connection through clearwire at home and I'm not on a network
If you are not connected to the internet, you can only work offline, and for example, if you write an email it will not send until you do connect to the internet.
You can configure Outlook 2007 to work with Yahoo.
If you want to "POP" your Yahoo! Mail into your Outlook 2007 application, here's how:
  1. From the Tools menu, select "Account Settings." If you do not see "Account Settings," place your cursor over the two arrows at the bottom of the list to display more choices.
  2. On the Email tab, click New.
  3. Check the box next to the first option, "Microsoft Exchange, POP3, IMAP, or HTTP" and click Next.
  4. In the Your Name box, type your name as you'd like it to appear when you send a message.
  5. In the Email Address box, enter your Yahoo! Mail address (for example, "user@yahoo.com").
  6. Check the box for "Manually configure server settings or additional server types" and click Next.
  7. Check the box next to the first option "Internet E-mail" and click Next.
  8. In the Server Information area, under "Account Type" select POP 3 from the pull-down menu.
  9. In the Incoming mail server field, enter: pop.mail.yahoo.com.sg
  10. In the Outgoing mail server (SMTP) field, enter: smtp.mail.yahoo.com.sg
  11. In the Login Information area, in the User Name field, enter your Yahoo! ID (your email address without the "@yahoo.com").
  12. In the Password box, enter your Yahoo! Mail password.
  13. Check "Remember Password" if you don't want Outlook to prompt you for your password each time you check your mail. Handy!
  14. Do not check the box labeled "Log on using Secure Password Authentication (SPA)."
  15. Click on the More Settings button.
  16. Click on the Outgoing Server tab and check the box next to "My outgoing server (SMTP) requires authentication."
  17. Click on the Advanced tab.
  18. Under "Incoming Server (POP3)", check the box next to "This server requires an encrypted connection (SSL)". The port number in the "Incoming Server (POP3)" field should automatically change from 110 to 995. If it doesn't, make sure the port number is set to 995.
  19. Under "Outgoing Server (SMTP)", check the box next to "This server requires an encrypted connection (SSL)". Enter port number "465" in the "Outgoing Server (SMTP)" field.
  20. If you'd like to keep a copy of your email messages on the Yahoo! Mail server, check the box next to "Leave a copy of messages on the server." If you want to delete your messages from the Yahoo! Mail server after viewing them in Outlook, don't check the box.
  21. Click the OK button.
  22. Click the Next button on the Email Account Wizard, then click Finished.
  23. Would you like your Yahoo! Mail inbox to be your primary inbox in Outlook 7? If so, click the Tools menu and select "Account Settings." If you don't see "Account Settings," place your cursor over the two arrows at the bottom of the list to display more choices.
  24. From the list, select the pop.yahoo account you've just added and click the Set as Default button.
  25. Click the Close button. You're done!
Troubleshooting instructions
If you followed the above configuration steps, you should be all set. However, if you cannot send or receive mail with your email client, try the following tips.
The Yahoo! Mail SMTP server requires authentication. Make sure you have enabled SMTP authentication. To turn this setting on, follow these steps:
  1. From the Tools menu, choose "Account Settings."
  2. Select the "E-mail" tab.
  3. Select your Yahoo! Mail account and click Change.
  4. Click on the "Outgoing Server" tab.
  5. Check the box next to "My Server Requires Authentication."
  6. Please make sure that "Log on using" is not checked.
  7. Click OK.
To control deletion of messages from the Yahoo! Mail server:
  2. Click on the "Email" tab.
  4. Click on the "Advanced" tab.
  5. Check "Leave a copy of messages on server" if you want to save your Yahoo! Mail messages on the Yahoo! Mail server as well as on your local computer. Please note that setting your email client to remove messages from the server will cause your messages to be deleted from the server. Once the messages are deleted, we are unable to retrieve them.
  6. Click OK.
  7. Close Microsoft Outlook and restart.
We strongly recommend that you enable SSL for both POP and SMTP, as detailed in the above instructions. This will ensure that your Yahoo! ID, password and email messages are transmitted securely between your mail client and the Yahoo! servers. However, if you choose to not use SSL for SMTP, your email client will likely default the SMTP port to 25. If your ISP blocks port 25 or if you're unable to send email, then you will need to use port 587 when sending via Yahoo!'s SMTP server. To make this change, please follow the directions below:
  1. From the "Tools" menu, select "Account Settings"
  2. Select your Yahoo! POP account and click on Change.
  3. Click on the "Advanced" tab.
  4. Click OK and Close.
May 05, 2011 | Microsoft Office Standard 2007: Windows
I am tying to set up yahoo account on thunderbird. i can send email but not receive.. i have tried changing server settings and port settings
Much more common is a sending issue. Often you have to send through your ISP server, contact them for what that server is, if you have sending issues.
I found directions for Outlook, which should be similar to Thunderbird:
Look closely at requires authentication settings....
Note: You must be a Yahoo! Mail Plus user to read Yahoo! Mail in an email reader program such as Microsoft Outlook. Click here for information about subscribing to Yahoo! Mail Plus.
To read your Yahoo! Mail Plus using Microsoft Outlook 2002 or 2003, follow these steps:
  1. From the Tools menu, select Email Accounts.
  2. Select Add a new email account and click Next.
  3. Select POP3 and click Next.
    • User Information
      E-Mail Address: Type your Yahoo! Mail Plus email address (for example, testing80@yahoo.com).
      Incoming mail server (POP3): Type plus.pop.mail.yahoo.com.
      Outgoing mail server (SMTP): Type plus.smtp.mail.yahoo.com.
    • Login Information
    • Select the Remember Password checkbox if you don't want Outlook to prompt you for your password each time you check your mail.
    • Do not select the Require logon using Secure Password Authentication (SPA) checkbox.
  5. Click More Settings. The Internet E-mail Settings dialog box appears.
    • Select the My outgoing server (SMTP) requires authentication checkbox.
  7. Click the Advanced tab:
    • Under Incoming Server (POP3), select the This server requires an encrypted connection (SSL) checkbox. The number in the Incoming Server (POP3) field usually changes automatically from 110 to 995. If it doesn't, type 995.
    • In the Outgoing Server (SMTP) field, type 465. Under Outgoing Server (SMTP), select the This server requires an encrypted connection (SSL) checkbox.
    • If you want to save your Yahoo! Mail messages on both the Yahoo! Mail server and on your computer, select the Leave a copy of messages on the server checkbox. If you want your messages to be deleted from the Yahoo! server once Outlook has downloaded them onto your computer, leave the box unchecked.
  9. Click Finish to close the Add New E-mail Account dialog box.
  10. Click Close to close the Account Settings dialog box.
Troubleshooting tips
If you still can't send Yahoo! Mail from Outlook, you might be accessing the Internet through an ISP that is blocking the SMTP port. If this is the case, try using port 587 when sending email via Yahoo!'s SMTP server. To make this change:
  1. From the Tools menu, select Account Settings. The Account Settings dialog box appears.
  2. Select your Yahoo! Mail Plus account and click Properties. The Change E-mail Account dialog box appears.
  3. Click More Settings. The Internet E-mail Settings dialog box appears.
  4. Click the Advanced tab.
  5. In the Outgoing Server (SMTP) box, type 587.
  6. Click Apply, and then click OK to close the Internet E-mail Settings dialog box.
  7. Click Close to close the Account Settings dialog box.
Oct 17, 2010 | Yahoo Mail
Dea .sirs I cannot get my pop settings to work and cannot send e mail please assist thank you jeremy silwood
Please follow the settings below:
* Click on Tools> Account Settings.
* Under the Account Settings window, click on the Email Tab, click New.
* Select Microsoft Exchange, POP, IMAP, or HTTP > click Next.
* Under the Auto Account Setup, place a check in the box called Manually Configure
Server settings or additional types, click Next.
* Select Internet Email, click Next.
Next, fill out the following information:
* User Information
Your Name: Your Name (e.g., Joe Black)
Email Address: username@email (e.g., jblack@yahoo.com)
* Server Information
Account Type: POP3 or IMAP
Incoming Mail Server: pop3.yahoo.com or imap.yahoo.com
Outgoing Mail Server: smtp.yahoo.com
* Logon Information
User Name: username@ (e.g., jblack@yahoo.com - This must be your full email
address)
Password: password
Check the box remember password if you would like the system to remember your
password. Please note: requiring your password to be entered each time you open
Outlook will ensure your email is better protected and will prevent others from
accessing your email without your consent.
* On Outgoing Server tab, check the box My outgoing server (SMTP) requires
authentication and confirm that the radio button Use the same settings as my
incoming mail serveris selected.
* On the Advanced tab, choose the following settings:
Incoming server (POP3) > Place a checkmark in the box next to This server requires
or
Incoming server (IMAP) > Place a checkmark in the box next to This server requires
Enter port number: 25, 2525 or 465
Use the following type of encrypted connection: Auto
* (For POP3accounts only) On Advanced tab, under Delivery, adjust the settings to
meet your requirements.
Click OK. Finally click Next, and then click Finish.
Feb 13, 2010 | Yahoo Mail
It says yahoo id or password incoorect and is i think its been hacked
Reset your password easily by following this link http://edit.yahoo.com/forgot select the option My Password Doesn't Work or I forgot my password as shown in image below..
Image#1
clicking on Next button the page will redirected to below showing page...
Image#2
put your ID correctly in the box and as well as captcha codes as showing in image...
click Next it will ask you information...as below...
Image#3
if your alternate email address is right press Next , it will go for next page like below
Image#4
if your alternate email address is not working follow image 3 2nd option....click next you will be asking for SQ answer...like below...
Image#5
if you put right information here you will be done....
Again if after 2nd image the below window comming contact Yahoo! Customer Care toll free number...
Image#6
For further help please be with us...Good luck
Dec 02, 2009 | Yahoo Mail
How do I install a yahoo email to outlook 2003
This is to inform you that Yahoo provides Outlook or Independent mail agent services for their Premium/Plus users. Well if you having a
Mail Plus account just open your outlook.... Click on Tools, then click on E-mail Accounts, choose option Add a new e-mail account, on Next choose POP3, click Next, in User Information type your screen name as Name, then E-mail address, type full yahoo mail address as User name, type your Password correctly, select the box Remember Password, in the box Incoming Mail Server (POP3) type plus.pop.mail.yahoo.com and plus.smtp.mail.yahoo.com for Outgoing Mail Server(SMTP), Then click Next and click Finish...Thats all....for further help please be with Fixya...Good Luck
Nov 10, 2009 | Yahoo Mail
My yahoo Id and massenger id (gopal_soni23@yahoo.compassword i for get and information while Account opening i forget so please solve how i access my yahoo a/c / Massenger please tell me. My another id for...
If you forgot all information there will be another way to reset your password that is through alternate email address which you provided during registration...
Go to http://edit.yahoo.com/forgot
select any of the first two options (I forgot my password / My password doesn't work )
see the image below...c6329c3.jpg clicking on Next button the page will redirected to below showing page...
click Next it will ask you information...see below image there are some short hint's on right side of the alternate email address box to find your alternate email address which linked with this account for password resetting purpose....
I think this will help you to reset your password and get your ID back....
Thanks for subscribing Fixya
All the best
Nov 06, 2009 | Yahoo Messenger
Is it possible to connect MS Outlook to yahoo.com?
yahoo's UK page has instructions on this and here they are: id rather paste theirs than type my own...
  1. From the Tools menu, choose "Accounts."
  2. Select the "Mail" tab.
  3. Click the "Add" button.
  4. From the Add menu, click "Mail."
  5. In the text box labelled Display Name, type your name and click "Next."
  6. In the Email Address box, type your Yahoo! Mail address (be sure to include "@yahoo.com") and click "Next."
  7. Under "My incoming mail server is a…" select "POP3."
  8. Type "pop.mail.yahoo.co.uk" in the Incoming Mail (POP3, IMAP, or HTTP) Server box.
  9. Type "smtp.mail.yahoo.co.uk" in the Outgoing Mail (SMTP) Server box.
  10. Click "Next."
  11. In the Account Name box, type your Yahoo! Mail ID (your email address without the "@yahoo.com").
  12. In the Password box, type your Yahoo! Mail password.
  13. If you want Outlook Express to remember your password, check the "Remember password" box.
  14. Do not check the boxes labelled "Log on using Secure…"
  15. Click "Next."
  16. Click "Finish."
Important: The Yahoo! Mail SMTP server now requires authentication. To turn this setting on:
  3. Double-click the account labelled "pop.mail.yahoo.co.uk."
  4. Select the "Servers" tab.
  6. Click "OK."
  4. Select the "Advanced" tab.
  5. If you'd like to keep a copy of your email messages on the Yahoo! Mail server, check the box next to "Leave a copy of messages on the server." If you want to delete your messages from the Yahoo! Mail server after viewing them in Outlook Express, don't check the box.
If you're unable to send email, try using port 587 when sending via Yahoo!'s SMTP server. Here's how to make this change:
  1. From the "Tools" menu, select "Accounts."
  2. Select your Yahoo! POP account and click the "Properties" button.
  3. Click the "Advanced" tab.
  4. Next to "Outgoing server (SMTP"), change port 25 to 587.
  5. Click "Apply." Then click "OK" and "Close."
Jan 12, 2009 | Computers & Internet
Computers & Internet Logo
41 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
