Question about Vacuums
The carpet shampoor is not releasing the cleaner fluid.I have cleaned it and checked everywhere.
  • 25 Answers
SOURCE: BISSELL PRO HEAT X2 CLEAN SHOT
Try checking the lint filter. It is located in the top clear plastic section (the one with the dial to switch from floor to tool use) and is on the underside. It is a small (1 inch square) red plastic filter with a little door on it. Open the door and you will probably find it is clogged with hair, carpet fibre., etc.. Clean this out and you will hopefully have suction again.
Posted on Sep 18, 2009
Vac Belts
  • 701 Answers
SOURCE: Bissell pro heat steam carpet cleaner, not releasing water.
That means that you need to replace the pump belt. Here is the belt you need and a manual you can view:
Bissell 7901 Belt and Manual
Posted on Mar 02, 2010
Testimonial: "just what I was looking for thank you"
SOURCE: My bissell carpet cleaner is not releasing cleaner...
my bissel carpet cleaner is not releasing carpet solution
Posted on May 25, 2010
SOURCE: Model #5880-900 Hoover spin brush carpet cleaner
The brushes on the Hoover steam spin will not move.
Posted on Aug 10, 2010
  • 4 Answers
SOURCE: Bissell carpet cleaner
I have owned three Bissell cleaners and experienced clogged hoses each and every use. Do not put carpet cleaning solution in these machines. They are not designed correctly. If you have a tough spot, just use some liquid dishwasher detergent and a scrub brush. It will get almost anything out! Try it! Then, use the Bissell with hot water only to clean up any detergent residue.
Have a great day! Bissell Sucks!
Posted on Aug 31, 2010
Hoover brush and wash instruction manual
Hi there! To prepare for cleaning, put the solution and water in the top tank. While cleaning, all the dirty water gets sucked into the bottom tank. To clean squeeze trigger to release cleaning solution and slowly push carpet cleaner forward, this equals one wet stroke. Continue to squeeze trigger and slowly pull carpet cleaner back toward you (second wet stroke). Release trigger and slowly push carpet cleaner forward over area just sprayed with solution (dry stroke). Then slowly pull carpet cleaner back toward you without squeezing trigger (dry stroke). To avoid saturating the carpet don't do more than 4 wet strokes over one area. Always end with dry strokes. Here is a link to view the instruction manual if needed.
http://hoover.com/file/604/
Hope this was helpful!
Jun 19, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
Why is thecleaner not coming out of carpet cleaner
You have to continually hold the trigger to release the cleaning solution. If you don't hold the trigger closed then you are running the vacuum in carpet drying mode. http://hoover.com/file/610/
May 25, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
When I shampoo the bissell leaves black carpet bits everywhere. When I turn it upside down they are covering the bottom of the cleaner. Plus I don't think it's sucking up the water as well as it once did....
A bit strange. You may want to check any belt drives to see if they are working properly. The debris you see may be pieces of drive belt which in turn would hamper the suction ability of the vacuum.
Sep 17, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
My Bissell Pro Heat 2X steam cleaner is not releasing the water
Have you tried cleaning out the small filterfrom the reserve tank? Also, check the tank/resevoir valve is operating properly, when you take it out to fill try to make water release from tank.
Apr 29, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Mar 01, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
How to release and withdraw water solution to clean carpet.
Problem resolved by contacting a local retailer who provided instructions.
Dec 30, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Why isnt my carpet cleaner releasing or putting any water out onto my carpet
I believe we own the same model or one that operates like it. If so, then yours has a "bladder" for the clean water, it has to be almost full sometimes before it will release any. Check the nozzle on the bottom of the tank body and on the cleaner for anything that might clog it up.
I think it will also release water only when you pull the cleaner toward you and hold the trigger down long enough as well...it does not release when moving forward.
Also check the bottom of the cleaner and clean off anything stuck to it...it gets pretty dirty and that is where the water comes through.
Dec 26, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
i WAS LOOKING AROUND FOR A SERVICE MANUAL FOR MY F5897900 CARPET CLEANER AND I SAW SOME THING ABOUT HAVING TO "PRIME" THE PUMP. YOU PPARENTLY TAKE THE TOOL HOSE AND HOLD YOUR HAND OVER IT FOR ABOUT 15 SECONDS. THIS MAY OR MAY NOT WORK.
ANYBODY KNOW WHERE I CAN FIND A SERVICE MANUAL FOR A HOOVER CARPET CLEANER? SEEMS TO BE A VERY CLOSELEY GUARDED SECRET.
RON
Sep 18, 2008 | Hoover F5906-900 Upright Steam Vacuum
Vacuums Logo
32 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
