Question about Peg Perego John Deere Front Loader
Hydraulic oil is leaking into the transmission while 644d loader not running
While loader in just setting after a few days oil started dripping out of the transmission breather
    Genius:
  • Peg Perego Master
  • 1,474 Answers
This toy doesn't take any fluid
Posted on Aug 18, 2017
My 79 ford courier is leaking oil badly when it hasnt been driving and parked for days
Here is what you must do, pressure wash the engine and the transmission top and especially bottom of all grease and oil residue then install a bottle of special die that glows under a black light, drive the truck for a 10 or so miles and then put it on a car lift and check for the source of the leak with a black light. On this old of an engine the leak are likely all over the place.
Jun 09, 2016 | Ford Cars & Trucks
Oil leak when engine is running.
Perhaps one or more seals have failed.
May 09, 2016 | John Deere 240 and 245 Farm Loader...
Leaking transmission fluid
TRANSMISSION FLUID LEAKS,CAN BE FOUND AROUND PAN GASKET.CHECK PAN GASKET,IF IT LOOKS WET AND YOU SEE FLUID DRIPPING AROUND THE EDGE OF OIL PAN, REPLACE PAN GASKET, WHILE YOU REPLACING PAN GASKET REPLACE TRANSMISSION FILTER WHILE OIL PAN OFF.IF TRANSMISSION OIL PAN NOT LEAKING, CHECK TRANSMISSION OIL COOLER LINES GOING INTO RADIATOR YOU WILL LOOSE A LOT OF FLUID THERE ALSO TORQUE SHAFT SEAL WILL CAUSE HEAVY FLUID LEAK WHILE ENGINE RUNNING CHECK OIL COOLER LINES AND LOOK AT THE TORQUE AREA WHILE ENGINE RUNNING YOU WILL SEE FLUID POURING WHILE ENGINE RUNNING THE OIL PUMP PRESSURE WILL PUSH FLUID OUT AT THE LEAKING AREAS.
Aug 01, 2011 | 1991 Nissan Stanza
Transmission oil foaming and pushing out of dipstick tube during normal transmission operation. Transmission has been serviced - oil & filter replaced with OEM components.
Has the suction filter been serviced? And what transmission oil have you used? Is it John Deere hydraulic oil or hydraulic/transmission oil? Does the tractor have a loader?
Dec 10, 2010 | John Deere 420,1020,2010,2020,2510,2520...
1998 Mercedes Convertible Top Slow and Drips Oil
Your top is moved by an electric motor wich operates a hydraulic pump which moves two pistons which move the top.
The "oil" thet you see is probably hydraulic fluid leaking from the drain hole in the car near the tire.
You have a leak in the hydraulic system.
You need to start at the motor/pump/reservoir unit behind the seat and find the leak.
Most commonly, it is a bad line. Second in popularity is a bad cylinder(s). Third on the list is the motor/pump/reservoir.
If you replace a line, do them all. If you replace a cylinder, replace them both.
Karl at topgunwon.com
Aug 13, 2009 | 1998 Mercedes-Benz SLK
We have just purchased a john deere 2140 B reg. it seems to have a bad oil leak on the hydraulic system. the position of the leak is in the centre of the vehicle directly below the drivers seat. it drips...
Probably oil from the pto output seal.
Also they leak from the inner linkage arm seals.
Both reasonably easy repairs, seals readily available.
System holds a lot of oil and low oil will affect the hydaulics and steering.
Jul 27, 2009 | Garden
Leaking clutch 85 s10 blazer when I bleed the slave cylinder oil leaks out the bell housing
First, unless you have just done some clutch work you should not need to be bleeding the clutch hydraulic system...that shows that it's leaking. There is nothing inside the bellhousing that has anything to do with clutch fluid, so, the fluid you see is either engine or transmission oil (rear main seal or seal on trans input shaft) Could it be that the clutch slave is leaking and it's running down and dripping at the bottom of the housing? (clean it up and check that)
Jun 17, 2009 | 1985 Chevrolet S-10
2020 john deere diesel tractor with j-d 36# loader
Sounds like you need more hydraulic oil - Or like you said the transmission screen (dirty).
Where it is ??
Mar 27, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Suzuki grand vitara 1999 hydraulic cylinder
Hydraulic leaks are typically a result of seals/o-rings wearing out. If you gave a leak coming from the cylinder you will probably have to replace the cylinder. Unless you are can do the repair yourself its unlikely that you will find someone who can rebuild it for less than a new one costs
Feb 22, 2009 | 1999 Suzuki Grand Vitara
Peg Perego John Deere Front Loader Logo
95 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
