Question about KVH 01 0277 01sl Tracvision A7 Mobile Satellite Tv Antenna System
KVH M7 track vision problem.Not tracking
Hello I have a KVH M7 track vision satellite. When I switch it on the antenna starts searching for the satellites but can not find the first one. I used the antenna in north Greece with Eutelsat W2 and Astra 1 satellites.There is a full coverage here by both of them.When I was in Italy and France everything worked perfectly.
If somebody can give me some clue will be great.
Thanks a lot
    New Friend:
  • 132 Answers
As you move east and west on the Mediterranean, you must adjust the LNB, rotate it, see book.
Posted on Jan 27, 2010
  • Evgeny Chereshnev
    Evgeny Chereshnev Oct 14, 2013
    Sorry, but you say nonsense. A7 can recieve only circular polarisation. It wouldn't work wit linear polarisation from eutelsat w2 and astra. A7 can work in north america with directv or in russia with NTV+ and Tricolor
  • 20 Answers
Please use http://www.dishpointer.com/ to calculate skew angle. For example Astra2 in North Greece have 21 degree skew and in France have only 6 degree skew. You had to changeLNB skew. In my opinion +-5 degrees is quite good acuracy.
KVH M7 track vision problem.Not tracking - kvh-m7-track-vision-problem-not-tracking-0betnbuhgrcovrmdypkzkom3-3-0.jpg
Posted on Jan 25, 2015
Stuck acquiring satellites
HotBird 13E, Astra2 28E, Astra4 5E and so on. Depends on what TV programs you want to see.
Oct 05, 2013 | KVH Boating
Can not locate satellite continues to search
There are few possible reasons.
Antenna can't "see" satellite.
Wrong data programmed.
Wrong skew angle.
Damaged RF board.
If you make log-file it will be much easy to understand your problem.
Jun 26, 2013 | KVH 01 0277 01sl Tracvision A7 Mobile...
Kvh tracvision r4
In those KVH dome antennas there is a belt attached to the motor that makes the antenna rotate on the inside. When this is not moving then it really can only be a couple of things. Either the belt is broken or worn down which is not letting it rotate the antenna, or the motor that moves the gears in which the belt is attached has gone out. In both these cases either the belt must be replaced or the motor must be replaced. if you need anything else or have any other questions feel free to contact us at 877.299.9931, or you can take a look at our website at www.NorthernAxcess.com. We have a full satellite communications service and repair centre in which we handle KVH repairs and other satellite internet terminal repairs and parts. We also do satellite phone repair and parts, and BGAN satellite modem repair and parts. Satellite phones such as iridium extreme 9575 satellite phone repair and parts, iridium 9555 satellite phone repair, iridium 9505A satellite phone repair and parts, and the inmarsat isatphone pro satellite phone repair is some of our specialties. We have many years of experience and friendly technicians. We have a dedicated site for repairs at www.NorthernAxcess.com/satellite-phone-repairs-and-bgan-repairs . We are a Premiere satellite communications service. We also do satellite phone sales, rentals, airtime, and installations. Call us...
Sincerely,
NorthernAxcess Satellite Communications Support Team
May 31, 2013 | Televison & Video
WHEN I TURN THE UNIT ON THE MOTOR CONTINUES TO RUN FOR A LONG TIME. SOMETIMES IT WON'T STOP RUNNING SO I TURN THE UNIT OFF. IT SOUNDS LIKE THE LNB IS SPINNING AROUND AND AROUND. I HEAR A COUPLE OF...
There are many possible reasons of this problem. Maybe antenna didn't see satellite, maybe satellite setup is wrong (frequency, bitrate and so on). The best way to solve your problem is to get logfile from antenna.
Jan 02, 2011 | KVH 01 0277 01sl Tracvision A7 Mobile...
Not tracking satalite.
If you can hear the dish actually serching when it says "searching", there is a good possibility that you have a bad LNB on the dish. Unfortunately, this is not the only thing that can cause the problem. Your best bet is to call KVH @ 4018473327. Make sure you are on the boat when you call and they will run you through all of the programming checks to narrow down your issue. Good luck.
Sep 01, 2009 | KVH Tracvision M3 Satellite Tv System
Satellite Spins but can't find signal
I have a brand new A5 satellite in the box. I never used it. Are you interested in just replacing the satellite itself?
Aug 07, 2009 | KVH TracVision A5 Car Video Player
Trackvision repair center in okla
First question, is it under warranty? If the answer is yes go to http://www.kvh.com/WhereToGetService/ and find an authorized repair center.
If not and you feel comfortable with electronics there are a number of things you can check yourself.
*The following is based off my experience with a KVH A7, proceed at your own risk.
Step 1 take the unit off the vehicle and place it upside down on a flat surface, I use a towel to minimize any scratching.
Step 2 take all the screws out from the bottom. There are quite a few and they are all hex heads.
Step 3 once all screws are out of the bottom carefully flip the unit and separate the top from the bottom. Note the 'Dome' does not remove at this point just the plastic around it.
Step 4 remove the 4 large phillips screws holding the 'Dome' on the satellite and remove the 'Dome'
**Disclaimer** you now have access to the electronics of the satellite, be careful! Take ESD precautions and stay grounded to avoid zapping a board.
Step 5 you will notice two electric motors. One that is attached to a large belt under the 'spinning' part that rotates the satellite and the second smaller motor controls the pitch of the satellite.
Step 6 I would start to inspect all parts and see if anything looks broke or out of place. You should be able to move the satellite around in a circular motion by hand without much resistance (there should be some from the engine). If it does not spin I would check the bottom belt and or the bearing track that the satellite spins on.
I would not advise taking the unit apart any farther. Generally most problems I have seen that are not board related are pretty obvious when you get the top off. The KVH family of satellites seem to be the only piece of electronics in the world that there is no good on-line support or discussions for.
Best of luck!
Dec 20, 2008 | KVH 01 0277 01sl Tracvision A7 Mobile...
KVH 01 0277 01sl Tracvision A7 Mobile Satellite Tv Antenna System Logo
958 people viewed this question
Top KVH Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a KVH Boating Expert? Answer questions, earn points and help others
