Question about Dishwashers
Why is there no water to spray heads.
Removed spray arms and internal piping and reinstalled but, still no water. there was no blockage.
  • 1462 Answers
SOURCE: water not going through spray arms
possible you have a leak and the bottom tray has water in it. tilt the machine back to 45deg and see if water runs out of the back. if it does, after putting upright, the machine will work - then find the leak!!
Posted on Jun 19, 2008
  • 15935 Answers
SOURCE: Lower spray arm does not spin on my bosch dishwasher
The quality/quantity of responses you get here on FixYa can greatly vary for WHEN you place your question.
There are a handfull of "experts" who use fixya that simply have a generic cut and paste answer for every question asked on FixYa.
"Final Answer" is one.
Many have little to no english skills, and resort to cutting and pasting the same answer to every question.
I apologize for their ignorance and im sure your post will soon be answered by knowledgeable QUALIFIED personnel.
Real answers are not automated here - I assure you. Give it a little time for our experts in the US to wake up and get coffee into their system.
We are not employed by FixYa - sitting in a little cubicle waiting to answer questions. Most of FixYa experts do this in their spare time between real service calls.
Be assured that if you are not satisfied - it is easy to request a refund. Please email if in the next day or so you have not gotten a fix to your problem.
Now that's out of my system I can try to help troubleshoot your problem.
Bosch dishwashers use a water system called FLOW CONTROL... which utilizes a valving system to control which arm gets water during the cycles.
Most washers see water at both arms all the time. Yours is controled with a PLC and uses information gathered from onboard sensors to tell the valves to open or close.
Your Lower sprayarm valve is faulty, or the controller board is bad.
Since we do not know your mechanical/troubleshooting skillset - all we can do is offer advice and try and help you if you feel this is a problem you would rather attempt to tackle yourself.
I have searched BOSCH website and could not find your model washer in their documentation. Please double check that it is SHV55M03GB/40 that you posted.
Posted on Mar 20, 2009
  • 81 Answers
SOURCE: removed lower spray arm:ge gld5500 dishwasher. Can reinstall.
Posted on Apr 24, 2009
  • 115 Answers
SOURCE: Low water flow and pressure
remove aerator and cart. and soak in limeaway over night
Posted on Jul 26, 2009
  • 21 Answers
SOURCE: leak where Grohe shower head attached to the threaded pipe
using a pair of vice grips wrapped in a soft towel( to prevent scractching) turn the shower head in a counter clockwise direction to remove it then apply liquid teflon (real-tuf) to the threads on the shower arm and tighten the shower head but dont over tighten it liquid teflon is more effective at sealing leaks than teflon tape and it can be wiped clean
Posted on Dec 03, 2009
Kitchenaid dishwasher KUDP01IL upper spray arm not spinning although water supply appears to be adequate (water sprays from jets but the arm remains stationary).
Just had the same problem, and fixed it. Spray arms turn with proper water pressure in the pipes. 3 reasons can lower the water pressure. 1-pump motor losing power (wasn't my case) 2- cracked pipe (wasn't my case either, pipes, although plastics, seem to be very solid) and 3- debris in the pipes/filters. (It was my case) At first, it looks difficult to reach de filters, but it isn't.
1- Remove both baskets, the top one by removing the front plastic cap on the rails.
2- Remove the "+" bottom spray arm, by unscrewing counterclockwise (if I remember well...) the plastic screw dead center of it (use your fingers.)
3- Remove the three screws you see, but don't try to remove the filter part right away because there is a 4th screw under the leading water pipe, the one leading water to the top spray arms.
4-To remove the 4th screw, you must remove the plastic pipe that connect with the top spray arms. Easy. It's beeing held there by two clips, one on the back wall and one on the top wall. Just spread them with your fingers (or screwdriver) and turn the pipe toward the right side, to free the bottom part of the pipe from the middle/bottom spray arm holder, you'll have to bent it a little so it passes over the heating element.
5- Remove the last screw. Now there's nothing holding the bottom part anymore. just remove by moving it back and forth left and right (to loose it up), be carefull not to lose the clear plastic washers on the main shaft when removing. Now if your dishwasher is like mine (should be) you should see a lot of debris that couldn't reach the chopping device. In fact, the water couldn't flow properly because of all the debris stocked there by the bottom drain filter. Patio screws (?) small chicken bones, etc...
6- If you can find something to pump the water resting at bottom there, (I used a Prestone coolant tester!) you'd have a better view, and could remove the single screw holding the chopping device cap in place. That's the last step. Notice that the chopping device cap, even after the screw is removed, still look like firmly attached, like "glued", but there's absolutely nothing else holding the cap. Just shake it with your hand and it will eventually come off. Now you remove all the dirt/debris you see there, and then follow thw step back the rebuild the washing machine. On my part, it brought it back like if it was brand new..., but, now I'm being a little more carefull about the stuff I'm putting in there...
I hope it can help, English is not my first language.
Good luck
Montreal, Canada
Dec 15, 2010 | KitchenAid 24 in. KUDP01IL Stainless Steel...
Apparently no water pressure to upper washing arm.
Hi sounds like there is a blockage in the circulation pump which causes low water pressure as it cannot push the water around. You would have to remove the unit and turn on it's side and remove the circulation pump to clear the blockage.
Also check all the holes in your spray arms for any blockages. Best to remove each arm and clean in the sink. Any blockages causes the arms not to turn.
Jan 24, 2010 | Frigidaire Dishwashers
The bottom spray arm gets jammed in lower dish rack.
I would unscrew the cap and remove the whole thing... you might have something clogging one side, which makes more water come out on one side than another, causing it to wobble... or you may find something else causing the problem.
If there is a blockage, clearing it out can be tricky. really long pipe cleaners work well. Craft stores have them.
Jul 25, 2009 | Whirlpool Dishwashers
Bottom rotating arm doesnt spray water but top arm does
i have a similar problem. water is not reaching the bottom spray arm. there. i have an underwater case for my digital camera, so i'm going to put a torch or 2 in some waterproof bags and remove the bottom spray arm and run the dishwasher to see if there's water coming out of the bottom pipe, if not, i need to try and see if there's a blockage in the system, or a dodgy valve, could be that the soldering's or the control panel's buggered.
Nov 24, 2008 | Siemens 24 in. SE25T250 Free-Standing...
Neff dishwasher
if the arm is rotating freely when you give it a push by hand, then the problem is blockage in the jets in the arm - the arm only rotates with water coming out of angled jets at the end. take arm out, spray water in centre hole and whatever is blocking the jets should become visible. prize out with a paperclip or similiar
Aug 07, 2008 | Dishwashers
Upper spray arm is not turning round even though water is coming through. We have checked the internal system for blockages and the machine is filling / draining as normal. When a full programme is run,...
I found the problem to be neither blockages of the upper arm or roof spray arm or the upper basket arm hitting the the back of the dishwasher. the problem was that the pump inlet where the food scraps are macerated was blocked with all manner of gunge including small chicken bones plastic and other detritus. Removal of the macerator housing under the upper filter housing using 2 different sizes of torx driver easily fixed the problem. Probably why the upper dish rack cleaning degraded overtime, Directly proportional to the amount of detritus blocking the intake screen behind the macerator.17a8801.jpgb9e8fa8.jpg789f2b8.jpgfb7a626.jpgator. See pics
Jul 13, 2008 | Dishwashers
Dishwasher spray arms don't spin & spray water
Could be a a couple different issues.. Not filling with enough water or food chopper broke or food chopper filter screen clogged.
Check water level:
Run the DW and wait for the main wash to start (water will fill. pause then complete fill) The water should be no more than 1/4 inch below the heating element. If not there..replace water inlet valve.
Inspect food chopper:
1. Remove lower spray arm and rear water supply tube to upper spray arm.
2. Remove torx screws that secure the sump cover.
3. Remove primary filter
4. Remove food chopper cover to expose the chopper assembly. Inspect for breakage or blockage.
If you need further assistance, let me know
Jun 29, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Internal Water Pipe Keeps Coming Out
There is a bracket held in with 4 screws under the lower spray arm, near the filter that has 4 lugs which the feed pipe for the top spray arm plug into. They are very common for breaking.
Mar 19, 2008 | Whirlpool 24 in. ADG6340 Built-in...
Water not spraying hard enough
Check water level:
Remove lower spray arm and rear water supply tube to upper spray arm. Remove torx screws that secure the sump cover. Remove the rounded cover on the left side to expose the chopper assembly. Inspect for breakage of blockage. There may be an additional plastic screen to remove first.
Sep 30, 2007 | Whirlpool GU1200XTLS Stainless Steel...
Dishwashers Logo
24 people viewed this question
Top Dishwashers Experts
