Question about Sewing Machines
Sewing machine thread is jamming up - Sewing Machines
  • 21 Answers
More info needed
Posted on May 09, 2017
Machine is jamming. Top thread broke so re threaded and re did the bobbin,but it is still jamming every time i try to sew
just found this on the internet...
Fabric jamming in your machine may be caused by the feed dogs. The feed dogs are those tiny teeth along the sewing machineunderneath the presser foot as those teeth pull the fabric through when the needle is making stitches.24 Feb 2016
Why Does My Sewing Machine Keep Jamming?•Sewing Made Simple
sewingmadesimple.net/why-does-my-sewing-machine-keep-jamming/..
or go to this link..
sewing machine is jamming Google Search
Oct 27, 2017 | Sewing Machines
Sewing machine jam
If you mean that the needle has jammed with a build up of thread, then the only option is to cut the thread, raise the needle, if you can, and remove ALL pieces of cut thread. Sometimes if it's really jammed, you need to use a sharp knife, horizontally, to slice through the jammed thread.
The bobbin should be removed after this, and ALL traces of thread removed from all areas. Then, re-thread, re-insert bobbin, and try again.
Apr 19, 2015 | Brother Sewing Machines
Threading the machine
You said it jams when you start to sew. Please clarify. how and where does it jam?
Make sure you threaded the machine with the foot in the UP position. Make sure your bobbin is in the case correctly and is spinning in the correct position when you pull on the thread.
When starting to sew, grasp the top and bottom threads and gently tug, then hold it down to the surface of the machine as you begin the seam.
Jul 14, 2012 | Necchi 3537 Mechanical Sewing Machine
Sewing machine motor jams when I sew thick fabric
a part of the computer is malfuctioning, & needs to be checked
try a new needle
rethread the machine using every thread guide
clean under the needle plate & in the bobbin area for loose threads & lint
Mar 19, 2012 | Sewing Machines
The bobbin thread will not pick up. The machine had jammed and I forced the wheel and can't get bobbin thread to pick up. When I thread manually, I only get holes, no stitches. Is it a timing belt?
check your needle to see if it's bent---roll on flat surface to see if it roll correctly
on some sewing machines when the thread comes off the thread take up lever it can cause the machine to jam
also if the bobbin thread becomes tangled it can jam
check the bobbin area for lint or loose threads
try having a top thread tail & bobbin thread tail of 3-4 inches
try holding the top thread tail & turn the handwheel on the right side on the machine manually & put the needle down into the bobbin area & see if the bobbin thread will pick up that way
Sep 24, 2010 | White Sewing 2037 Mechanical Sewing...
Sewing machine is jamming
The UPPER thread is not threaded through the machine correctly.
Feb 11, 2010 | Kenmore 11101 Mechanical Sewing Machine
Keeps getting jammed
Give these solutions a try.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin as there could be a nick along the edge of your bobbin spool that’s catching your thread as you sew.
* When you start to sew a seam, Hold the upper and bobbin thread tails back and out of the way as you sew your first couple of stitches. This will keep them from getting jammed in your machine.
I hope this helps.
Dec 29, 2009 | Sewing Machines
My sewing machine keeps getting jammed when sewing. the top stitch keeps getting tangled in with the bobbin thread and jamming up the machine.
Here are a couple of things to try.
There could be a nick along the edge of your bobbin spool that’s catching your thread as you
sew.
* When you start to sew a seam, grasp the upper and bobbin thread tails. Hold them back
caught in your machine.
I hope this helps.
Sep 11, 2009 | Singer 5160 Mechanical Sewing Machine
Sewing machine jammed wheel will not turn
Thread is caught in the hook...Remove the upper thread and bobbin case...turn the hand wheel backwards and forwards by hand and remove the thread remands. Good Luck
May 17, 2009 | Brother CS-8060 Computerized Sewing...
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
