Stops cooling after a few mins
.works well inicially for a 15 - 20 mins but then makes a louder noise and stops cooling when rom temp goes down to about 27º. fan still works bu temp rises rapidly in room..there is also a dimming of lights etc. temp outside is in the mid to high 30º.filters are clean
  • 52 Answers
Check the condenser fan motor It probley has bad bearings and over heats and shuts down
after 15 or 20 min of run time
Posted on Jul 25, 2009
After running for awhile when i stop it makes a humming noise and when i start after 25 miles an hr the noisestops
Sounds like your electric cooling fans are working properly...any change in coolant temp in these situations?
Jun 17, 2015 | 2000 Mercury Grand Marquis
PTAC stops running after a short time
Sounds like a voltage or amp draw issue. So how about if you only try to run the blower??
Jun 05, 2017 | Heating & Cooling
McQuay PTAC stops working after short time
Sounds like you need a new control board with thermistors. you probably have a relay that is getting hot and quitting.
Sep 19, 2014 | Heating & Cooling
Heater fan runs for a few min then shuts down
Check the afc Automatic fan control is shut off too soon .
Apr 29, 2017 | Vulcan Heating & Cooling
Why has my fridge freezer started to make a louder humming noise?
no problem with that it is normal..your ref working properly it is just the motor you hear
May 22, 2012 | Beko Refrigerators
Amana Cooling Condensing Unit fan stops spinning after 15 mins
Capacitor, dirty condencer coil causing the motor amps to run too high. But most likely worn bearing on blade side of motor causing it to pull to one side causing it to over heat and shut down. Sleve bearings should have no side play.
Jun 28, 2009 | Amana PTH123B25AJ Heat Pump Air...
Drivers side ac switches to heat
THE TEMP ACTUATOR IS BAD. SOMETIMES THE HVAC MODULE IS THE PROBLEM TOO.
Jun 16, 2009 | 2004 GMC Sierra
AIR CONDITION NOT COOLING AT FIRST & HORN, CRUISE,RADIO ON SW
Sounds like the compressor is weak. Replace it. Check pressure when hot .
Jun 11, 2009 | 2002 Lincoln LS
1997 960 volvo.think? auto tranny pump makes whinny noise cold.
Your transmission is going to fail sooner or later, the whining noise you hear is the the clutch packs in the transmission going out.
Mar 26, 2009 | 1996 Volvo 960
Heating & Cooling Logo
194 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
