Question about Weber Grilling
I"ve got a Weber Genesis and it has three burners. One won't light with the starter but it lights if I ignite it. What can I do to the third burner rod to get it to ignite
    Habit-Forming:
    New Friend:
  • 46 Answers
Your zapper igniter is only to ignite one burner and that burner lights the other burner and so on. Follow the directions inside the left door and do it in the propper sequence and it should work as it suposed to.
Posted on May 08, 2017
My back burners wont light but my front two will genesis silver edition
If the Cross Over Tube/Burner is clogged, the ignition flame can't get to the last 2 burners to light them. To check this, light the front 2 burners using the ignitor button and try match lighting the back burners. If they match light, that indicates that the Cross Over Tube is clogged. You will need to remove it to clean it properly. Which can be a chore in itself. Be careful removing it, because if it's rusted, it may break.
Hope this helped you, Kevin and thanks for choosing FixYa.
Aug 07, 2011 | Weber Genesis Silver A Grill
My grill is a Genesis Silver B. The front burner ignites but the middle and back burner will not. I took off the tubes and can't see where anything is plugged or restricted. I can hear gas through the...
I believe your model Weber has a Cross Over Tube Burner , on the left side of the interior of the grill, just above the middle and back burner. If that's clogged or needs replacing, that's more than likely the culprit. As, it won't carry gas to those two burners. It is easily replaceable, if necessary.
In case you have misplaced your Owners Manual, I have included a link to it. You can download and print it for future reference.
http://www.weber.com/help/manuals/pdf_files/Genesis_SilverB_LP_Owners_Guide_55008_03_21_01.pdf
Apr 09, 2011 | Weber Genesis Silver B Grill
My Weber Genesis Silver only lights on the first burner. The second and third burner are not lighting.
Close the propane tank valve and disconnect the hose/regulator from the tank. Reconnect the propane tank and very slowly open the tank valve. You may have opened the valve too fast causing the built-in excess flow to close to a trickle. If you still have issues, let me know and I'll dig deeper. Douglas
Oct 08, 2010 | Weber Genesis Silver A Grill
I can not get the grill to light without turning on all three burners and then it is like a big puff and you see flames shoot up and then it lights with no problem. Not sure why it will not light with the...
The primary burner ,which is lite first and provides an ignition source for the remaining burners may be clogged and is not supplying adequate gas. Remove the primary burner and make sure all the holes are clear. Spiders are a frequent cause of trouble by building webs around the burners.
Apr 21, 2010 | Weber Genesis Silver B Grill
Back burner won't light on my Weber Genesis Silver A Gas Grill
Only front burner lights (out of three) and it only has flame comming out of half of the tube.
Apr 04, 2010 | Weber Genesis Silver A Grill
Gas flowing to burners 1 and 2 but not 3
there could be debris in the carryover tube..(the open channelled pipe that connects the three burners together) alignment is also critical,
Jul 12, 2009 | Weber Genesis Silver B Grill
Grill no longer producing good heat
read manual...possibly triggered propane safety bypass. Close tank, Turn OFF all burners, disconnect tank. Open one burner for 1 minute and turn off again. Reconnect tank. NOW OPEN tank slowly, all the way. Turn on first burner and ignite with starter or light through port hole manually. Hopefully works better.
Mar 25, 2009 | Weber Genesis E-310 Gas Grill
Weber Summit Grill Igniters
I contacted Weber and they sent me a complete igniter system. I will have to install it.
Oct 06, 2008 | Weber Genesis Gold B Grill
Grilling Logo
80 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
