I have a singertreadle machine cearal no.JC096073 can you tell me how much it is worth it works very well,in light Coloured cabinet.?
Have a singer model 750 (came with a cabinet I wanted) machine is locked up. Is it worth repairing? Looks to be very good condition.
Usually, a good dose of machine oil will usually loosen up a locked up machine. It's worth a try.
May 04, 2017 | Singer Sewing Machines
Friend died. Has this machine, how much would it be worth? how do we tell how old it is?
First, you'll need to find out the make and model of the machine. After that, it's a matter of determining what physical and working condition it's in, whether the manual and what accessories are included, whether it has a carrying case, etc. Price is mostly subjective since it is usually based on the make/model, age, condition, usability, accessories, location, and overall public demand. Used sewing machines can be priced anywhere from $1 to thousands. Older Singer sewing machines are very common so the prices are generally lower for lack of demand unless it is a specific model, ie the Featherweight is coveted for its transportability and stitch quality. Machines in cabinets are usually more difficult to sell, etc. However, if it is something like a Bernina 830 Record, an Elna Jubilee or Grasshopper, or a Husqvarna Class 10, it could be worth more because of its desirability.
However, some sewing enthusiasts just want a good, solid machine that works.
You can probably search the internet for similar machines that have sold or are listed for sale to get an idea.
May 23, 2016 | Sewing Machines
Can I put an Elgin machine in a Singer cabinet?
You probably can but not without doing some (maybe a lot of) retrofitting. Difference in machine footprint will make a big difference. Also, connecting the lifting hardware, etc. adds to the overall difficulty. You could always ask a handyman familiar with woodworking but chances are, the expense will be more than the machine is worth. But, then sometimes nostalgia wins!
Jan 09, 2016 | Singer Sewing Machines
We have an old Singer sewing machine & would like to know approx. its value?
SORRY but no we can not assist the lack of information you provide is a big problem suggest you try SINGER singerco com
Sep 12, 2017 | Sewing Machines
Is my china cabinit from the 1940s worth anything if it is in good condition?
Because your china cabinet is from the 40s, it is considered anantique. Antiques in good condition tendto go for a lot of money, even if the item was originally purchased for a smallsum. I would call an appraiser in yourarea to give you some tips on how to restore the cabinet. The appraiser will then tell you how muchyour cabinet could go for in auction or private sale, once you have completedthe restoration process.
May 29, 2012 | Furniture
I need to get access to the inside of a kenmore top laod washer how would i go about getting inside of it
The entire cabinet removal procedure is illustrated in this diagram. Even though the procedure is very straight forward, a couple of fine points are worth mentioning:
  • Some Kenmore-branded versions of this washer use plastic endcaps to cover the console screws. Just remove the console end caps and the console retaining screws are right there. This technique is illustrated in this photo.
  • Once you've removed the console screws, flip the entire control console up and back to reveal the cabinet retaining braces, shown here.
  • After you pull the cabinet back and away from the washer, here's an illustrated anatomy of your naked washing machine. The lid switch is screwed to the inside of the cabinet top panel and is easily accessible with the cabinet removed.Hope this helps GOOD LUCK
Dec 16, 2010 | Kenmore Washing Machines
Help! We have a KV27TW75, Sony, cabinet tv, which simply stopped working. It's like the power was shut off. We doubt that it's worth fixing, but are wondering whether we could fit another tv INTO that...
The tv in the cabinet could be fixed. First check the mains fuse. It sounds to me that the internal power supply board fuse has blown, to access this you will need to access the back, once you have access to the insides of the set where the power cord enters the set you will find a small somtimes coloured fuse set in a small fuse holder, pop it out, take to your local electrical shop and you should be able to find the same rating fuse, and the good news is that they are only cheap. Make sure you get the exact rating fuse to replace the old one.
With regards to the cabinet if the above dos'nt fix the set, then yes it would be possible to put another set into the cabinet, but you would probably find you would have to do alot of modifications yourself to fit another set, you would have to find the screen dimentions, and need to be able to secure the set properly. hope this helps a bit and post back if you manage to get the set going again. thanks.
Oct 30, 2010 | Sony Televison & Video
Black grease stains on cloths, grease is coming out from one area in the drum. Whirlpool Calypso-6 years old. Is it worth repairing ?
Machine life is depends on the cabinet condition if the cabinet condition is good means you can service the machine it will be useful otherwise it is better go for exchange
If cabinet is good condition means you can use it for few more years also
Jan 08, 2010 | Washing Machines
Epson Stylus Photo PX800FW doesn't print text
printer working ok-did 50 colour photos ,6x4 when i made a mistake and pushed the print button when there was still about 1 inch of the previous photo still being printed.This print emerged with overprint of about 1".Thereafter the printer has refused to operate properly the next print being heavily discoloured.It then told me to replace the light magenta cartridge-this I did and the discolouration changed hew.It then told me to change the magenta and light cyan carts.-I did and discolouration changed again.It then told me to change the yellow and cyan=siscolouration now bright
red over coloured. I then successfully printed a letter in B&W proving that the black cartridge was still working.However as soon as I tried again to print a coloured photo it now tells me that the machine does not recognise the black cartridge and orders me to change it and until I do refuses to take any instructions telling me to install the black cartridge cprrectly.The black cartridge installed isout half full and has successfully printed copies and photos.I have carried out the suggested remedies by the machine and none were effectuve.How do it the infernal machine working again???
Oct 11, 2009 | Epson Office Equipment & Supplies
Code f21,
Remove the front kick panel (3 screws on the bottom and the panel will just slide off) on the side of cabinet there will be a plastic enveloppe, or a paper one with a sheet in it. This is the tech sheet. It will show all the error codes for your machine. Look up F21 and it should tell you how to test the component that is causing the failure. Based on that, you can decided if it's worth calling a technician.
Feb 12, 2009 | Kenmore 46462 Front Load Washer
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
