Question about Sony Televison & Video
I have an old sony tv 60" model drc-mf/mid digital quick focus,working fine but need a projector lamp, the picture quality is not that good
I need a projection lamp on a rear projector Sony TV model # KV-13FM13
Hi HG Allen,
Search Amazon or Google with your model name and the word Lamp replacement. You will find some lamps listed as "OE" which means it fits like original equipment (lamp) but it's an aftermarket lamp and is cheaper in price and quality. These lamps most of the time do not last beyond 3 months and the light output is weak so you picture is noticeably dimmer.
If you find an "OEM" listing and it says "Philips" or "Osram" then those are the quality lamps that are quality made and will last and your tv picture will be brighter like it was new again.. I hope this helps you.
Aug 29, 2014 | Televison & Video
Sony drc-mf, 29inch turns on, red light brinks 5 times at intervals
29 inch Sony tv D R C good working but pip & Twoin pics no picture blank plz help me
Dec 26, 2011 | Sony FD Trinitron WEGA KV-27FS100 27" TV
I`m in japan and have no idea what this front load ic card does on my sony DRC-MFV1/MID-X KD-28HD600. Any info at all would be helpful . thank you so much for your time mchael
There are two slots on my 42 inch version. One is behind the front access panel and is for the subscription TV service called BS/CS and the other is for a Sony Memory stick to directly display pictures on the TV in a slide show.
I had cable TV in Japan so didn't need the BS/CS service. My TV was bought in 2003 so is a bit old now - not sure if yours has the same features. Model of mine is DRC-MFV1/MID-X MBD-HXIP
Feb 28, 2011 | Televison & Video
My Sony trinitron drc-mf has now got a sort of negative screen (reddish black) with the actual picture of the DVD player,satellite TV,video ....etc but the menu,channel numbers........etc are all normal
If the Menu Display is normal. DRC module is faulty.This module is installed vertically and has a stainless steel cover, beside Tuner module. If you can do, try to remove the DRC Module,and clean its terminals with paintbrush then put it back properly, if it doesn't work replace the DRC module.
Nov 05, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Power keeps going on and off
Model number posted in question that is KDF-60SX955 shows it is Sony dlp tv, if tv shuts down and turns On itself then reason is weak lamp that is near to end of its working life and need to be replaced to fix this issue.
Lamp replacement procedure is written in user manual and its easy. Please buy Sony original lamp for good quality picture in tv.
Let me know if you have additional question.
Apr 18, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Television switching itself off with red light flashing.
Had same problem on a 50inch wega tv. It needed lamp replaced,not hard to replace about $180.00
from Sony.
May 07, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Panasonic lumix DMC-FZ10 at least 5 years old no longer focuses
There is a switch AF/MF to set the unit to auto focus/manual focus, try to set to AF mode.
Here is the link of the manual
check page 65
Apr 03, 2009 | Panasonic Lumix DMC-FZ10 Digital Camera
Pictures goes black while power light blinks green
I have a 40 but i was having the same problem. It turned out to be my lamp. I got a brand new lamp from Projector Lamp Services ( and my tv works fine now. Im pretty sure that the 40 and the 60 take the same lamp. You might want to give them a call.
Jan 05, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
HD channles
Hi Scan 1080: Enables you to receive the 1080i, 720p, 480p and 480i digital TV formats. By using the VIDEO 5/6 IN jacks, you can connect a DTV (digital television) receiver to view DTV programs. q DRC Multi-Function: Unlike conventional line doublers, the DRC feature doubles vertical and horizontal lines, resulting in four times the density for quality sources such as DVD, Satellite and Digital camcorder. q CineMotion: Using the 2-3 Pull-Down technology, the CineMotion feature allows you to obtain a smooth picture movement when playing back movies or other video sources on film. q Twin View: Using Multi-Image Driver (MID-X), Twin View allows you to watch two programs side by side with the ability to zoom in one picture and listen to selected window. You can watch pictures from two different sources (1080i, 720p, 480p or 480i) simultaneously. q 16:9 Enhancement: Vertical Compression technology that maximizes picture resolution on “anamorphic” or “enhanced for wide screen” sources, including selected DVDs. q Steady Sound: Equalizes volume levels so there is consistent output between programs and commercials. q Parental Control: V-Chip technology allows parents to block unsuitable programming for younger viewers. q Component Video Inputs: Offers the best video quality for DVD (480p, 480i) and Digital Set-top box (1080i, 720p, 480p, 480i) connections. q S-VIDEO Inputs: Provides a high-quality image for connected equipment. q Favorite Channel Preview: Preview up to eight favorite channels
Jun 02, 2008 | Sony KP-61HS20 TV
Picture changes focus/sharpness instantly and then recorrects
You can try and get more infornation for me.
Go into the the menu by pressing the WEGA GATE button on the remote. In the sub menu of picture adjustment switch the DRC-MF setting to off. It should read normal.
See if this stoppes your focus problem.
If it changes let me know for further directions.
Feb 24, 2008 | Sony KP-57WS500 57" Rear Projection...
Open Questions:
Televison & Video Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
